Old 03-03-2019, 06:09 PM   #1
Jcas
Jcas's Avatar
Drives: 2013 Limited Subaru BRZ
Exclamation First start after 4 and a half months
First off, I want to apologize if I am posting this in the wrong section it seemed like it would be the most suiting. So, yesterday I had replaced my headers, overpipe and front pipe all with aftermarket parts and I already had a catback on it, so now I have a full exhaust system . Now to my part where maybe i'm just bugging out because the car makes different noises changing so much with all the new exhaust components. I tuned it stage 2+ on the OFT and started it up, mind you its been sitting in my garage for 4 and half months because its winter here in the Northeast. So it started right up no problems at all idle was a little low at times trying to adjust to the tune at times but never stalled. So what had me worried is while it was warming up I popped the hood to make sure everything was kosher and all the sudden I started hearing a little ticking noise not to the beat or idle of the engine though. It was coming from the driver side engine on top somewhere it sounds like. I was thinking maybe just a lifter tick? Fuel pump? Injectors? Not really sure but yeah haven't started the car in a while nonetheless so that could also play a factor possibly just not used to the sounds yet maybe lol. If anyone has any ideas on what it could possibly be feel free to share! Thank you in advance.
Jcas is offline   Reply With Quote
Old 03-03-2019, 08:19 PM   #2
gravitylover
Is the gas in the tank the same 4 1/2 months old? Fuel pump not happy or maybe injectors...
Old 03-03-2019, 08:52 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
May have been lubricating things still. When it sits for that long, everything goes bone dry. Let it run for a half hour and tell us if it's still there. Could also be a belt or pulley, but terribly unlikely.
Old 03-04-2019, 10:31 AM   #4
Jcas
Jcas's Avatar
yes it is the same gas, but I also out stabil in it so the gas didn't go stale/bad. And yeah thats what I was thinking possibly.
Old 03-04-2019, 10:32 AM   #5
Jcas
Jcas's Avatar
Yeah thats true, I didn't even drive it yet either so im sure im just paranoid and itll go away once it runs more and actually drives and gets everything all lubricated and what not.
Old 03-04-2019, 10:53 AM   #6
New exhaust heating up, expanding and making a ticking sound. All exhausts do it but new ones can be really loud as everything finds it's place. It may have sounded like it was coming from the top of the engine since the noise bounced around a bit. The fact that it was not tied to the engine speed rules out most of the engine components.
Could also just be the style of header you installed. Some of them make some weird sounds.
Old 03-04-2019, 02:29 PM   #7
Yep, like said, I'd suggest you go fill up with fresh gas and then take a long drive (an hour or so). Maybe the car just needs to "shake it out" after its hibernation and the new exhaust parts need a chance to settle in.
Old 03-04-2019, 07:25 PM   #8
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Gas isn't going to go bad in 4 months, I have had motorcycles sit for a year with a full tank and start up like normal after taking them off my trickle charger.
Trueweltall is offline   Reply With Quote
Old 03-04-2019, 07:50 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
Then why is it recommended to use stabilizer for winter storage? There must be SOME degradation but stabilizer is also a lubricant which helps upon bone dry startup no doubt. It also quiets the crickets.
Old 03-04-2019, 08:27 PM   #10
Trueweltall
It's recommended so you spend your money on their product, it's marketing 101. Just top off your fuel tank before you store your car, if it's under a year you'll probably be a-okay. If it's outside in direct sunlight being exposed to a greater range of temperature fluctuations you will have more hydrocarbons evaporate and possibly more condensation getting in (e85 and blends).
Old 03-04-2019, 09:45 PM   #11
When the engine is up to temp and left to idle, the fueling system switches from port injection to direct injection. It can be disturbing for the unsuspecting owner because it truly makes a racket. Viewing the engine from the front, the DI pump is just behind the oil fill cap.
Here's someone else's video clip capturing the moment where it switches over.
[ame]https://www.youtube.com/watch?v=IBB3GREGPSc[/ame]
Old 03-05-2019, 08:06 AM   #12
Jcas
Jcas's Avatar
THATS EXACTLY THE SOUND!
Old 03-05-2019, 08:06 AM   #13
Jcas
Jcas's Avatar
fair enough thanks!
Old 03-05-2019, 08:07 AM   #14
Jcas
Jcas's Avatar
This is true since im new to the full exhaust life
brz, engine, headers, noise, tick
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 02:12 PM
Half trd parts from the factory? Grips&slips Scion FR-S / Toyota 86 GT86 General Forum 24 12-22-2018 07:26 PM
C-West Half-Lip 636 Cosmetic Modification (Interior/Exterior/Lighting) 15 04-09-2014 11:08 PM
WTB: TRD Intake Air Box (Front Half) FyeaFRS Want-To-Buy Requests 0 01-23-2014 11:20 AM
Half Inch Drop? Ray_32 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-28-2013 05:44 PM
