#29 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If you have documentation that the '13 OEM springs have already been changed out, you should be able to provide that as evidence for CA CARB purposes.
You kept the receipts, right?
"I gotta rock." -- Charley Brown |
#30 |
Famous Potatoes
Drives: '15 ultramarine
#31 |
Hey guys, I've got the Edelbrock supercharger on my 2013 FRS. I took it into one dealership that after downloading the Edelbrock manual said it would cost me $800 dollars for the extra labor. I contacted another and he said he didn't think it would cost extra unless they had to remove a belt (that would cost $125), but he didn't do the research that the other dealership had done. Does $800 sound reasonable? And, does the second dealership who told me it wouldn't cost extra not know what he's talking about?
| The Following User Says Thank You to kelpaso For This Useful Post: | mswbrz (03-02-2019) |
#32 |
Drives: 2013 FRS
If anyone has access to the tech bulletin and procedures to replace valve springs, that would help us understand how extra FI hardware affects this work.
The shop manual describes disassembling of engine, which starts by removing the fronts and pulleys... but I am hoping it isn’t necessary to replace valve springs ...
2013 FRS - JRSC CARB
"Use all of the track" they say |
#33 |
Drives: 2013 FRS
The dealer removes the engine , all the front pulleys and the timing cover. the cams need to be removed to replace the springs. the timing cover gasket and valve cover gaskets are replaced in this provedure.
| The Following User Says Thank You to Smaay For This Useful Post: | milanojess (02-13-2019) |
#34 | |
Drives: 2013 FRS
while you have the engine out, consider replacing the clutch and throwout bearing. |
#35 |
The service rep told me it would be about 5 hours of work extra because they need to take not just the SC off but a bunch of hoses too. Smaay, I'll look through the manual and see if I think this is a job I could take on. Thanks for the reply.
#36 |
Drives: 2013 brz limited / galaxy blue
My car falls under the recall 13 Brz and I was able to register with no issues and HAVE NOT DONE RECALL .
| The Following 5 Users Say Thank You to mswbrz For This Useful Post: | Clipdat (03-03-2019), CxG (04-08-2019), milanojess (03-03-2019), mrg666 (03-03-2019), shiumai (03-04-2019) |
#37 | |
Proud of BOXER
Drives: Subaru Boxer
That's great news!
#38 |
Grip>Slip
Everyone keeps saying (and taking at face value) that the car "has to be stock." Has actually anyone seen this policy in writing anywhere? If so, I'd LOVE to see the source. I don't think it has a leg to stand on legally. This ain't warranty work. It's NHTSA Mandated.
![]() https://www.safercar.gov/staticfiles...ecalls-FAQ.pdf I've got an investigation opened with the NHTSA as their literature instructs. Not my monkeys, not my circus. Last edited by xjohnx; 03-04-2019 at 02:14 PM. |
#39 |
It's not NHTSA mandated, it is a voluntary recall by Subaru, and by follow-up, Toyota. There's a difference, but the net effect is the same in terms of the work.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#40 |
Grip>Slip
Fair enough, although I guess the NHTSA investigation I opened will determine if Subaru is following in good faith the guidelines they set forth when issuing the "voluntary" recall.
#41 | ||
#42 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
It's not going to take an hour to remove the edelbrock SC and return to stock. That's going to take about 6 hours. My dealer refused to take the car unless it had been returned to stock. Contacted Subaru USA and after a week or so of back and forth they agreed with the dealer. They also refused to help in any way to cover the cost of SC removal and return to stock. So, I have not done the recall so far.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
| 2013 Scion FR-S Valve Spring Replacement Recall | Aussie | Northern California | 29 | 06-22-2020 01:51 AM |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
| Valve Spring Recall Resolved!!! | hgamit | Issues | Warranty | Recalls / TSB | 32 | 02-23-2019 10:00 PM |
| valve spring recall-engine oil leak | TYinhouse | Issues | Warranty | Recalls / TSB | 13 | 01-17-2019 11:09 AM |
