#57 | |
Drives: 2013 FR-S Argento
#58 |
Makes you want to buy two tubes on Amazon ($20/tube) and hand it to them when dropping off the car for the recall. Hahaha
The recall instructions don't say anything about how long to wait before adding oil or starting the car but the repair manual says to wait 30mins before adding oil or starting. The recall instructions also say "only P/N 00295-1217H will be accepted for FIPG Sealant". 1217H is grey so those photos above are proof that they didn't follow the recall instructions. Not saying that using the wrong packing is the cause of his failure but legally it is proof they didn't follow the instructions there for it would be easy to assume other parts of the instructions may have also been ignored. Everytime I go over the recall instructions I notice little details that aren't in the repair manual. For example they tell you to put tape over the OCVs before cleaning off the old packing. They also have significantly more detail in how to apply the packing on the caps and timing cover. They have revised the path you take around the oil gallery on the timing cover and they make it very clear how critical it is to not use too much on the cam caps for risk of "engine seizure". Toyota/Subaru really have gone out of their way to make very good instructions. I wish these instructions were around when I did my rebuild. Last edited by ermax; 03-01-2019 at 10:29 AM. |
#59 |
Benz Tech
Drives: 2017 BRZ Premium
Those photos show a lot sealant. The instructions specify bead widths, they are substantially larger than I’m used to, guess that Japanese machining isn’t as exact as the Germans.
They’ve been updating the procedure, looks like 2/13 is the most recent. I like this part. Those pictures aren’t fake, they know exactly what’s happening. Page 31 of the 2/13 update is pretty good too. Lots of yellow highlighter and bold “carefully”. I think they found the problem. Their technicians.
#60 |
Wow that is interesting. Do you have a link to this updated version? The instructions I am looking at are from 12/20. You are damn right though, they know exactly what is happening. These dealers should not be screwing people over for their mistakes.
#61 | |
Benz Tech
https://static.nhtsa.gov/odi/rcl/201...8V772-6522.pdf All the documents are here, .gov site. https://www-odi.nhtsa.dot.gov/acms/c...72&docType=RCL |
#62 | |
These are the Toyota instructions I have been looking at: https://drive.google.com/file/d/1uUi..._dVLZl_w7/view Last edited by ermax; 03-01-2019 at 11:18 AM. |
#63 | |
Drives: frs
#64 | |
Drives: frs
But they are going to inspect it again, been to this dealer 3 times in a week already. Last edited by msaikhan; 03-01-2019 at 12:40 PM. |
#65 | |
Benz Tech
I hope the techs are reading all the documents available. Any additional information you have before diving in to a project like this helps. |
#66 | |
Drives: frs
#67 | |
#68 | |
So the original dealer isn't going to cover their faulty work because you had another shop look at it? Did the other shop actually touch the car or just look at it? Man any excuse to get off the hook. |
#69 | |
Drives:
Sent from my SM-G930W8 using Tapatalk |
#70 | |
Drives: frs
2nd shop didn't touch anything, only listened and inspected externally. |
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 03:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
