Old 02-27-2019, 03:45 PM   #1
Tristor
Tristor's Avatar
Quality Hubcentric Spacer Brands?
Howdy All,
Besides H&R Trak+, are there any quality hubcentric spacer brands? I need 5mm, 10mm, and 15mm spacers that are hubcentric slip-ons. I'm looking around and I find a lot of brands, but without much that would lend me confidence in their quality.
Who makes good spacers?
Tristor is offline   Reply With Quote
Old 02-27-2019, 03:53 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Eibach and Ichiba are the other 2 that come to mind.
BigTuna is offline   Reply With Quote
Old 02-27-2019, 03:55 PM   #3
Code Monkey
Drives: Subaru BRZ
I highly recommend Motorsport Tech.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Tristor (02-27-2019)
Old 02-27-2019, 04:34 PM   #4
DAEMANO
Time Traveller
Parts Shop Max
https://store.partsshopmax.com/shop/...-5-125-56.html
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 02-27-2019, 04:55 PM   #5
Tristor
Tristor's Avatar
These look very high quality. I think this is probably what I'm going to go with. Looking at the other options, these seem to be the best I've seen so far.
Old 02-27-2019, 05:20 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
ok. Ill play... My suggestion: get single piece hubcentric spacers. Get ARP extended studs, they will work for: 5mm, 10mm, and 15mm spacers.
I have 5mm, 10mm, 12mm, 15mm, and 25mm spacers.
I have these...
https://www.ebay.com/itm/4pcs-12mm-5...ox!97412!US!-1
Running these in the front, 15mm in rear... They are machined perfectly. Use ARP extended studs with them. Additionally, their OD is the same as the brake rotor hub.
And these...
https://www.ebay.com/itm/Two-WHEEL-H...kAAOSwIgNXwjdF
I had ichiba. mag center, aluminum outer. IMO, two piece are crap. These Universal spacers have a bigger OD than the Rotor hub. They look really stupid.
The parts max are nice. Not sure the OD.
Why three sizes?
Cost and or brand, does not guarentee quality.
I LIKE TIRES!
Old 02-27-2019, 05:28 PM   #7
Tristor
Tristor's Avatar
Cost doesn't guarantee quality, but brands have reputations and some have better or worse reputations than others for quality. That is what I'm trying to get a grasp on, because this particular part is difficult to research what brands are even available, much less which are any good.
I think wheel spacers are perfectly safe to use when installed correctly and made properly. I'm confident in my understanding of their purpose and my ability to install them correctly. But as I'm not making them, I need some confidence that they are made properly before I bet my life on them on track.
I don't buy things off eBay for my car, ever.
Old 02-27-2019, 05:39 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have 100% confidence in the machined aluminum chunks from ebay on my car.
Good luck!!!
I LIKE TIRES!
Ichiba 10mm and 12mm HUBCENTRIC Spacer Kits WRKHARD Wheels and Tires 0 07-16-2015 03:47 AM
f/s b2 auto designs 20mm hubcentric spacer malubawla Wheels and Tires 3 01-23-2014 11:43 AM
FS: Ichiba V2 Hubcentric Spacer 20mm, $99.99 shipped. Figo Wheels and Tires 2 11-18-2013 11:27 AM
FS: Ichiba V2 Hubcentric Spacer 20mm, Central Jersey Figo NY / NJ / CT / PA 2 11-16-2013 05:28 PM
Project Kics 10mm 5x100 to 5x114.3 Conversion Spacer Hubcentric deedz Wheels and Tires 12 05-22-2013 04:18 AM
