Old 02-27-2019, 01:06 PM   #85
GrabTheWheel
Drives: 16' BRZ
Surge tank anyone?
GrabTheWheel is offline   Reply With Quote
Old 02-27-2019, 04:39 PM   #86
toast
Drives: 14 BSP Edelbrock BRZ
Nice execution.
toast is offline   Reply With Quote
Old 02-27-2019, 08:20 PM   #87
GrabTheWheel
Drives: 16' BRZ
Originally Posted by spitsnaugle View Post
Dang, I'd love to see what they came up with. I'd love to get some proper long tubes on the car. I went with CX racing and they're just acceptable.
I've been in talks with Brady about Pure buying some of the recessed clutch master cylinder mounts I designed, but I get a reply from him about once every other week, he must be busy with your car!
I was wrong they went with CX headers just slightly modified for the Vorshlag mounts. What don't you like about yours?
Old 03-04-2019, 09:40 PM   #88
GrabTheWheel
Drives: 16' BRZ
So far @ILLSMOQ is the only one I've heard of who's upgraded to a Ford 8.8 diff curious if anyone else with a swap has destroyed the stock diff? How much abuse can it take? Also really curious why Vorshlag hasn't put out any new info on developing new swap parts for our platform since like 2016? Is there just not enough demand and they've lost interest?
Old 03-04-2019, 10:06 PM   #89
wrxdriver2002
Drives: 2015 Subaru BRZ
I went with a Nissan R230 rear diff, which has a ring gear diameter of roughly 9.05”. I had DSS make me a set of level 5 Axles for it as well with their larger splined hub.
From what I understand, the oem brz diff can take quite a bit of abuse. I’ve never heard of anyone breaking one. I changed mine because I wanted something larger, different gearing options without having to have a custom ring and pinion made, and other LSD options.
wrxdriver2002 is offline   Reply With Quote
Old 03-05-2019, 09:36 AM   #90
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
They don't have a LS twin. They are in the process of swapping a shop car though. They have a build thread on it. I believe a new set of 1 7/8 long tubes and a different rear diff are in the works (New mustang). They have revised their transmission mount to include an actual trans mount instead of the tiny sliver of poly with the current mount. Can't develop more swap parts if they don't know what needs made. Not sure what else they could offer though.
Element tuning is running a stock diff on their twin turbo ls track car. Making almost 1k Whp. I may have misunderstood, but I am pretty sure they even had stock axles for some reason. Killed one last session. Though there isn't any long term info on the diff at those levels, I think only those drag racing and launching the cars hard have had diff issues, and that was mostly in the casing.
Click image to see their current progress
Old 03-06-2019, 04:35 PM   #91
GrabTheWheel
Drives: 16' BRZ
You're right Dustin, not much more they can develop for the swap. I was mainly thinking they could offer some kind of CANbus solution and package everything together as a "complete kit" possibly at a slightly discounted price if you bought all the parts, driveshaft, headers, etc. I'm glad they let you buy individual parts though, saved a little money not using some of their stuff.
I guess I'm just surprised more people aren't swapping these cars as they get cheaper to buy used every year. I thought at this point Vorshlag would have more competition from someone like Sikky. Simple answer I think is engine swaps are more expensive and complicated than people think...
Old 03-08-2019, 08:04 AM   #92
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Agreed
Old 03-13-2019, 12:57 PM   #93
GrabTheWheel
Drives: 16' BRZ
It’s almost ready...
Old 03-13-2019, 01:29 PM   #94
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
How much longer will we have to wait?
eastendraceshop is offline   Reply With Quote
Old 03-13-2019, 01:59 PM   #95
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I finished your fuel system and pump wiring today. Ill be sure to get you some fresh pics
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 03-13-2019, 03:15 PM   #96
spitfire481
Drives: 2JZ FRS
T56 Magnum XL with MGW shifter and Raceseng Circuitsphere extended knob:
Untitled by spitfire481, on Flickr
Radium surge tank setup with dual walbro 450's. Fuel system and AC is full PTFE hose and Fragola ends:
Fused 12v feed post in the rear for fuel pump and any other add ons/trickle charger:
Oil Cooler sandwich plate:
Engine Bay as it sits:
MoTeC
Build Thread
@spitfire481
Old 03-14-2019, 05:02 PM   #97
GrabTheWheel
Drives: 16' BRZ
It's ALIVE!
https://drive.google.com/file/d/1-WA...ew?usp=sharing
Old 03-14-2019, 05:18 PM   #98
Leonardo
Country Boy 4 Life
Leonardo's Avatar
That remote is fun to play with! It sounds good both ways!
I LIKE TIRES!
