Northwest AK, ID, OR, WA
Old 05-16-2018, 06:18 PM   #15
Pete156
I like to eat!
I bought the Aluminum driveshaft off Stockysnail about 4-5 years ago. It does not produce vibration but provides a louder experience that appears/feels like it's putting my fi power to the wheels faster and more directly. Im also running the Perrin shifter bushing along with the Whiteline. I'm certain it is louder than the CF version and holding up well.
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
stockysnail (05-17-2018)
Old 02-24-2019, 06:10 PM   #16
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Originally Posted by stockysnail View Post
I no longer have it as I thought the TRD short shifter mixed with it was the issue for why the short shifter wasn't working properly. I took it off and sold it. The issue ended up being the trans bushings. Ended up selling the TRD short shifter too. Definitely don't recommend the short shifter. I haven't gotten around to buying another drive shaft. It's a cool mod. Makes the revs slightly free-er. Makes a cool noise like a supercharger almost since the aluminum is hollow and picks up some vibration. Is it worth the $, I'm not sure, but I enjoyed it and would buy it again, especially if I can find a used one or there's a sale. It's fairly simple to install.
Do you know exactly what was interfering with the TRD shifter? I have that installed and was thinking about getting a one piece shaft. I was checking the current clearances. Theres a good half inch of space from the drive shaft to the bottom of the shift lever pivot. Less at where the shifter shaft crosses over the ujoint yoke.
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 02-24-2019, 06:33 PM   #17
Turbo
Drives: FR-S Turbo
Originally Posted by Decay107 View Post
Many of us have swapped out to the STi mounts (NOT solid) and seen a huge improvement.
Do you have a good source for these? Are they cost effective?
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
funwheeldrive (03-01-2019)
Old 02-24-2019, 07:14 PM   #18
Trust86
Drives: 2016 Halo FRS
I had a one piece aluminum driveshaft with kartboy short shifter. The shift “fork” was hitting the u joint. I just ended up grinding down the fork a little bit where it was hitting and never hit again.
Trust86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Trust86 For This Useful Post:
bmacfrs (02-24-2019), q335r49 (10-17-2019)
Old 02-05-2020, 12:18 AM   #19
DreamSpeedBRZ
Drives: 2017 86
Did you have any clearance issues with the aluminum driveshaft and perrin shifter bushing? I saw someone said that the bushing caused contact on the larger diameter DS. I just got an aluminum DS that I'm going to install but want to buy the perrin bushing to install at the same time since it sounds like it will be easier.
DreamSpeedBRZ is offline   Reply With Quote
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 08:53 PM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 02:48 PM
GFB 3-Piece lightweight aluminum pulley kit Touge Factory Engine, Exhaust, Transmission 60 06-03-2013 02:52 PM
KARTBOY Lightweight Aluminum Crankshaft Pulley! RallySport Direct Engine, Exhaust, Bolt-Ons 0 10-29-2012 03:55 PM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 02:40 PM
