Old 02-22-2019, 07:50 PM   #1
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Thumbs down Failure After J02 Recall - Discussion Threads
I see only frs / Toyota cars as having issues after recall
mswbrz is offline   Reply With Quote
Old 02-22-2019, 11:27 PM   #2
DarkSideFRS
Drives: 2013 pearl white FR-S
Should list dealerships that did the work as well so that everyone will steer clear of them
DarkSideFRS is offline   Reply With Quote
The Following 7 Users Say Thank You to DarkSideFRS For This Useful Post:
CY86 (03-03-2019), D_Thissen (02-22-2019), gkubed (09-06-2019), Muaddib (02-23-2019), ORrooster (03-16-2019), Teseo (02-23-2019), Turbo (02-28-2019)
Old 02-22-2019, 11:38 PM   #3
D_Thissen
D_Thissen's Avatar
Originally Posted by CT86 View Post
Vehicle Mileage: 80000km
Vehicle Make: Scion
Mileage After Recall Performed: <120km
Symptom(s): Brief high pitched sound on cold starts
Failure: Knocking and power loss, engine shut off on the road
State:ON
Dealership Offering Repair: under investigation
Which dealership did the work?
The Following User Says Thank You to D_Thissen For This Useful Post:
Turbo (02-28-2019)
Old 02-24-2019, 09:13 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
While I do enjoy the feedback we're sharing, let's try to keep posts sparse to make identifying failures when referencing this thread easier
The Following 6 Users Say Thank You to DarkPira7e For This Useful Post:
ka-t_240 (02-24-2019), Magoo (02-25-2019), Rampage (02-25-2019), RToyo86 (02-26-2019), strat61caster (02-27-2019), Ultramaroon (02-24-2019)
Old 02-26-2019, 08:09 AM   #5
Hypnocracy
Hypnocratic Missionary
Hypnocracy's Avatar
They told me to bring it in so they can check the error code (don’t trust the one at AutoZone) if it is related to the safety recall work...repair is under warranty...if not it is on my dime...
In the customer lounge now...
Update: Oil Control Valve is working correctly now...recommended changing Oil running for five minutes...change oil for second time...checking for debris...wondering if this is sealant related?
Hypnocracy is offline   Reply With Quote
The Following User Says Thank You to Hypnocracy For This Useful Post:
DarkPira7e (02-26-2019)
Old 02-26-2019, 07:25 PM   #6
BlackOptics
Vehicle Mileage: 64,959
Vehicle Make: Scion FR-S 2013
Mileage After Recall Performed:64960 (dealership misread mileage and tried to say 64596 so this may not be accurate.)
Symptom(s): Engine knocking CEL and Trac lights on after less than two days of driving and less than 100 miles. Happened while in traffic.
Failure: No catastrophic, but hard for engine to turn over, and dealer saying to replace the entire engine. Scaring on camshafts, cam tower, and damaged rod bearings.
State: Vancouver, Washington, USA
Dealership Offering Repair: McCords Vancouver Toyota.
I would also like to add that they refused to check the source of the cause after only checking to see if they installed the valve springs correctly, and blamed it on the oil filter and/or engine abuse.
Edit: As of now I've told Toyota to shove it as they want to charge 8k to drop a used engine from LKQ into my car, and bought directly from LKQ for the same engine they tried selling me, but for 1k less than Toyota's asking price, and took it to a trusted mechanic with 35 years experience. I would tell anyone in my area to stay clear of that dealership, and to not get the recall done on yours. From what I've seen it is more of a risk to your car than leaving them in.
BlackOptics is offline   Reply With Quote
The Following User Says Thank You to BlackOptics For This Useful Post:
phm14 (06-08-2021)
Old 02-26-2019, 08:41 PM   #7
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
If anyone has this type of failure (ie; knocking, bearing failure) after the recall insist that the dealer who did the repair pull the oil pan and inspect the oil pickup in your presence. Also have them use a boroscope to look inside the pickup. These types of failures occur when they let old sealant & debris fall into the engine during the recall. It plugs the oil pickup and oil starves the engine. It's a dealership workmanship issue.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 7 Users Say Thank You to Opie For This Useful Post:
humfrz (02-27-2019), ka-t_240 (02-27-2019), Magoo (02-27-2019), N234 (02-28-2019), NoHaveMSG (02-26-2019), phm14 (06-08-2021), wparsons (02-28-2019)
Old 02-26-2019, 09:32 PM   #8
BlackOptics
Originally Posted by ka-t_240 View Post
Did you call Toyota Corporation? Seems like something they should pic up the bill for. If you havent already started work, I'd hold off until speaking to them. Or ask your dealership to speak directly to their regional rep.
Yeah, and Corporate is backing them, refusing to pay for anything.
Old 02-26-2019, 09:54 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It may be worthless but it is something. I would say they failed. This thread makes me not want to do the recall.
If the manufacturer has failed or is unable to remedy this safety recall for your vehicle in a timely manner,
please contact the NHTSA Vehicle Safety Hotline at: 1-888-327-4236 or TTY: 1-800-424-9153 or file an online complaint with NHTSA.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (02-26-2019), DarkPira7e (02-26-2019), Exrald (03-18-2019), phm14 (06-08-2021), Teseo (02-27-2019)
Old 02-27-2019, 02:52 PM   #10
Ichima
Drives: 13' Lightning Red Brz
94k miles
Driven 300 miles since the recall. At idle when warm slow and loud knocks. When driving fast loud ticks. Dealer is stating it could be the direct injectors. Bringing it in next thursday because they told me they can’t squeeze my car in for repair or to be looked at. Hopefully nothing happens from now until then because it’s my only car to get to work and back everyday.
Ichima is offline   Reply With Quote
Old 02-27-2019, 03:28 PM   #11
ka-t_240
Originally Posted by Ichima View Post
94k miles
Any chance you can update post to follow the template in original post, then update you post with any new info as you hear from dealer?
Please post a video if you can in, if its making a knocking noise, you're best to not drive it.
ka-t_240 is offline   Reply With Quote
The Following 3 Users Say Thank You to ka-t_240 For This Useful Post:
DarkPira7e (02-27-2019), JohnJuan (03-01-2019), Magoo (02-27-2019)
Old 02-27-2019, 04:37 PM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Anyone getting shit fro a dealership or from corporate should be pointed toward this thread and the other compilation one.
There is IMO more than enough proof that something dealing with the recall procedure is making engines spin bearings.
The Following 4 Users Say Thank You to x808drifter For This Useful Post:
CT86 (02-27-2019), D_Thissen (02-27-2019), Teseo (02-27-2019), wparsons (02-28-2019)
Old 02-27-2019, 05:36 PM   #13
steve99
Drives: FT86
One possible explainarion for the spun bearings would be small bits of engine case sealant may be getting into engine as they are pullng it apart, or cleaming off the sealant from reused components. Its also possible that excess sealant is being applied to components during re assembly or the sealant is applied incorrectly or in incorrect areas. This sealand then gets into oil supply galeries and blocks or partialy blocks oil supply to bearings or other components resulting in engine failures.
The Following 7 Users Say Thank You to steve99 For This Useful Post:
caus (03-15-2019), CT86 (02-27-2019), D_Thissen (02-27-2019), MasonL1997 (02-28-2019), N234 (02-28-2019), phm14 (06-08-2021), Teseo (02-27-2019)
Old 02-27-2019, 06:20 PM   #14
Decep
Drives: 2013 FR-S Series 10
Definitely sounds plausible. Is this how most boxer engines are assembled, with friggin sealant instead of a traditional gasket? What benefit is there to sealant over gasket?
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
