Old 02-22-2019, 02:09 AM   #15
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Originally Posted by btan219 View Post
the dealership was able to replace it with no cost. i specifically requested to have all lugs torqued at the recommended 90lbs. Today was the first time since then I worked on my tires and I guess they over torqued some of them, again! This is why I hate going to the dealership if I can do things on my own. But it looks like replacing wheel studs isn't something I can do without buying extra tools. I'm going to try to find a reputable shop in my Orlando area to get this resolved and bring my own studs and lugs.
Any tire shop can do that. No need for dealership.
Yes, you can learn to do all the work yourself. Google and YouTube are your friends.
Buying tools is the equal to the amount you'll pay for someone to do it.
Old 02-22-2019, 10:15 AM   #16
GrantedTaken
If you want to work on cars you need to invest in tools. That's how it works. Perfectly fine bring it to a shop.
GrantedTaken is offline   Reply With Quote
Old 02-22-2019, 11:57 AM   #17
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by EndlessAzure View Post
It's actually very easy to do in a garage with a basic tool kit.
All you world need to supplement it with is a universal ball joint separator ($20 from harbor freight to pull and help seat the stud), some washers, and an open ended lug nut
I know from experience
If you flip the tool around, you can use it to install the studs too. I did on all of mine.
I LIKE TIRES!
Old 02-22-2019, 02:46 PM   #18
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
First, invest in a torque wrench if you plan on taking off your wheels. The stock wheel studs aren't the greatest. From what you've experienced, it sounds like one of your lug nuts was over-torqued which caused it to strip and why you had so much trouble getting it off. The damage was already done when it was over-torqued, breaking it off was just the result of that. A breaker bar would have given you the same result. I had the same happen on a few of mine after a shop rotated my tires. I went ahead and replaced ALL of my studs, got new lug nuts, and won't let a shop near my wheels anymore. Problem solved! Torque for the lug nuts is 89 ft.-lbs., btw.
Beachin86 is offline   Reply With Quote
Old 02-23-2019, 09:36 AM   #19
GrantedTaken
What is the ball joint tool for?
I think I hammered my broken one out,
and then used washers/nut to install the new one.
How did you use a ball joint tool in this repair?
Old 02-23-2019, 11:07 AM   #20
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Your probably thinking of the ball joint removal fork type tool. He is probably talking about a ball joint press tool.
[ame]https://m.youtube.com/watch?v=DXWxgET4Sd8[/ame]
GrantedTaken (02-23-2019)
Old 02-23-2019, 12:09 PM   #21
darkbluemn
Drives: Brz
Stock stud is easy job, just use hammer to take it off and put new stud in, any shop can do it within 1 hour labor.
darkbluemn is offline   Reply With Quote
Old 02-23-2019, 12:31 PM   #22
soundman98
ProCrastinationConsultant
soundman98's Avatar
I'd suggest you take your car into a shop and have them remove all the lug nuts and inspect the wheel studs (the "bolts" that the lug nuts screw on to).
Replace any stripped wheel studs or lug nuts.
I'd suggest you use this type of lug wrench to take off and put on lug nuts. This way you will get even torque applied to the nuts and studs.
more along the same lines, many places offer collapsible versions-- one of the first things i do with any car is put either a 4-cross or a collapsible version in the trunk.
my family once had a vacation where we changed 10 flat tires(we learned about dry rot that trip). i don't plan to use the oem lug wrench ever anymore.
humfrz (02-23-2019)
Old 02-23-2019, 02:00 PM   #23
GrantedTaken
I was worried about bashing at the hub, but I think the wheel stud remnant came out with minimal bashing from the BFH. Almost tapping. No press tool needed.
Stripped tail light screw Jajanken86 Issues | Warranty | Recalls / TSB 9 12-11-2017 10:55 PM
Screw in RS-4 (relatively new tire) CB750F Tracking / Autocross / HPDE / Drifting 4 11-24-2017 04:27 PM
Cost to replace pads/rotors on AP Racing BBK c8Face Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 05-02-2016 10:35 PM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
Screw / Nail in tire kpamir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-03-2015 12:20 AM
