| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
[insert cool phrase here]
Drives: BRZ Premium
Yes, you can learn to do all the work yourself. Google and YouTube are your friends. Buying tools is the equal to the amount you'll pay for someone to do it.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#16 |
If you want to work on cars you need to invest in tools. That's how it works. Perfectly fine bring it to a shop.
#17 | |
Country Boy 4 Life
I LIKE TIRES! |
#18 |
Drives: FR-S 10 Series
First, invest in a torque wrench if you plan on taking off your wheels. The stock wheel studs aren't the greatest. From what you've experienced, it sounds like one of your lug nuts was over-torqued which caused it to strip and why you had so much trouble getting it off. The damage was already done when it was over-torqued, breaking it off was just the result of that. A breaker bar would have given you the same result. I had the same happen on a few of mine after a shop rotated my tires. I went ahead and replaced ALL of my studs, got new lug nuts, and won't let a shop near my wheels anymore. Problem solved! Torque for the lug nuts is 89 ft.-lbs., btw.
#19 |
What is the ball joint tool for?
I think I hammered my broken one out, and then used washers/nut to install the new one. How did you use a ball joint tool in this repair? |
#20 | |
Famous Potatoes
Drives: '15 ultramarine
[ame]https://m.youtube.com/watch?v=DXWxgET4Sd8[/ame] Last edited by Sapphireho; 02-23-2019 at 12:22 PM. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | GrantedTaken (02-23-2019) |
#21 |
Drives: Brz
Stock stud is easy job, just use hammer to take it off and put new stud in, any shop can do it within 1 hour labor.
#22 | |
ProCrastinationConsultant
my family once had a vacation where we changed 10 flat tires(we learned about dry rot that trip). i don't plan to use the oem lug wrench ever anymore.
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (02-23-2019) |
#23 |
I was worried about bashing at the hub, but I think the wheel stud remnant came out with minimal bashing from the BFH. Almost tapping. No press tool needed.
| Stripped tail light screw | Jajanken86 | Issues | Warranty | Recalls / TSB | 9 | 12-11-2017 11:55 PM |
| Screw in RS-4 (relatively new tire) | CB750F | Tracking / Autocross / HPDE / Drifting | 4 | 11-24-2017 05:27 PM |
| Cost to replace pads/rotors on AP Racing BBK | c8Face | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 05-02-2016 11:35 PM |
| Replace Only 1 Tire? / Spare Tire Question | chermo12 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-28-2015 02:44 PM |
| Screw / Nail in tire | kpamir | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 07-03-2015 01:20 AM |
