Old 02-09-2019, 02:46 AM   #113
Originally Posted by sohcanddohc View Post
So I went and took a look at my engine today...broken valve spring, bent valve, broken valve guide, and missing valve spring retainer. They are still waiting on the replacement engine. I am currently waiting to see how “complete” the complete engine replacement is.
How many miles on it? How long was it running on 3 cyls?
Tcoat (02-09-2019)
Old 02-09-2019, 09:33 AM   #114
sohcanddohc
Drives: 18 Civic Type R
75k, it had 250 miles on it when we got it. It’s my wife’s DD and I might have used it for cone dodging from time to time.
My wife hit a Coyote December 13th, the insurance company picked Up the car December 21st (this was the last time I drove the car). The engine never had any signs of internal damage. Never had a CEL, it’s really been a great car. The body shop at the dealership did the repairs from the Coyote impact. Once they were done they took it to the service department. Everyone involved says it ran just fine. They said it must have happened when they turned it off in the service bay....at the end of the day I am glad they are fixing it no questions asked.
2018 CTR
2013 FR-S
sohcanddohc is offline   Reply With Quote
The Following User Says Thank You to sohcanddohc For This Useful Post:
Ultramaroon (02-09-2019)
Old 02-09-2019, 01:26 PM   #115
Edge case for sure. Couldn't have happened in a better place.
Old 02-09-2019, 09:29 PM   #116
kiwiasian
Drives: GT86
Recall done last Thursday, 26 parts replaced under recall including some 2017 revision parts (nice), and a 2017+ TOB along with fresh gearbox oil. Pretty happy with everything, especially since cars done 113k kilometers.
kiwiasian is offline   Reply With Quote
Old 02-13-2019, 03:21 PM   #117
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
I'm having my dealer do my spark plugs and most of the 60k maintenance. They aren't going to charge me for the spark plug labor and were willing to use the motul gear oil I had purchased to go ahead and replace those fluids.
Going to save me around ~$400!
demasrv is offline   Reply With Quote
Old 02-13-2019, 03:35 PM   #118
DarkSideFRS
Drives: 2013 pearl white FR-S
why are they even changing out the tranny fluid? it's not part of the recall
DarkSideFRS is offline   Reply With Quote
Old 02-18-2019, 08:57 PM   #119
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
I'm making a list to give to the dealer as I'll be out of town while the work is getting done so they'll have the car for over a week.
Spark Plugs, Throw-out Bearing / Clutch, Brake Fluid (never did this myself, still running stock), Inspect & Clean Parking break and Suspension, Transmission gear oil, and Motor mounts.
Am I taking this way too far and should just stick to plugs TOB?
slizoth is offline   Reply With Quote
Old 02-19-2019, 03:43 PM   #120
ka-t_240
Nope. I am sure the dealer would be happy to any other maintenance items you request while the car is there. It give them more "work". Just know that the stuff like looking at ebrake and flushing brake fluid are all on you. I don't see any need to clean the braking break, but if you feel its not working correctly it could be in need of adjustments.
The plugs and clutch you will get a big savings on as its minimal extra labor.
ka-t_240 is offline   Reply With Quote
Old 02-19-2019, 03:49 PM   #121
slizoth
slizoth's Avatar
I'm pulling the rest from the shop manual / maintenance plan (mostly) but I'm thinking I'll just do a thorough inspection before wildly tacking stuff on. As a point of clarification, what's the difference between replacing the throw-out bearing and the entire clutch? I've not replaced either before on any automobile.
Old 02-19-2019, 03:58 PM   #122
The TOB is just a couple of clips and a $25 - $40 part (depending where you buy it). The clutch is ...well... all the clutch. If the TOB hasn't gone too bad then the clutch will be fine. If the TOB melted away to nothing then the clutch and flywheel will be toast.
slizoth (02-19-2019)
Old 02-19-2019, 04:04 PM   #123
ka-t_240
You typically replace both together. The TOB on these cars is bad and fails long before the clutch needs replacement. If your clutch is good, you can probably get away with doing just a TOB, however, the cost of a clutch now is lots less than one in the future as your engine is already out.
The Following User Says Thank You to ka-t_240 For This Useful Post:
Old 02-19-2019, 04:28 PM   #124
DarkSideFRS
is the transmission fluid drained if the TOB is replaced? I doubt it is, but just making sure
Old 02-19-2019, 04:37 PM   #125
ka-t_240
During this recall, it would not be. The engine is removed.
Typically, it would likely be drained during a clutch or TOB removal as you would remove the transmission.
Old 02-19-2019, 05:11 PM   #126
DarkSideFRS
since the motor is removed, the TOB is visible and easily accessible. So, transmission fluid is drained if TOB is replaced?
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 06:21 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
valve spring recall-engine oil leak TYinhouse Issues | Warranty | Recalls / TSB 13 01-17-2019 11:09 AM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 08:44 PM
