Northern California NorCal
Old 02-07-2019, 08:08 PM   #29
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Originally Posted by ndsleep612 View Post
Did the dealer mention if there is a "break in" period with the new spring valves?
Mine didn't.
I will find out this weekend with some autocross.
tigermack is offline   Reply With Quote
Old 02-08-2019, 02:49 PM   #30
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
They told me the break in required is about 150 miles.
I had a track day at Thunderhill the next day after I got my car back which is about 180 miles from where I live. I decided not to go, though, since my car had just been so majorly disassembled. Thought I'd play it safe for a little while and make sure things were copacetic.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
Old 02-08-2019, 08:07 PM   #31
ndsleep612
Drives: Thee Argento Cricket
Besides the valve springs, does anyone have a list of what maintenance parts they had the dealer do while the engine was dropped?
ndsleep612 is offline   Reply With Quote
Old 02-08-2019, 09:18 PM   #32
justint5387
Drives: 4 wheels
Originally Posted by tigermack View Post
Got my car back from Fremont, charged me $100 for installing the clutch/cover/TOB, changed out my spark plugs, too. I got the parts ahead of time via a buddy who works at Toyota.
justint5387 is offline   Reply With Quote
Old 02-12-2019, 12:42 AM   #33
AngelGT86Racer
The recall procedure actually includes quite a few maintenance items in addition to the valve springs.
Valve cover gaskets
DFI pump hard line
Exh manifold to head nuts
Cowl brace bolts/nuts(for some inexplicable reason)
Spark plug tube gaskets
Crank shaft oil seal
Exh manifold to head gaskets
Oil drain plug gasket
Crank shaft pulley o-ring
Timing cover o-rings
Dipstick o-ring
Chain tensioner o-ring
DFI pump o-ring
Fuel injector seals
Fuel injector grommet
Fuel injector o-rings
A/C discharge hose o-ring
Throttle body gasket
Radiator drain seal
For auto trans you get everything mentioned above PLUS:
Front sway bar endlinks(for some inexplicable reason)
Vacuum pump o-ring
Don't ask me where I got that list.
Old 02-16-2019, 01:08 PM   #34
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Originally Posted by 408brz View Post
I booked Stevens Creek Subaru for May 29th. Earliest they had I was told.
Wow — end of May. Guess I should wander over there and make an appointment. Looking forward to hearing feedback on how Stevens Creek Subaru does with this recall job.
PWBRZ is offline   Reply With Quote
Old 02-17-2019, 07:46 PM   #35
Magoo
Magoo's Avatar
Drives: 2013 Scion FRS
Originally Posted by Magoo View Post
My car is scheduled to have the work done on the 2nd of Feb. at Toyota of Santa Cruz. Not looking forward to driving a rental, but what can you do?
It took a week and everything is good to go.
Magoo is offline   Reply With Quote
Old 02-18-2019, 12:39 PM   #36
justint5387
Drives: 4 wheels
Try Fremont Subaru
Old 02-19-2019, 11:15 AM   #37
sfruski
Drives: Many
I want to San Francisco Toyota, Geary location.
The car has a JRSC and other bits. Around $800 was the charge for doing it with the supercharger on the car.
The work was done very well. Had the car back in three days.
sfruski is offline   Reply With Quote
Old 02-19-2019, 06:55 PM   #38
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
i wish i could take my brz to a toyota dealership, they seem to have there shot together
Bones36 is offline   Reply With Quote
Old 02-19-2019, 07:45 PM   #39
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Avoid Stockton Toyota. So far a local has got a new short block and now his radiator broke and they found a pen in the system. Yes, a pen as in a writing instrument. Their initial response is that they wont cover claiming it wasn't them lol
Old 02-19-2019, 10:45 PM   #40
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Why'd you wait for 3+ months when Fremont can do it within a week? lol
Old 02-21-2019, 01:06 PM   #41
WelshJ
Drives: FRS
I got mine done at Hendricks Toyota in Merriam KS (KC) After one false start to get a gasket, they took a week. Nice loaner. Kept me well informed. I have put about 100 miles since I got it back. No leaks and so far no problems.
WelshJ is offline   Reply With Quote
Old 02-21-2019, 01:11 PM   #42
finch1750
finch1750's Avatar
This is the Norcal version of this thread lol
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 12:10 AM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
Valve Spring Recall Dealers AsianStyle Mid-Atlantic 20 05-04-2019 02:43 PM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 08:44 PM
