Old 02-05-2019, 07:08 PM   #141
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Originally Posted by Jesse36m3 View Post
Are there any extra sets available, or are these made to order?
Thanks.
Originally Posted by HachirocksU View Post
Part of a back-order batch
We have another large batch order incoming in April. We recommend just jumping into the backorder list as soon as you can. Thanks!
CounterSpace Garage is offline   Reply With Quote
Old 02-11-2019, 02:38 PM   #142
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Just arrived 5 minutes ago!
I know what I'm doing tonight...
spitsnaugle is offline   Reply With Quote
The Following User Says Thank You to spitsnaugle For This Useful Post:
CounterSpace Garage (02-13-2019)
Old 02-12-2019, 07:55 AM   #143
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
got mine too and put 1 in... i stripped out the allen on my end link and hand to use an impact and vice grips to get it off.
one odd thing i didnt see in there was recommended camber. im thinking of 2 square since i DD my car too
The Following User Says Thank You to Breadman For This Useful Post:
Old 02-13-2019, 05:48 PM   #144
CounterSpace Garage
Generally speaking, the recommended alignment is specific to each individual. We slammed and lifted the kit + tossed in a plethora of variables for settings. At the end of the day, we're probably racers are heart so we want to stick to our performance setup.
Depending on DD settings, you'll want a little less camber if you're just running strictly street miles.
Old 02-17-2019, 01:41 PM   #145
Breadman
Breadman's Avatar
so ive been driving on mine for 3 days more or less and will say the difference between stock pp and theres are night and day. i went with the recommended drop and 8/11 clicks and on smooth roads they hook so well. i did eventually go 4 clicks softer all around because when i got to bad roads with ruts it would track the rut really badly, and when i hit big potholes i could feel my back lift. im sure a -1/16th or -1/8th toe in the back will help keep the back a bit more stable.
right now im eyeballed -2.5 front -2 back but will get a real alignment friday. ill probably go a bit stiffer once i get use to them/have a real alignment. cant wait to put my conti summers on and autocross this
Old 02-17-2019, 11:22 PM   #146
Mr_Eyo
Drives: 2017 Toyota 86
So 15 clicks in back? How does it sound?
Mr_Eyo is offline   Reply With Quote
Old 02-18-2019, 08:32 AM   #147
Breadman
Breadman's Avatar
Sounds like my snow tires picking up cinderss and throwing them everywhere. Which is not the answer you wanted to hear
Old 02-18-2019, 01:07 PM   #148
spitsnaugle
I've been tinkering with my camber over the past couple days, I'm just curious, do the hash marks on the camber plates relate to a certain degree of camber? I've just been measuring at the wheel but not paying attention to the marks.
On Camber thoughts- I'm around 3˚ front and 2.5˚ rear right now, whats the chances of needing toe arms? (I'll probably go to 3.25 and 2.75 eventually, slowly making adjustments here and there)
Old 02-18-2019, 01:28 PM   #149
FirstWinter
Drives: Car
It's a rough gauge of camber and makes it easier to reference when adjusting but varies. I wouldn't rely on it solely but next time you get an alignment you can ask them to mark it down on some tape on top of it showing the range of degrees.
No, you won't need toe arms unless you're running something crazy. I've had more camber than you and the stock toe arms were more than enough.
FirstWinter is offline   Reply With Quote
Old 02-18-2019, 01:48 PM   #150
spitsnaugle
I guess while I'm here, is this amount of leftover welding slag/splatter normal?
Not a terribly big deal, but I wouldn't want anything to cause premature corrosion...
Old 02-18-2019, 03:25 PM   #151
FirstWinter
Drives: Car
Yeah, it's fine.
Old 02-20-2019, 06:28 PM   #152
FRStevan
Drives: 2013 Scion FRS
Finally got em!
FRStevan is offline   Reply With Quote
Old 02-21-2019, 12:25 AM   #153
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
Originally Posted by FRStevan View Post
Finally got em!
Sexy! I'm GREEN with envy! Congrats!
BA9092 is offline   Reply With Quote
The Following User Says Thank You to BA9092 For This Useful Post:
FRStevan (02-21-2019)
Old 02-21-2019, 07:20 PM   #154
CounterSpace Garage
Some updates for latest incoming batch - ETA is end of March/beginning of April.
Recommended adjustments are in the manual. This will give you a fairly nominal setup and you can adjust from there.
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 01:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 06:27 PM
TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day CounterSpace Garage Groupbuys 47 02-18-2016 12:33 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
