Old 10-31-2016, 05:45 PM   #379
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
totaled the car a few weeks ago. interior is all gone.
all i have left are wheels and coilovers. i also have the BMW cupholders if anyone wants to do them.
Jive Turkey is offline   Reply With Quote
Old 12-21-2016, 02:30 AM   #380
Brayden_23
Drives: Asphalt 2015 FRS
Dammit.
Just read through this entire thread, getting more and more excited to see where the build was going. This came to such an abrupt halt.
Sorry about your car, but thank you for the inspiration you have provided to myself and others.
Brayden_23 is offline   Reply With Quote
The Following User Says Thank You to Brayden_23 For This Useful Post:
Jive Turkey (12-22-2016)
Old 12-21-2016, 10:22 AM   #381
FujiwaraTofu86
Drives: gt86
wow WISH I have the time and money to do this, very impressive
FujiwaraTofu86 is offline   Reply With Quote
The Following User Says Thank You to FujiwaraTofu86 For This Useful Post:
Old 08-06-2017, 10:27 PM   #382
Pho20
Drives: 2013 Subaru BRZ
Originally Posted by Jive Turkey View Post
starting to clean it up. went with the STi blue edition button, picked it up at the local dealership and then painted the ring gloss black. now i need to figure out what to do with the shift knob, copper is no longer appealing to me.
interior before:
Button:
Before/After
i'm leaning towards some sort of shade of black, but honestly i don't know for sure, but the copper has to go.
How did you remove the chrome ring I just bought that switch and want to do the same thing but don't wanna pry on it
Pho20 is offline   Reply With Quote
Old 09-29-2017, 02:34 AM   #383
Jive Turkey
the tuna, no crust.
it just pops off. its held in in three places, just use a thin flathead.
Old 09-07-2018, 12:28 AM   #384
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
-ivan
Can I see a close up of the seat heater buttons? did you encounter and issues putting them in that location? I am putting my buttons there as I have a console plaque in there currently.
Thanks,
MemphisR
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 10-10-2018, 01:26 AM   #385
Jive Turkey
the tuna, no crust.
don't have a close up. I had zero issues. be careful not to cut hole too big for them if you place them there. You don't want them to be loose.
The Following User Says Thank You to Jive Turkey For This Useful Post:
MemphisR (10-10-2018)
Old 01-08-2019, 09:28 PM   #386
Crystalwhitebrzsti
Drives: Crystal white brz
I may have missed it, but how did you make the gauge pods? Thanks for all the other things you have done! Now my car won’t feel so cheap thanks to you!
Crystalwhitebrzsti is offline   Reply With Quote
Old 02-17-2019, 01:17 PM   #387
Jive Turkey
the tuna, no crust.
bought a spare cluster cover for 40$ and some PVC pipes from Home depot that fit gauges.
Cut pipes into like 3 inch "pods" and cut two circles in the cluster where i wanted gauges to go. glued the PVC pipe and then filled with some body filler, sanded and painted. Its pretty simple once you get to it. hope this helps.
Old 02-18-2019, 09:59 AM   #388
Crystalwhitebrzsti
Yes sir!! Thanks a bunch!
Old 05-18-2019, 11:39 PM   #389
CornfedCatfish
Drives: 2015 White BRZ Premium
Dude those pull straps are mad cool!!!!!!!
Now you got me thinking!
CornfedCatfish is offline   Reply With Quote
Old 05-20-2019, 04:46 AM   #390
slifer
Drives: 2019 Subaru BRZ
Hi question about the hvac surround pillars (silver trim pieces) How did you wrap it and what is the process of removing it?
slifer is offline   Reply With Quote
Old 05-29-2019, 01:25 PM   #391
MaverickMonk
Drives: 13 BRZ Limited
Not OP but I just did mine in alcantara.
  1. Remove the center console (you can look up how to do this on youtube).You might be able to get away with just loosening it instead of fully removing, but I was installing an armrest at the same time.
  2. Remove the two plastic trim pieces below the knee pads on the left and right sides of the tunnel. They just pull off.
  3. Reach up through the newly created hole and push out the USB/aux port from the back, disconnect the wire. Then pop out the center coin catch/push to start plate from behind. Again disconnect any wires.
  4. Remove the single phillips head screw holding each kneepad on.
  5. Pull the whole assy, (kneepad + silver trim) towards the rear of the car, it slots into the dash for retention.
  6. Remove the single phillips head screw holding the silver trim piece to the kneepad. Hold the kneepad still and press on the silver trim to remove (for directionality, if the trim were still installed you'd be pushing "into" the dash.
Sorry for the awful wording. It's way easier to show than to tell. Once you've done it once the clips will be pretty intuitive.
MaverickMonk is offline   Reply With Quote
DCW Carbon Fiber interior items! Center console Plaques / Interior panels doggy Interior Parts (Incl. Lighting) 143 10-11-2013 12:17 PM
LED interior conversion kits (interior), USA stock & warranty WTF Interior Parts (Incl. Lighting) 0 05-22-2013 11:17 PM
Video: Toyota FT-86 II Concept Design Explained by "Dezi" Nagaya (Design Manager) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 58 04-11-2011 10:03 PM
