Old 08-07-2017, 12:47 PM   #43
SoNotCool
SoNotCool's Avatar
Drives: 2013 FRS
Originally Posted by TeutonicShift89 View Post
Found a few more awesome photos posted in November of a rally GT86 driver's car. You can read about his story here.
He's running a 205/45/17 for tarmac. I also like having the mud flaps sitting further outboard and lower than the rally armor versions. White also seems to be ideal for the rally look.
Can anyone tell about how much extra height this car's running over stock front and back? The front seems to be the most different from stock, while the back appears to be almost the same as stock. Is it just an optical illusion or do other people see what I'm seeing?
I looked at doing a 1'' lift all around but based on the one photo I've ever seen of this done on stock wheel/tires it looks too high--and much higher than what you see above. The guy I found on instagram used the Subtle Solutions 1'' lift, and doesn't appear to have kept in on very long:
i neeed those wheels in my life lol!
SoNotCool is offline   Reply With Quote
The Following User Says Thank You to SoNotCool For This Useful Post:
TeutonicShift89 (05-08-2018)
Old 03-15-2018, 02:04 PM   #44
Racecomp Engineering
Bump.
We're considering the idea of developing a RCE Rally-x spring set.
Let us know your thoughts.
http://www.ft86club.com/forums/showthread.php?t=125863
And to contribute to this thread:
Also, we now carry BRAID wheels if you're looking for strong wheels in 16 inch (possibly 15 inch) sizes that clear OEM brakes.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
bcj (03-15-2018), Chimera (03-15-2018), TeutonicShift89 (05-08-2018)
Old 03-24-2018, 10:00 PM   #45
subtledriver
Drives: RallyX BRZ
I hope my photos worked.
IG: @SubtleDriver
subtledriver is offline   Reply With Quote
The Following 5 Users Say Thank You to subtledriver For This Useful Post:
bcj (03-25-2018), BigFatFlip (03-25-2018), churchx (11-22-2019), Racecomp Engineering (05-09-2018), TeutonicShift89 (05-08-2018)
Old 08-14-2018, 09:51 PM   #46
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
How bout a full coilovers set? I need a reasonable priced coikover set so I can make the jump to stage rally next year.
Instagram: @Pocock_Racing
Bump.
- Andrew
RazBRZ is offline   Reply With Quote
The Following User Says Thank You to RazBRZ For This Useful Post:
bcj (08-15-2018)
Old 09-14-2018, 02:52 AM   #47
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Originally Posted by DustinS View Post
1" Lift with 215/65/16 is enough to clear fender liners. Your only issues becomes the frame extension at the back of the fender well that pushes the fender liner out a tad too far. It will rub, but not really bad enough to really worry about it. I just ignored it while I had mine lifted.
Will the Anderson 2" lift kit, 16x7 Sparco Terra's and BFGoodrich T/A KO2 215/65R16 work with stock suspension? Or is there other modification that has to be done?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is online now   Reply With Quote
Old 10-29-2018, 06:32 PM   #48
beanswv17
Starting to get my BRZ setup to have a more rallyish look, mods are mostly cosmetic for now but am hoping to get a set of RCE's Rally-x springs if they ever do a run, and maybe an ADF lift down the line. Right now I have a set of Hella 500ff and 500 Amber driving lights, Rally Armor Mudflaps, and 205/55R-16 Blizzaks mounted on Sparco Terras.
Here's a few pics I took today after doing some snonuts:
beanswv17 is offline   Reply With Quote
The Following 8 Users Say Thank You to beanswv17 For This Useful Post:
bcj (10-30-2018), BigFatFlip (10-30-2018), BigTuna (02-28-2019), BWilky (10-30-2018), Racecomp Engineering (12-19-2018), Shark_Bait88 (06-27-2019), TeutonicShift89 (11-07-2018), yurikaze (10-29-2018)
Old 10-30-2018, 12:05 PM   #49
BWilky
BWilky's Avatar
Drives: 2016 Subaru BRZ WRB
Love it beanswv17!
Where up north are you in NH?
Im in Hooksett and just put my winters on but no snow yet here.
BWilky is offline   Reply With Quote
Old 10-30-2018, 07:54 PM   #50
beanswv17
Originally Posted by BWilky View Post
Love it beanswv17!
Thanks, I'm up near Plymouth.
Old 11-02-2018, 10:08 AM   #51
BWilky
BWilky's Avatar
Ill have to keep an eye out when I head up to Cannon this winter.
Old 11-03-2018, 02:19 PM   #52
DenizS
DenizS's Avatar
Drives: Toyota GT 86 2012
Thank you all for sharing, pictures are fantastic, cars are splendid!
DenizS is offline   Reply With Quote
Old 02-11-2019, 09:27 PM   #53
Antonovich
Drives: '13 BRZ, 04 rust bucket Suburban
So yesterday I've installed Anderson Design & Fab 2-inch spacers and changed the wheels from 225/35R18 to 215/65R16. Took me like 6 hours (mostly because of my own incompetence). And I got...mixed results. First of all it definitely feels more comfortable driving (which is one of the things I was going for), there is minimal rubbing - mostly at full lock. But I also get a strange knocking sound at the front from small bumps. Like metal on metal. I'm thinking it might be the end links because the actual coilovers sitting much lower now, so the end links or sway bar is hitting something. Maybe I'm wrong, but I'd appreciate any feedback on this issue.
Sent from my ONEPLUS A5010 using Tapatalk
Antonovich is offline   Reply With Quote
Old 02-17-2019, 11:58 AM   #54
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
For the rubbing issue I'm pretty sure both @LiftedFRS and @LiftedBRZ on IG mentioned that when they went to that exact lift and tire size they had to trim parts of the underside of the bumpers to keep from rubbing. They also ended up removing the liners altogether.
As far as the metal sounds, I'm not sure. Perhaps check the top hats to make sure everything is tightened? Or check the end links of the suspension? Did you also get LCA's for camber correction in the back or any other supporting mods?
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
Old 02-17-2019, 11:58 AM   #55
TeutonicShift89
Also more pics would be nice
Old 02-17-2019, 01:51 PM   #56
Antonovich
No rubbing in the back that I can see. And there's only 2 spots up front where it's rubbing, that I can see: small spot on the front bottom liner, I think I can get that with a heat gun. Another is the Rally Armor mudflaps, or more specifically, the bottom inside portion of the bracket. I'll definitely do some cutting and grinding.
As far as LCA's in the back, the lift kit I bought came with extra 1-inch spacers for the whole subframe, so I'm not sure LCA's are even necessary. This is what I got: Spacers
The knocking sound, my theory is that because the struts now sit 2 inches lower, the end-links push the sway bar lower and it's making contact with the steering shafts. I've ordered shorter end-links, see if that fixes the problem.
Will take more pics when I install the end-links, do some trimming, and get a wash.
The Following User Says Thank You to Antonovich For This Useful Post:
Spawn_Of_Creation (03-28-2023)
WORLD RALLY BLUE BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 1268 04-11-2023 01:44 PM
Rally GT86 - The Little Car That Could - Lots of rally video and photos! Circuit Motorsports Tracking / Autocross / HPDE / Drifting 48 10-12-2020 03:32 PM
BRZ/FRS VIS Carbon Fiber oem style hood and AMS style trunk. BNIB. js0uth Exterior Parts (Aero, Lighting, Etc.) 76 12-03-2014 04:37 PM
86 Farm Style (Rally Test?) [Video] BenArmstrong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 81 04-10-2014 01:39 AM
Akio Toyoda Drives the 86 Rally Style (Dirt and Snow) nate89 Scion FR-S / Toyota 86 GT86 General Forum 3 02-09-2012 11:22 PM
