Old 02-15-2019, 02:33 PM   #1
bharick
Drives: 2016 Subaru BRZ
Fog Lights only on with out head lights?
Any body done this?
Do a rewire to have only the fog lights on without the head lights having to be on?
Tahnks
bharick is offline   Reply With Quote
Old 02-15-2019, 04:22 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
There's an "always on" module you can buy that's plug-n-play by Diode Dynamics.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-15-2019, 05:04 PM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
IIRC, that's for the boomerangs not the fog lights.
shiumai is offline   Reply With Quote
Old 02-15-2019, 05:17 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Oh ok thanks for the correction.
Current DD: M235i
The Following User Says Thank You to 8RZ For This Useful Post:
shiumai (02-15-2019)
Old 02-15-2019, 07:56 PM   #5
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Carista able to do that?
PetrolioBenzina is offline   Reply With Quote
Old 02-15-2019, 08:47 PM   #6
HaXx
Drives: jrsc_brz
i recently just had a really good experience with a lighting guy on here. his name is HeresMyMind. i bought a set of second hand yellow fog lights from him and after talking to him for a while i found out he does a lot of custom work and wiring/retrofitting, etc. you could reach out to him and he might have a solution for you.
HaXx is offline   Reply With Quote
Old 02-15-2019, 08:55 PM   #7
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
You will need a dedicated switched 12v source so lights will get power only when car is running. You could also buy fog light wiring kit and run it separate from the OEM wiring.
el-guapin is offline   Reply With Quote
Old 02-16-2019, 05:36 AM   #8
Boomerang
86
Boomerang's Avatar
It comes standard with GT86 models in Australia
Old 02-16-2019, 08:48 PM   #9
p1l0t
p1l0t's Avatar
So then it's probably a matter of the right relay part number...
Old 02-17-2019, 12:06 AM   #10
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
This idea keeps coming back... check out the older threads. The important question, rather than how, is... WHY?!?!?
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 02-17-2019, 12:08 AM   #11
p1l0t
p1l0t's Avatar
Headlights make it worse. Foglights make it better. I would love to drive with just the leds and the fogs when it's misty.
Old 02-17-2019, 12:13 AM   #12
MuseChaser
MuseChaser's Avatar
If it's misty, you've got your wipers on. If your wipers are on, you've got your headlights on (at least in my state). Then.. foglights. I can't think of a situation where I'd like my fog lights on but NOT my lo-beams. Hi-beams definitely make things worse, but low beams plus fogs are a winning combination unless you're doing 5 mph. Just my opinion.. and the law where I live.
Old 02-17-2019, 12:15 AM   #13
p1l0t
p1l0t's Avatar
Yeah CT law says headlights on even if it's overcast but the intent behind the law is visibilty. You can be seen just fine without your HIDs.
Old 02-17-2019, 12:28 AM   #14
MuseChaser
MuseChaser's Avatar
Point taken... but try arguing with the FAA about the "intent" behind article 14, part 117. Plus, and in my mind way more importantly, I can see better with my lo-beams and fog-lights on simultaneously. Properly mounted and aimed fog lights help illuminate the lane/road edges/sides and immediate forward path.. say, half a second or so unless you are crawling forward at walking speed... the lo-beams take care of the next second or two forward. Perfect combo. Sure, I could put a rotating beacon on my roof and be seen, but so what.. that hardly matters if I can't see what's in front of me in fog and drive off the road.
No?
F/S 2013 stock tail lights-head lights gsrmn Exterior Parts (Aero, Lighting, Etc.) 4 05-20-2018 01:20 AM
WTB - Buddy Club tail Lights & Winjet Front Head Lights thehube2013brz Want-To-Buy Requests 0 12-22-2015 02:42 PM
WTS OEM Frs Head lights and Tail lights Plaid Exterior Parts (Aero, Lighting, Etc.) 3 06-07-2015 09:42 PM
Selling my new GT86 Head lights and Tail lights diddyv AUSTRALIA 2 06-04-2014 06:36 AM
FS: OEM FR-S head lights with HID and Tail lights chimmy Exterior Parts (Aero, Lighting, Etc.) 7 03-25-2014 08:57 PM
