#15 | |
But that would risk a lawsuit if someone got hurt. Seems they have added more risk then they had just leaving it alone though. There are more reports of dead engines from the recall than there have been of actual spring failures. Although the liability may be offloaded from Subaru to the dealer if the dealer does the recall, the engine dies and they get in a wreck. We all know a bearing doesn’t fail because you replaced the valve springs unless the dealer makes a mistake. I plan to do mine eventually. I talked to a neighbor that had his done and it took them a week. They said it was the first one they have done. So I think I will hold of a few months. |
#16 | |
Drives: BRZ DGM Limited
I am with you and going to wait a bit to see how this all plays out! |
| The Following User Says Thank You to BRZnut For This Useful Post: | tobin (02-21-2019) |
#17 |
Drives: 2013 BRZ 6MT
I’m going to wait as long as possible. Really wish I didn’t have to do it but here in CA it’s mandatory.
![]() Sent from my iPhone using Tapatalk |
#18 |
I have experience with this situation.
I brought my car in for the valve spring recall about a month ago. After the recall work was performed, the #3 rod bearing failed while the service department was doing their test drive. The dealer claims everything went fine with the recall work and that it must have been a random rod bearing failure. They ask Toyota for a replacement short block, which was eventually approved despite the car being 5 months out of the powertrain warranty window. Fast-forward 25 days and the car is ready. The dealer claims Toyota won’t cover the labor for the replacement of the short block. Angry, I call Toyota customer service who promptly refers me back to the dealer. The dealer offers to discount their labor rate slightly but I’m still stuck with a bill for nearly 20% of the value of the car (spark plugs, tob and pressure plate were replaced as well). Granted, it’s a cheap price to pay for a new short block, but sticking the customer with the bill when the failure was almost certainly related to the recall work and the car was still in the dealerships possession is a great way to ensure I don’t shop there in the future. If people are considering have the valve spring recall performed I would strongly recommend discussing with your service advisor which party is financially responsible if another failure occurs as a result the recall work before handing over your keys. Sent from my iPhone using Tapatalk |
#19 | |
The accident would come as a result of the failed engine. Pull the EPS fuse and go for a drive if you want to simulate the experience of not having power steering. I just did this last week and was shocked at how difficult it is. People think of PS as a luxury when it’s nearly mandatory on our car due to the 13:1 ratio. Old cars without PS had ratios to accommodate. Even at a roll this car is super hard to steer. A quick reaction to avoid an accident would be hard especially if you unexpectedly lost it. I agree the chance of failure is low but the chance of an accident if it failed is higher than you would think. |
#20 | |
Valve Spring Recall > Spun Bearing
Man that sucks. I’d collect all the occurrences of bearing failure from this forum and show them you aren’t the only one. Just curious, how many miles are on your car? It’s also interesting to see people register just to report these recall failures. Just think of how many people could be going through this that we don’t know about. I know Tcoat is going to slap my hand for this comment but it’s true. Last edited by ermax; 02-13-2019 at 09:18 AM. |
#21 | |
#22 | |
| The Following 3 Users Say Thank You to ka-t_240 For This Useful Post: |
#23 |
Initial G
Drives: 13 FR-S, 15 BMW 228i
Man this really sucks, Toyota doesn't have techs with experience rebuilding boxer engines. I bet few if any BRZ owners will have their engine fail after this recall, but now we have 3 in one thread.
There was a local in Austin here that had his engine oil overfilled and his crankshaft seal was done improperly, and had to be redone. Hope his engine lasts... I give up on this recall, for now at least, not letting them near my car.
2013 FR-S
2015 BMW 228i |
#24 |
45k miles on the car.
They were non-committal on the mechanism of the rod bearing failure “it’s a known issue with this engine”. Stated that they didn’t believe it could directly attributed to the recall work. I was told multiple times that “Toyota will contact you” so I thought I would have a chance to plead my case with them. When I attempted to contact them I was referred to the PR person at the dealer who gave me back to the service manager. I was hopeful that the labor would be included since the short block was deemed to be covered under the powertrain warranty. At that point though, I just wanted my car back and understood that I was going to be stuck writing a check no matter whether or not Toyota covered the labor. The whole thing left a sour taste in my mouth, but I get that all parties probably share some responsibility in paying for the failure. I drove the car for several years putting some wear on the bearing. Toyota donated a $6800 short block with a one year warranty. The dealership discounted their labor and gave me a rental for a month (but also probably compromised oil flow to the rod bearing in the first place). Sent from my iPhone using Tapatalk |
#25 | |
Drives: Crapcan
Sent from my Moto E (4) Plus using Tapatalk
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | ermax (02-13-2019) |
#26 | |
Also, a short block isn't $6800. Hell even if you paid MSRP it isn't 6800. If I recall MSRP is 2050, I paid $1860 for mine. I would put up a fight on this one. |
| The Following User Says Thank You to ermax For This Useful Post: | Teseo (02-22-2019) |
#27 | |
Drives: Ultramarine
#28 |
Drives: jrsc_brz
I guess this is all a good reason to have as much work done as possible at a reputable tune shop instead of a dealer. I'm not knocking all dealer techs, but I have more confidence tossing my keys to a subie tune shop.
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 10:32 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-09-2019 12:38 AM |
| Valve Spring Recall Dealers | AsianStyle | Mid-Atlantic | 20 | 05-04-2019 03:43 PM |
| FR-S Valve Spring safety recall Ħɞ|| | Hypnocracy | Scion FR-S / Toyota 86 GT86 General Forum | 65 | 02-27-2019 12:53 AM |
| I have the valve spring recall information. | meadowz06 | Issues | Warranty | Recalls / TSB | 24 | 12-23-2018 09:44 PM |
