Old 01-30-2019, 11:08 PM   #8261
jflogerzi
jflogerzi's Avatar
Question about how the sc builds boost. Most people say the heads and rods are most vulnerable when boost is built low and quick. With this sc does it build boost gradually or is more in the middle in the reviews range. Is there any gear and and rpm combo to avoid? Sorry noob here
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 02-03-2019, 12:18 PM   #8262
sqd
sqd's Avatar
Drives: '13 SWP GT86
I would love some clarification on the topic of an aftermarket MAP or MAF - is it needed?
I'm used to older tuner cars which need a bigger MAF or be converted to use a MAP sensor. But I swear I've read it's not a requirement for the Sprintex?
My setup will consist of a S5-210, on straight E85 (not going flex since we have pretty good availability of E85 over here) with a bigger fuel pump and DW 700cc injectors.
This will be tuned on Ecutek. Will my tuner be able to safely tune the car to 250-280 whp on the stock MAP/MAF?
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 02-03-2019, 12:24 PM   #8263
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
1. STOCK map because of airflow instability issues.
2. Stock MAF works just fine with stock intake or compatible intake.
3. STOCK MAP, stock MAF will work fine.
Sent from my HTC6525LVW using Tapatalk
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
The Following User Says Thank You to riboyster For This Useful Post:
sqd (02-04-2019)
Old 02-03-2019, 12:26 PM   #8264
sqd
sqd's Avatar
Originally Posted by riboyster View Post
1. Aftermarket map because of airflow instability issues.
3. Aftermarket MAP, stock MAF.
Ok, thanks for the info! So like a Omni 3-bar MAP should be good then?
IG @squareddesign
Old 02-03-2019, 12:27 PM   #8265
riboyster
riboyster's Avatar
Boost is instantaneous, how much of it you get depends on rpm.
Avoid low rpm high load.
My motor loves to knock in the 3000s at 0.3 - 0.45 g/rev (medium load)
No problems high load at 3000, but I never go WOT under 3000, and very rarely under 3500.
Old 02-03-2019, 12:29 PM   #8266
riboyster
riboyster's Avatar
ACTUALLY I got that backwards. STOCK MAP. Aftermarket caused airflow issues. Gonna correct my post now.
sqd (02-04-2019)
Old 02-03-2019, 12:41 PM   #8267
jflogerzi
jflogerzi's Avatar
So example 5 or 6 gear at 60mph that was area even NA the motor would knock. But if your first or second gear... That rpm range and WOT should be avoided
Old 02-04-2019, 03:24 AM   #8268
sqd
sqd's Avatar
Hah, well then, so I wasn't crazy when I thought I'd read that stock MAP and MAF would work fine..
IG @squareddesign
The Following User Says Thank You to sqd For This Useful Post:
riboyster (02-04-2019)
Old 02-04-2019, 05:29 AM   #8269
86TOYO2k17
Drives: 2017 toyota 86
Not only do they work fine. They are recommended.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
riboyster (02-04-2019), sqd (02-04-2019)
Old 02-04-2019, 12:14 PM   #8270
riboyster
riboyster's Avatar
Yeah most tunes will run off of the MAF because of aforementioned airflow problems in the map area
sqd (02-05-2019)
Old 02-10-2019, 02:19 PM   #8271
jflogerzi
jflogerzi's Avatar
For those using an oil cooler which one are you using and where did you place it if you have the intercooled version
Old 02-10-2019, 04:37 PM   #8272
86TOYO2k17
Personally i use mishimoto radiator with oem oil cooler. Don’t track my car but drive very spirited and temps are never an issue.
Also hear a lot of good things about Jackson dual radiator and oil cooler as well. Just two possible solutions.
Old 02-10-2019, 04:42 PM   #8273
jflogerzi
jflogerzi's Avatar
Car, but drive very spirited and temps are never an issue.
Also hear a lot of good things about Jackson duel radiator and oil cooler as well. Just two possible solutions.
I got the OEM cooler with the TB install. But I want to do some track days. I guess I should try with it and and 5w30 oil. If it proves to much I will just byte the bullet and get the Jackson racing dual radiator
Old 02-10-2019, 06:02 PM   #8274
86TOYO2k17
I had the oem TB oil cooler from my NA days so decided to see if the mishimoto radiator would help the oil cooler work better as it is way cheaper then JR dual radiator. Feel like so far it’s working. Let us know your oil temps from tracking with he oem cooler.
Also how are your 225/45r17 tires handling the power? I can’t launch at all. If I take off anything over idle I just spin all the way through 1st till 2nd. Maybe I need to change camber and or lower tire pressure in rears.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
jflogerzi (02-10-2019)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
