Old 02-09-2019, 12:55 PM   #20455
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by mrg666 View Post
This is a liquid-to-liquid oil cooler but at the same time it is an air-to-liquid cooler as well. Is there a thermostat for oil circulation as well? If not, I am thinking that it might be cooling the oil too much when the the air temperature is too low.
https://jacksonracing.com/product/fr...toroil-cooler/
According to their site it is "thermostatically controlled via cooling system" I don't think it's a traditional thermostatic sandwich plate. It would warm the oil via the coolant as it was warmed. It will not allow the oil to be overcooled (One of my concerns) It's supposed to keep both fluids within 30F, which is ideal. I've also read to use a standalone cooler for FI systems on track. But, that's up for debate like everything else. They're proven for NA applications from what I've read.
The Following User Says Thank You to new2subaru For This Useful Post:
mrg666 (02-09-2019)
Old 02-09-2019, 01:53 PM   #20456
It seems to me the ideal solution would be having a separate heat exchanger between oil and coolant inside the engine loop, just like the OEM oil cooler but larger.
Wait. Isn't that exactly what the JR radiator does? I thought the oil circuit is oil-to-water on the left side. I think you guys are putting too much into this.
Old 02-09-2019, 02:07 PM   #20457
new2subaru
Weight Weenie
Drives: 15 FR-S
Right side if you're looking at it from the front And, that's correct.
Ultramaroon (02-09-2019)
Old 02-09-2019, 02:18 PM   #20458
So, the "thermostat" is just the coolant thermostat. Functionally, the difference between this and the Forester cooler is that the Forester cooler runs water parallel to the heater circuit which is NOT thermostatically controlled. Therefore it heats the oil faster. IMO, the thermostat thing is academic because the heat-shedding capacity of the Forester cooler is laughable.
Old 02-09-2019, 02:19 PM   #20459
mrg666
pessimistic skeptic
mrg666's Avatar
Yes it does. But, I am suspecting, it is only doing effective oil-to-water heat exchange when water thermostat is allowing the coolant circulation through the radiator. At the same time, air-to-oil cooling is always happening if there is no oil thermostat which is not good in my mind. Maybe I am reading too much into this. It is my skeptic side I guess, I wanted to buy this thing so many times and I could not click that "pay" button.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
new2subaru (02-09-2019), Ultramaroon (02-09-2019)
Old 02-09-2019, 02:22 PM   #20460
Perfectly understandable.
Old 02-09-2019, 02:40 PM   #20461
new2subaru
Weight Weenie
Drives: 15 FR-S
Yes. It's the simplicity that appeals to me. The heat from the oil will be cooled by the coolant system on track. From my experiences, so far, my car has no trouble maintaining coolant temps. Oil temps are another story. I pull of track after I hit 250F which doesn't take that long with 5w 40. I've read that this will maintain 230-250F. I'm on a short technical track so am hoping for the same results.
Also, my oil will be at the proper temps when driving normally. Just as high priority.
I can't speak to the Forester cooler. I've done lots of research but that one fell off right from the get go. I don't remember.
Old 02-09-2019, 02:43 PM   #20462
new2subaru
Weight Weenie
Drives: 15 FR-S
I think you're right. But, it doesn't take long for the coolant to warm up and open the thermostat. All of us should be taking it easy until we're up to normal operating temps anyways. So, IMHO it won't make much difference.
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
mrg666 (02-09-2019), Ultramaroon (02-09-2019)
Old 02-09-2019, 02:43 PM   #20463
I say pull the trigger. YOLO, right?
mrg666 (02-09-2019)
Old 02-09-2019, 02:45 PM   #20464
new2subaru
Weight Weenie
Drives: 15 FR-S
I did. That pic above was on my car
Old 02-09-2019, 02:46 PM   #20465
^^^this^^^ Literally every other car on the street.
mrg666 (02-09-2019), new2subaru (02-09-2019)
Old 02-09-2019, 02:47 PM   #20466
OH! duh.
Old 02-09-2019, 03:13 PM   #20467
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Booked it in for a service apointment. The Window alignment appears to be off when I am "rolling" the window up. It pops outward and sometimes will realign as it closes.
I'm also eyeing a set of OZ superleggera's. O.O
Old 02-09-2019, 08:42 PM   #20468
Iceman
Iceman's Avatar
Drives: GT86
Originally Posted by suzyj View Post
They look really nice. The red matches your car really well. Are they oem rotors?
They do match the red! It’s the same rotor as the Performance Package ones, but the calipers aren’t
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday
Iceman is offline   Reply With Quote
