#43 | |
humfrz |
#44 | |
edit. https://www.wolverineheater.com/coll...s-light-trucks |
| The Following User Says Thank You to Tokay444 For This Useful Post: | humfrz (02-07-2019) |
#45 |
o____o
mine's special. I can turn it off.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (02-08-2019) |
#46 |
So I forgot my SD card at the office so I wasn't able to use my Tactrix to log on the way in this morning so instead I used my Bluetooth LE adapter which has a terrible refresh rate and ended up hanging up before everything was up to temperature.
So here is the summary of my short log. After being parked overnight for about 13 hours the oil temp started at 71F and the coolant started at 80F. I idled in the driveway for about 4.5mins and by that time the coolant was up to 129F and the oil was up to 97F. I then pulled out of the driveway. About 6 mins from the start of the car the coolant needle on the car hit the 1/4 mark and the data showed 147F for the coolant and 115F for the oil. I forgot to get a timestamp at the point where the needle stopped climbing so I can't correlate it to the actual data. When the tstat opened for the first time it was 9mins into the log and the coolant was 194F and the oil was 158F. The BLE adapter hung up 11mins into the log and at that point the oil was at 170F. I did reconnect the BLE adapter and did some more logging on the interstate. Cruising around 3000rpm the oil temp is fairly stable around 210. I picked my cruise speed to about 90mph where it's running 4000RPM for about 1.5 mins and it jumped up to 220F. I then exited the interstate and in about 1.5mins it was back down to 210F and stayed the for the rest of my commute driving like a normal person. Here is the chart. Keep in mind the oil and coolant are on different scales so just because the line for oil temp climbs above the coolant doesn't mean it actually did. Hove the mouse to see the actual numbers. https://datazap.me/u/ermax/log-15496...=2-3&mark=2803 I will use my Tactrix to log on the way home but the starting temps will probably still be well above ambient. |
| The Following User Says Thank You to ermax For This Useful Post: | humfrz (02-08-2019) |
#47 |
You should never idle for that length of time.
Oil pressure is at its lowest at idle, and your oil is cold. That's THE HIGHEST wear and tear mode there is. Start the car and before it comes off high idle, you should be granny driving under light load and between 1500-3000 rpm until your oil is up to temp. The key here is oil pressure. |
#48 | |
![]() However, you do make a good point - in some parts, in 4 minutes, an idling car in the driveway just might get stolen - ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Tokay444 (02-08-2019), Ultramaroon (02-08-2019) |
#49 | |
The highest wear/revolution is cranking at startup. After that, there is absolutely nothing to sweat. Idle all day long.
#50 |
Famous Potatoes
Drives: '15 ultramarine
#51 |
Drives: 2015 Scion FR-S
the day i decide idling is bad for my car is the day i sell my car.
stressing over how long the car idles is not how i want to live my life lol |
| The Following User Says Thank You to e_lunatic For This Useful Post: | Tcoat (02-08-2019) |
#52 | |
Right oil temp for higher revs
Sorry, I was saying bye to my family. Hahaha. I normally crank and go. Personally highest wear would be redline with cold oil. That is all I really worry about. |
#53 |
The same applies to those that say that driving at higher RPMs all the time is wearing out the engine! The oil systems are designed to work through the whole range of engine speeds during normal driving conditions and worrying that one speed or another is damaging anything is silly.
#54 | |
But it’s only 100 at idle with cold oil right? Once it’s up to temp the idle pressure on this car is silly low isn’t it? I don’t have a pressure gauge so I don’t have first hand knowledge of this. |
#55 | |
![]() ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | e_lunatic (02-11-2019), Ultramaroon (02-08-2019) |
#56 |
| Tags |
| oil, temperature |
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 05:47 PM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-29-2013 11:50 PM |
| 2.5L with lower revs/more torque, or 2.0L with higher revs? | Superhatch | Engine, Exhaust, Transmission | 124 | 08-28-2013 12:20 PM |
