#184 | |
Just WOW
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | MuseChaser (02-05-2019), Summerwolf (02-06-2019) |
#185 | |
Feeling like thinking....
You should take up flying. What could go wrong?
Drive like everyone's life around you depends on it...
| The Following User Says Thank You to MuseChaser For This Useful Post: | gravitylover (02-05-2019) |
#187 |
Weight Weenie
Drives: 15 FR-S
#188 | |
Wife and I were in Kingston, ON, less than a year ago. We laughed our butts off when we saw the Dollar store where everything was $1.25. No political commentary felt or intenteded... just funny.
| The Following User Says Thank You to MuseChaser For This Useful Post: | new2subaru (02-05-2019) |
#189 |
Famous Potatoes
Drives: '15 ultramarine
Like Motel 6 and EZ 8 Motel. Tough when you have a price in your name. We had a dumpster company here for years called "$100 Dumpster Rental". Had it plastered on the side of their dumpsters. You would call and they would inform you that was their outdated name, and a dumpster cost a few hundred.
#190 | |
Weight Weenie
Drives: 15 FR-S
They sold out...They're carrying all the name brands now.
#192 |
Famous Potatoes
#193 | |
This has happened so many times on this forum in the 6 years I've been here. Always ends with the same original poster asking the question and trying to prove everyone wrong when we tell him/her to use 91 or higher as the savings offset the cost. As well as less engine wear when we prove the IAMs in the tunes can get below 1 at some points.
#194 | |
Bottom line is you're taking a performance hit and adding wear to your engine and not listening to the vast majority of people who had this car longer than you. As an avid tune user with some tweaks made to my OFT tunes, I can tell you, the only way to correctly observe knock on a modern car is definitely not by ear or feel, the fact you think you can hear it proves your stupidity. You would have to datalog and watch the ignition advance modifier (IAM), Fine learning knock control (FLKC), and feed back knock control (FBKC). To get an accurate read on anything, a knock sensor is literally mounted to the engine block and is a microphone way more accurate than a human. A long time ago a user like you called "CatScan" posted a similiar thread and I went through and posted full datalogs of my car testing it on 87, 89, 91 and 93 and posted the logs on datazap.me. I consistently had IAMs below 1 that would run from .7 back up to 1 after each fill up as the car learned at the stock tune and on 87 it stayed around .89-1 depending on how I drove. This proved the car was knocking. How? Because it has to detect the knock before it can adjust, subjecting your engine to knock BEFORE it can adjust is not something you want to do repeatedly. Especially when it keeps knocking and you're not making proper MPG or power. Also the oil check idea is ridiculous and not a valid comparison and makes you seem like a troll. You realize oil can burn slowly without losing it right? and on this car specifically people have had oil leaks that don't puddle on the ground like the cam seal leak on manuals correct? I sincerely hope you spend your money on something less costly than a sports car if you can't be bothered to check maintenance items like that or to fill up on 91 or higher. You lack the knowledge to make a good judgement about your vehicle's technology therefore stick to the manual and stop complaining on a forum when others tell you not to do something or suggest that doing something is bad. Otherwise stick to the 87 octane and stop trying to justify it to everyone else.
| The Following 6 Users Say Thank You to FRSBRZGT86FAN For This Useful Post: | finch1750 (02-06-2019), jrb363 (02-06-2019), MuseChaser (02-06-2019), Sapphireho (02-06-2019), Tcoat (02-06-2019), Ultramaroon (02-06-2019) |
#195 | |
Also learn to quote peoples posts.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Tcoat (02-06-2019) |
#196 |
DANG! - look out folks - ol @FRSBRZGT86FAN is onna roll -
![]() ![]() humfrz Reminds me of when I was 14 and had my own car, back on the farm, my Dad told me I couldn't put "tractor gas" (from our farm fuel tank) in my car because it would turn the carburetor red and the sheriff could tell I was using tax exempt farm gas in a car.
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | FRSBRZGT86FAN (02-06-2019), Tcoat (02-06-2019) |
| Oil grade opinion please. | Mr_YUzU_FRS | Forced Induction | 47 | 03-10-2018 02:45 AM |
| Weapons Grade CNC Mounts | Bullitt2496 | Engine Swaps | 8 | 02-28-2017 04:18 PM |
| Vette-Powered BRZ by Weapons Grade | shiud | BRZ First-Gen (2012+) — General Topics | 28 | 04-28-2015 02:53 PM |
| Has anyone driven Laurales Grade in Monterey | 1FunFR-S | Southern California | 0 | 09-30-2012 02:04 AM |
| Weapons Grade Performance Intro | Doug@WGP | Announcements, Contests, Giveaways | 2 | 07-21-2012 05:24 AM |
