Old 02-03-2019, 10:07 PM   #85
gravitylover
Originally Posted by WRXcellent View Post
One of the dealers near me has a "special package" for $399 for full hose and belt replacement.
https://www.premiersubaru.com/subaru...ing-recall.htm
Hmm Branford isn't that far from me. I might consider this dealer when I'm ready.
Old 02-04-2019, 11:00 AM   #86
ka-t_240
I know timing chains are technically lifetime items, but I also know things can fatigue and stretch.
156k miles here. Would anyone think to replace their timing chain since it comes off during the recall or just let it be?
I would discuss with the location doing the service. I know they are typically they say they last forever, but I know there are also many applications(EvoX) that have had chain stretch issues. I would imagine there is a spec for strech that is acceptable vs none on these engines.
On the Subaru engines with belts, the tensioners often fail before the belts, it would not be a bad idea to discuss having those and the guides/wear surfaces replaced.
ka-t_240 is offline   Reply With Quote
The Following 2 Users Say Thank You to ka-t_240 For This Useful Post:
finch1750 (02-04-2019), Tcoat (02-04-2019)
Old 02-04-2019, 11:10 AM   #87
Depends. Do you want to be the guinea pig for how long these chains last? So far it has been a non issue but as we climb in miles it may appear. I personally wouldn't at this point but I am also the guy that waited too long to change my TOB and destroyed my clutch.
Old 02-04-2019, 11:56 AM   #88
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Didn't think about a published spec for it. I'll talk to the service manager and try to get some info.
Old 02-05-2019, 11:29 AM   #89
vladniko86
vladniko86's Avatar
Drives: FRS
My dealer is pulling the most annoying stuff right now. I dropped it off last monday and its the next week's tuesday. I called them last thursday and they said they broke something and have to get a new part. Call today, figured out it was a "holder
engine mount im guessing
and they said its still not here. Isnt the dealer supposed to overnight this stuff?
vladniko86 is offline   Reply With Quote
Old 02-05-2019, 11:53 AM   #90
No spec in service manual. All it references is "deformation" with no actual measurements supplied.
finch1750 (02-05-2019)
Old 02-05-2019, 11:54 AM   #91
finch1750
finch1750's Avatar
It'd be nice of them, but no. They should definitely be covering a rental if they aren't already though.
vladniko86 (02-05-2019)
Old 02-05-2019, 11:55 AM   #92
vladniko86
vladniko86's Avatar
Drives: FRS
No. But they should definitely be covering a rental if they aren't already.
Oh I was under the assumption that they are. In that sense UPS is what they said they were using so Boo ups haha
Old 02-05-2019, 12:01 PM   #93
LunarStorm86
Drives: 2016 FR-S RS2.0
Dealers can't shit parts, and they cant make the supplier shit parts.
Shortages happen. As long as they are covering your rental, enjoy racking miles on someone else's vehicle.
I damaged a cam sensor on one, 275 are on back order through toyota. Apparently I'm not the only one.
I called a local Subaru dealer, they had 2 on the shelf.
Toyota can only get a part when Subaru has them to give to them, know what I mean..
LunarStorm86 is offline   Reply With Quote
The Following 2 Users Say Thank You to LunarStorm86 For This Useful Post:
Kwaziekeller (02-06-2019), Tcoat (02-05-2019)
Old 02-05-2019, 12:03 PM   #94
vladniko86
vladniko86's Avatar
Drives: FRS
Ah gotcha makes sense. I wish they could've not broken it but that's life
The Following User Says Thank You to vladniko86 For This Useful Post:
Tcoat (02-05-2019)
Old 02-05-2019, 05:24 PM   #95
LunarStorm86
Yea man I definitely understand, we hate breaking things too,
But it does happen
As long as you get taken care of, that's all anyone can ask for
The Following User Says Thank You to LunarStorm86 For This Useful Post:
Old 02-05-2019, 05:24 PM   #96
vladniko86
vladniko86's Avatar
Drives: FRS
But it does happen
True. How long have you been working as a tech?
Old 02-05-2019, 05:29 PM   #97
LunarStorm86
Toyota for 7 years, I worked at and independent shop for about 5 years.
My bossman at the time passed away and it was just me and him, so I decided a shop with air conditioning was my kind of place
Been here ever since
Old 02-05-2019, 05:34 PM   #98
vladniko86
vladniko86's Avatar
Drives: FRS
Do you like the work you do?
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 06:21 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
valve spring recall-engine oil leak TYinhouse Issues | Warranty | Recalls / TSB 13 01-17-2019 11:09 AM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 08:44 PM
