Old 02-04-2019, 11:34 AM   #113
So what are your feelings on lightweight pullies?
Lightweight pulleys? Depends on the color.
finch1750 (02-04-2019)
Old 02-04-2019, 11:57 AM   #114
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by FRSBRZGT86FAN View Post
I suspect OP doesn't have an OFT or anything close to that to datalog his cars or show evidence of how lower octane fuels effect performance....
Considering I've asked and never gotten an answer, they do not.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
FRSBRZGT86FAN (02-06-2019), Tcoat (02-04-2019)
Old 02-04-2019, 12:42 PM   #115
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Originally Posted by extrashaky View Post
BTW, I have used non-ethanol in mine. My anus did not pucker any differently.
Did you notice any other performance differences between non-ethanol and ethanol enemas?
PetrolioBenzina is offline   Reply With Quote
The Following 2 Users Say Thank You to PetrolioBenzina For This Useful Post:
extrashaky (02-04-2019), Tcoat (02-04-2019)
Old 02-04-2019, 12:53 PM   #116
Silverz
Drives: Black frs
No I don’t have a data logger. That would be the same as me asking if you have ever tested the octane of the gas pumps to determine if you are actually getting 93 octane or if the driver filled 87 in the premium tank. Lol
Silverz is offline   Reply With Quote
Old 02-04-2019, 01:24 PM   #117
Tokay444
Naked Bacon it is.
The Following User Says Thank You to Tokay444 For This Useful Post:
Sapphireho (02-04-2019)
Old 02-04-2019, 01:25 PM   #118
Tokay444
No it isn't, because one would actually be cause for a lawsuit.
Old 02-04-2019, 01:50 PM   #119
Silverz
Drives: Black frs
It has happened many times before. Diesel has been put in the unleaded tanks.
87 in premium tank doesn’t cause problems so you may have filled up with 87 and not know it.
Old 02-04-2019, 01:53 PM   #120
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Funny, that has never happened to me in 40 years of driving.
Tokay444 (02-04-2019)
Old 02-04-2019, 02:03 PM   #121
Tokay444
That would most DEFINITELY cause a problem. It's called knock, and predetonation.
In the case of diesel, it's, "Car don't fuckin' work"
Old 02-04-2019, 02:06 PM   #122
Silverz
Drives: Black frs
Probably not diesel in unleaded because you would know.
But how do you know they haven’t accidentally or intentionally put 87 in premium storage tank?
Old 02-04-2019, 02:10 PM   #123
Tokay444
Because your car would knock its ass off under load.
Ultramaroon (02-04-2019)
Old 02-04-2019, 02:23 PM   #124
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
The ECU should compensate and pull timing if you used a lower octane fuel, causing the car to lose some torque-ponies. You could either drain the gas or add octane booster.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-04-2019, 02:36 PM   #125
Tokay444
You'd never be able to get enough "Octane booster" in the tank to make any discernible difference. You'd need to use straight toluene, or something like methyl hydrate.
Old 02-04-2019, 02:38 PM   #126
Silverz
Drives: Black frs
But it doesn’t. I hit 100+ mph regularly.
Oil grade opinion please. Mr_YUzU_FRS Forced Induction 47 03-10-2018 02:45 AM
Weapons Grade CNC Mounts Bullitt2496 Engine Swaps 8 02-28-2017 04:18 PM
Vette-Powered BRZ by Weapons Grade shiud BRZ First-Gen (2012+) — General Topics 28 04-28-2015 02:53 PM
Has anyone driven Laurales Grade in Monterey 1FunFR-S Southern California 0 09-30-2012 02:04 AM
Weapons Grade Performance Intro Doug@WGP Announcements, Contests, Giveaways 2 07-21-2012 05:24 AM
