Old 02-04-2019, 02:15 AM   #1121
C3
C3's Avatar
Drives: Scion FR-S
Originally Posted by Trust86 View Post
You sure wastegate is hooked up/installed correctly? Sounds like valve seat in wastegate wasn’t installed
I'm adding a 10psi spring this week so while im doing that I'll check the valve seat. I'm convinced its a boost leak but we tested with smoke and the only leak was out of the intake. My brother and I are going to take a look at this week. Hopefully he can see what me and my tuner are missing.
C3 is offline   Reply With Quote
Old 02-04-2019, 05:57 PM   #1122
Trust86
Drives: 2016 Halo FRS
Smoke only leaked out the intake? Did you not block off the intake side of the turbo? The throttle plate should be closed and run the leak tester through the intake side of the turbo, it shouldn’t leak anywhere, you can further conduct a leak test by turning the key to on position, the hit the gas pedal to open the throttle plate. That’s how I found my leak, injector in the intake manifold was missing the o ring. I use cut a hole in the finger of a latex glove, stuck the leak tester tip in it and taped it off, then stuck the glove over the intake side of the compressor housing. It shouldn’t leak at all, and if it is, there’s your leak. If you did do it correctly, then it has to be the valve seat in the waste gate. Basically a big hole in the manifold before the turbo, exhaust gases going through there instead of spoiling the turbo. I’m guessing you have recirculated wastegate, bc you would be able to notice it right away if you had open dump
Trust86 is offline   Reply With Quote
Old 02-05-2019, 01:37 PM   #1123
C3
C3's Avatar
Drives: Scion FR-S
I’m new to building cars but after talking to my brother, it’s because I’m 10:1 compression. More boost should get me where I want to be power wise.
The Following User Says Thank You to C3 For This Useful Post:
Trust86 (02-05-2019)
Old 02-05-2019, 03:25 PM   #1124
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
You failed to mention that you had a built low compression engine.... that explains everything lol
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
C3 (02-05-2019), Trust86 (02-05-2019)
Old 02-05-2019, 05:35 PM   #1125
Trust86
Lmao I was like “well then”
The Following User Says Thank You to Trust86 For This Useful Post:
C3 (02-05-2019)
Old 02-12-2019, 01:04 PM   #1126
r3myx626
r3myx626's Avatar
Drives: 2015 Subaru BRZ Limited ISM
Realistically how much horsepower should I expect with stock frontpipe/catback with 7 or 10psi spring on gt2860rs kit (pump gas 93oct or e85)?
r3myx626 is offline   Reply With Quote
Old 02-12-2019, 02:54 PM   #1127
ATL BRZ
ATL BRZ's Avatar
250-300whp fuel/boost dependent
Conman (04-30-2019), r3myx626 (02-12-2019)
Old 04-03-2019, 10:27 AM   #1128
djezlee
Drives: 2017 BRZ Limited
JDL No-Cut Intercooler
Anyone have a good review of the no-cut intercooler offered by JDL? I am looking for any opinions on performance, fitment, regrets, or installation problems.
djezlee is offline   Reply With Quote
Old 04-05-2019, 12:19 AM   #1129
incutebus
Drives: Boosted
From the questions I've asked Jesse before. You gain a little bit of lag and with more parts, there potentially can be more issues along the line. He and a few others highly recommend grabbing an aftermarket bash bar.
incutebus is offline   Reply With Quote
Old 04-13-2019, 12:25 AM   #1130
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Yup, for the price it goes for it is a good move. We have one coming for our build, this will also make it easier to mount up the oil cooler.
Xero-Limit is offline   Reply With Quote
Old 04-30-2019, 01:36 PM   #1131
James Russels
Drives: 2013 FRS
Question for those who have installed the kit: I currently have a 2.5" overpipe but may upgrade to a 3" in the future. If I get the 3" downpipe outlet flange, would something like this or this be able to adapt it to the overpipe?
Also, is there any general hardware or nonstandard tools you would recommend having on-hand before installing the kit?
James Russels is offline   Reply With Quote
Old 04-30-2019, 01:40 PM   #1132
Trust86
I believe the flange size is the same for the 3” and 2.5”. The hole is just a different size. Shouldn’t have any problem bolting 2.5” to 3” or 3” to 2.5”
Old 04-30-2019, 01:41 PM   #1133
ATL BRZ
ATL BRZ's Avatar
Adapters like that are not ideal and will allow leaks. If you have a 2.5" overpipe just leave it be and order your kit with the 2.5" downpipe exit flange. 2.5" exhaust will not become a restriction until you're making far beyond the power limits of a stock engine (500+)
You can complete the install with basic hand tools and metric sockets but a set of crows foot socket adapters will come in handy when getting to all six manifold nuts
Old 04-30-2019, 03:52 PM   #1134
James Russels
Drives: 2013 FRS
I've read sources saying that a 3" is recommended for as low as 350 hp. Do you know where I can find these calculations for our platform?
Thanks - any spare hardware you'd recommend I have available? Nuts, bolts, washers, gaskets, etc?
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
