Old 01-31-2019, 03:01 PM   #15
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
No it doesn't it says 91 which is still premium.
I don't think the OP understands what the numbers mean and feels that it is just a quality thing. It is not.
My understanding may be imperfect, but the main affect low octane gas has is that if you ignite too early, it creates too high pressure near the cylinder walls, resulting in detonation. The Subaru ECU good at protecting the engine from this by pulling timing. The result is lower efficiency and power. My understanding is that the factory tune is borderline for not pulling timing with 91. It will pull timing with 87.
I guess it's questionable whether it can pull enough or whether 87 also introduces pre-ignition detonation. I guess someone could log some driving with 87, but anyone who can do that probably doesn't want to (including me lol).
Spuds is online now   Reply With Quote
Old 01-31-2019, 03:02 PM   #16
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
Originally Posted by PetrolioBenzina View Post
Needs a tune for ethanol, using the OFT. Surprisingly strong running, and probably how it shoulda/coulda come from the factory.
Huh, it was my understanding that most high compression engines could run on 105 octane race fuel no problem. Am I perhaps thinking of a non-ethanol 105 octane?
Borchert97 is offline   Reply With Quote
Old 01-31-2019, 03:08 PM   #17
qcbaker
Shitpost Generator v8.6
qcbaker's Avatar
93, since that's what the manual recommends and its available at the gas station near my house.
qcbaker is offline   Reply With Quote
Old 01-31-2019, 03:18 PM   #18
Brink
Drives: 2017 BRZ
I'd imagine there's an upper RPM limit somewhere below redline where there's just not enough time left for the ECU to pull timing enough for 87. Not that anyone would be particularly eager to find where that is.
Brink is offline   Reply With Quote
The Following 2 Users Say Thank You to Brink For This Useful Post:
Spuds (01-31-2019), Tcoat (01-31-2019)
Old 01-31-2019, 03:20 PM   #19
Your understanding is correct. However, some gas stations are not actually giving you the octane that is rated on the pumps. Stations with high turnover will usually be there but since the octane levels drop with age you can be at risk if using rated 87. It could actually be 82 or 84 and since the difference between the small changes in numbers is significate that is serious. The chance of serious pre ignition in a high compression engine increases. Will it pull timing in time is anybody's guess but you most certainly have some bad knock while it does. Could possibly (probably?) use it for the life of the car and never have an issue or you could blow the engine up from one tank of bad gas. I have had to put 87 in a couple of times and it is not big deal but it is not a risk I would accept on an ongoing basis just to save a couple of hundred bucks a year. I seriously question the claimed savings of $2,500 since you would have to go through a shitload of fuel. Ironically you would get worse mileage running the 87 anyway so any savings you think you are getting may be null.
Gonna say something I never do but...
If saving money by using the wrong fuel is that important than people need to be looking at other cars.
finch1750 (01-31-2019), jrb363 (02-03-2019), mrg666 (02-08-2019), Rakshaa (03-12-2019), Sapphireho (01-31-2019), Spuds (01-31-2019)
Old 01-31-2019, 03:23 PM   #20
They will run on it but it will serve zero advantage unless tuned to take advantage of it. Higher octane does not mean "better" burning or higher quality. In fact it does the exact opposite as far as the burning part goes.
Borchert97 (01-31-2019), e30kawi (01-31-2019), Grady (01-31-2019)
Old 01-31-2019, 03:23 PM   #21
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I get knock correction on 91, would never run anything less. I run on E85 most of the time now but changed during this last "cold snap" when it was hard to start in 30F temps. Plus I have to drive 15-20 min away to get it so is a hassle to begin with, but worth it for my engine to run better.
ethanol has different flow requirements then regular fuel so it requires a tune.
Old 01-31-2019, 03:23 PM   #22
Borchert97
Borchert97's Avatar
Makes sense, thanks.
The Following User Says Thank You to Borchert97 For This Useful Post:
Tcoat (01-31-2019)
Old 01-31-2019, 03:27 PM   #23
finch1750
finch1750's Avatar
Figuring 30mpg to be nice it's a savings of $600-650 based on the normal $0.20 savings from premium to 87
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Brink (01-31-2019), Tcoat (01-31-2019)
Old 01-31-2019, 03:31 PM   #24
Well they we go then.
Old 01-31-2019, 03:45 PM   #25
gravitylover
93 unless I find non ethanol gas then I use it, I've never seen it over 91.
Old 01-31-2019, 03:58 PM   #26
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
93 Sunoco...
RL_BRZ is offline   Reply With Quote
Old 01-31-2019, 04:06 PM   #27
Tokay444
Why non ethanol?
Old 01-31-2019, 04:23 PM   #28
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
There are places here and there where I live where you can get a variety of different race fuel octane levels from 98 to about 110. You won't notice any difference in your street car, except maybe an increase in acceleration due to the weight loss in your wallet.
Oil grade opinion please. Mr_YUzU_FRS Forced Induction 47 03-10-2018 02:45 AM
Weapons Grade CNC Mounts Bullitt2496 Engine Swaps 8 02-28-2017 04:18 PM
Vette-Powered BRZ by Weapons Grade shiud BRZ First-Gen (2012+) — General Topics 28 04-28-2015 02:53 PM
Has anyone driven Laurales Grade in Monterey 1FunFR-S Southern California 0 09-30-2012 02:04 AM
Weapons Grade Performance Intro Doug@WGP Announcements, Contests, Giveaways 2 07-21-2012 05:24 AM
