Old 01-29-2019, 09:48 AM   #15
Originally Posted by PatSciFRS View Post
This intermittent power steering failure should be considered a safety concern. Toyota and Subaru should do the right thing and issue a TSB/recall for it. If this happens whilst in the middle of a sharp turn, it can really cause a bad accident.
Anyone knows how to contact the right people at Toyota/Subaru?
Has it happened to you? How many has it happened to?
Old 01-30-2019, 08:48 AM   #16
PatSciFRS
Drives: Scion FRS 10 Series
Yeah, it has happened to me on several random occasions. On most of these occurrences, a quick engine off and on at the stop light solved the problem. On at least one occasion, the warning light and beep came on while driving and before I got the the next stop, the fault cleared itself. The other day, my son and his wife came to visit and I let them borrow the car during their stay. I had to warn them about the steering problem. Of course, they never experienced it happening, and they probably thought that I had just made up this story so they would not try to "drift" the car. Maybe they did do it anyway, who knows?
PatSciFRS is offline   Reply With Quote
Old 01-30-2019, 08:59 AM   #17
Presume you have had it in to the dealer?
Old 01-30-2019, 09:20 AM   #18
Brz_racer
Drives: Subaru BRZ
This has yet to become a widespread issue with these cars, if it ever does. It would need to happen to hundreds or even thousands of owners before Subaru or Toyota would issue a TSB, let alone a full on recall. Recalls cost the manufacturer a fortune and they wont put one out just because a few people have had this problem. This is why it's usually a good idea to get an extended warranty for after the manufacturer one expires.
Brz_racer is offline   Reply With Quote
Old 01-30-2019, 10:08 AM   #19
There was a recall for steering failure in Australia (and the UK?). It was for corrosion in a module that we don't even have here though. It didn't take hundreds or thousands of failures to drive the recall though.
Recalls are strictly for safety reasons and can occur even with relatively few failures. The thing is that the failures all have to have the exact same cause. I don't think there has been any consistent cause identified for the very, very rare reports of failures in North America.
TSB are technical documents on how to repair identified defects. They are just instructions and in no way should they be confused with a recall or even an acknowledgement that there is a problem (weird but true). Once again however they can only exist if there are enough failures to identify a common cause and develop a correction.
Since recalls only can occur for safety reasons the manufacturers usually have zero say in if there is a recall or not. They most certainly have the option of a voluntary recall (such as the valve spring one) or the NHSTA (in the USA) can force them. They can't decline because it will cost them to much. If somebody has had a repeated issue that is safety related and they have not managed to fix it they should contact the NHSTA. They WILL investigate.
Extended warranties can be a hit or miss proposition. Some use them and it saves them thousands. Most never have an issue so they never collect and beyond giving peace of mind it was wasted. They are pretty much a gamble with you betting you will have a serious enough problem to make it worthwhile and the insurance company (they are insurance companies) betting you won't and keeping your money.
Old 01-30-2019, 10:17 AM   #20
ermax
ermax's Avatar
It didn't take hundreds of thousands of valve spring failures to issue a recall for that. What was there like 94 cases reported? I am not having intermittent outages on my car but I am suffering from the annoying gear chatter (not a safety concern). It would be nice if they sold parts for this unit so you were not forced to replace the whole thing at $1400. I bet the intermittent outages are due to something as stupid as a sensor going bad but because it's only sold as one unit you can't buy just a sensor.
One of these days when I'm in the mood to potentially burn some money and I will buy a used unit on eBay for $150 to take apart and learn from.
Old 01-30-2019, 10:28 AM   #21
Brz_racer
Drives: Subaru BRZ
Back in 2010 I had Cobalt SS that had a recall for the ignition shutting off when going over bumps but I didnt know it at the time I bought the car. This was a serious issue that when it occurred would cause the steering wheel to lock while moving. Happened to me on the highway going 70mph once and I almost shit myself. My point is at least you were still able to retain manual control of the car.
Old 01-30-2019, 10:37 AM   #22
The GM ignition recall is one of the most infamous ones out there. If memory serves me it caused 150 or so deaths and ended up costing Gm almost a billion dollars in penalties alone. I believe the total costs with lawsuits, recall expenses, penalties and others was somewhere around $3.5 billion. It is one of the main reasons that voluntary recalls have climbed over the last few years.
Old 01-30-2019, 03:20 PM   #23
pkat696
Drives: 2013 Scion FR-S 10 Series
I have been chasing the same issue on my 2013 FR-S. Here is a thread describing others' attempts to figure this out as well my attempts, which by the way continue.
http://www.ft86club.com/forums/showthread.php?t=114665
pkat696 is offline   Reply With Quote
Old 08-19-2019, 06:36 AM   #24
Envirotech
Drives: 2014 BRZ
I have had the same intermittent problem on my 2014. started happening in maybe 2016. I first started seeing it when it was very damp out in the mornings. Then eventually, when it was really hot out. Now, just yesterday, it happened, and it would not disappear. Restarted car 5 or 6 times. Kept coming back. Looks like whatever loose wire, corrosion, bad connection has finally decided to not correct itself. Shop bound today.
Envirotech is offline   Reply With Quote
Old 08-19-2019, 08:58 AM   #25
ermax
ermax's Avatar
That is interesting because all the electronics related to the EPS are located inside the car. It’s all mounted to the column right behind the lower kick panel. You can reach your arm under there and lay your hand on the motor.
Old 10-18-2019, 08:16 PM   #26
rflip
The same issue has been occurring on my 13 and the dealer diagnosed it as a failure of the ECU. It’s happened roughly 30 times in the last year and is a $1200 fix at the dealer. The dealer solution matches the solution for the Australian recall.
rflip is offline   Reply With Quote
Power Steering rosol16 Issues | Warranty | Recalls / TSB 15 12-15-2015 09:44 AM
Where is our power steering ECU? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-24-2015 12:38 PM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 04:16 PM
Quit old job looking for new one ric342 Southern California 4 08-05-2013 03:36 AM
trunk release quit working regal Issues | Warranty | Recalls / TSB 4 04-20-2013 10:41 AM
