Old 01-29-2019, 08:19 PM   #29
OK, oh wise one. If your car was the same age but only had 23,000 miles on it, would you feel the same way?
I wouldn't do it if it survived break-in.
Clipdat (01-29-2019), humfrz (01-29-2019)
Old 01-29-2019, 08:31 PM   #30
Thanks.
I'm kind of leaning that way - "if it ain't broke, don't fix it" - has served me well, over the years (most of the time - ).
Clipdat (01-29-2019), Ultramaroon (01-29-2019)
Old 01-29-2019, 08:59 PM   #31
Thanks.
This is a classic example of one of my mantras "It'll either break right away or it'll last forever."
humfrz (01-29-2019)
Old 01-29-2019, 09:08 PM   #32
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Bathtub curve.
Old 01-29-2019, 09:26 PM   #33
gravitylover
Originally Posted by maslin View Post
If you take your car to the dealer they will want to do the recall. Some states (California?) won't let you renew your registration without completing the recall.
They can't require you to come in. If you don't want to get it done, don't get it done. Recalls never expire. Never. If you hold off and a spring fails in 10 years, it will all be fixed under the recall.
What about when a recall fix was performed but the part goes bad later anyway? We had "the fix" on the rear brake lines on our 06 OB done way back when, a year and a half ago they rotted through anyway. Subaru wouldn't even consider working with me on replacing the lines at that time because the recall had expired.
Old 01-29-2019, 09:28 PM   #34
Bathtub curve.
For these springs the first component of the curve dominates. Especially, those engines that survive cold start in Minnesota and Illinois in the next few days.
Old 01-29-2019, 09:40 PM   #35
Yep, in my case, many cold starts, run till just get warmed up, shut down.
I would think that if a valve spring was going to come unsprung, it would have done it within the first 5 years -
Besides, you know how many of those pneumatic screen/storm door closers you have ran across - that have failed?
Now, compare that to the old screen door closing springs that have worked for years and still work.
Old 01-29-2019, 10:17 PM   #36
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
I would double check that. I was told by the service advisor at the Toyota dealer where I had my recall done that if you avoid the job and your engine blows as a result, they may not actually cover it.
Don't know where the legality stands on that, but I thought I'd pass this along.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
Old 01-29-2019, 10:51 PM   #37
ermax
ermax's Avatar
Valve spring recall - CEL and Slip Light now on
Originally Posted by Pinoy_FRS View Post
Hey guys so I finally got my car back again earlier this morning. Car is running great as of right now. I’ll see how it does in the next few days. As for the check engine light this is what is written on my invoice:
“Cause: p000b cam position b timing slow response bank 1, p0014 cam position b timing over advanced or system performance. I active tested both exhaust vvti systems and found bank 1 had a delay. I swapped the oil control valves and found the delay followed the ocv to bank 2. I road tested the car 55 miles and could not get a code to set, monitor passed.
Correction: replaced bank 1 exhaust vvti solenoid. Active tested the vvti system and the delayed engagement did not happen, road tested 14 miles, the monitor is complete and the code did not return”
So to my understanding (still not that mechanically inclined) it was my vvt gear? Oil pressure wasn’t getting high enough to drive in higher rpms?
No, sounds like all they did was replace a bad OCV. There is one on each gear and to troubleshoot you swap OCV’s between banks to see if the CEL follows. If it follows then you know you have a bad OCV. Most likely they cracked the connector on one while handling your timing cover.
OCV = Oil Control Valve. They are referring to it as a solenoid because that is what it is. The OCVs work in a feedback loop. They pulse on and off at different rates of speed which controls the flow of oil into the gear while monitoring the cam angle sensors. If the ECU wants a specific angle and doesn’t see the result it expects in the cam angle sensor within a specific amount of time it throws the slow response CEL for the bank in error.
Old 01-29-2019, 11:46 PM   #38
radroach
Drives: car
@Pinoy_FRS correct me if I'm wrong but I think its the intake cam that is variable, not the exhaust?
Old 01-29-2019, 11:55 PM   #39
ermax
ermax's Avatar
All 4 cams are variable.
The Following User Says Thank You to ermax For This Useful Post:
humfrz (01-30-2019)
Old 01-30-2019, 12:01 AM   #40
OK, you're back in my good graces -
ermax (01-30-2019)
Old 01-30-2019, 12:03 AM   #41
@ermax did.
Old 02-12-2019, 12:08 AM   #42
Pinoy_FRS
Drives: Ultramarine
AND WE’RE BACK KIDS!!
Two weeks after I got my car a second time following my check engine light problem my car has died on me.
Quick little background information...I was driving home on the highway and went to downshift to pass a car. As I did I heard some clanking sound and knew immediately something wasn’t right so I started to pull over. Oil light came on followed by everything else. As I pulled over my car started to die and it did. Couldn’t start it at first and when it finally cranked there was a loud knocking sound. Shut it off immediately.
Got it towed to the dealership I had it serviced for the recall so I’ll be waiting to talk to them tomorrow
Pinoy_FRS is offline   Reply With Quote
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
Valve Spring Recall Dealers AsianStyle Mid-Atlantic 20 05-04-2019 02:43 PM
Has Anyone Brought Their Car In For Valve Spring Recall Little Mt. Fuji NY / NJ / CT / PA 33 03-21-2019 09:49 PM
Valve Spring Recall Resolved!!! hgamit Issues | Warranty | Recalls / TSB 32 02-23-2019 10:00 PM
