Old 01-27-2019, 04:58 PM   #1
Butterballz
Drives: Black FRS
Metallic tink
So I’ve been hearing a metallic tink from the passenger side engine. It’s regular and evenly space. Not loud enough to hear from the cabin but can hear it through the engine idle with hood open and ear near there. Slightly slower than the DI clicks. I used a a stethoscope but couldn’t really pinpoint it out since in couldn’t reach the side of the head well. I can hear it from the oil control valve area and also on the block near that area about the same loudness. Nothing from the driver side that matches the right side or at least nothing that slow and regular. Increases speed with rpm.
What do you guys think?
Butterballz is offline   Reply With Quote
Old 01-27-2019, 07:24 PM   #2
Lantanafrs2
Drives: 2013 frs red
Is the car stock?
Lantanafrs2 is offline   Reply With Quote
Old 01-27-2019, 07:52 PM   #3
Butterballz
Drives: Black FRS
Originally Posted by Lantanafrs2 View Post
Is the car stock?
Yes stock motor.
Old 01-27-2019, 09:07 PM   #4
AT or MT?
Does it do it after the car is totally warmed up?
Old 01-27-2019, 09:34 PM   #5
Lantanafrs2
The cams spin at half crank speed so if the noise seems slower yet steady, could be in valve train. Header leak can cause metallic sounds as well.
Old 01-27-2019, 09:35 PM   #6
Butterballz
Drives: Black FRS
AT or MT?
MT and yes
Old 01-27-2019, 09:53 PM   #7
Originally Posted by Butterballz View Post
MT and yes
OK, so it's not that cam thing that the AT uses.
Must not be a heat shield, unless it slow to warm up and to cool off.
Old 01-27-2019, 10:11 PM   #8
Butterballz
Drives: Black FRS
Yea I’m as stumped as you. Best case scenario is header leak, worst case scenario is valve train damage.
Old 01-28-2019, 12:23 AM   #9
Well, OK.
Lets see, you said:
"So I’ve been hearing a metallic tink from the passenger side engine. It’s regular and evenly space. Not loud enough to hear from the cabin but can hear it through the engine idle with hood open and ear near there. Slightly slower than the DI clicks. I used a a stethoscope but couldn’t really pinpoint it out since in couldn’t reach the side of the head well. I can hear it from the oil control valve area and also on the block near that area about the same loudness. Nothing from the driver side that matches the right side or at least nothing that slow and regular. Increases speed with rpm.
Like suggested you may check the exhaust and make sure you don't have a leak.
Since you can't hear it from inside the cabin, I would suggest you just ignore it. These engines make all sorts of weird sounds, that a lot of gasoline engines don't.
Back in the day, I would have called a valve lifter out of adjustment. But, since this puppy uses "buckets" tightening up a little valve slack is a pain in the butt. Besides, being a little loose (chattering a bit) is better than being too tight (can't hear it - can cause a burnt valve).
Besides if the engine is really hurting - it will send you a CEL.
Old 01-28-2019, 12:26 AM   #10
Brink
Drives: 2017 BRZ
That must be some crazy engine swap. How did you get two engines in there?
Brink is offline   Reply With Quote
Old 01-28-2019, 12:40 AM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
No swap, an add.
Sorry OP.
Back on topic, is there a running problem?
Old 01-28-2019, 01:11 AM   #12
Butterballz
Drives: Black FRS
No swap, an add.
Sorry OP.
No problems, pulls the same, no idle issues, no cel. Don’t have a reader that can pull how the engine is running so can’t tell if any is out of spec.
Old 01-28-2019, 01:16 AM   #13
you had that ah com-en.
tink, tink noise comes from rear for first ten minutes when car is cold. Wise Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-21-2017 12:51 AM
"Tink" noise, What torque spec do you use for rear axle nut? Vmax911 Engine, Exhaust, Transmission 7 09-15-2015 07:01 PM
Strange metallic rattle at around 3-4k rpm. Brett Issues | Warranty | Recalls / TSB 17 11-08-2013 03:11 PM
Why metallic intakes do not work IceFyre13th Engine, Exhaust, Transmission 53 10-16-2013 04:31 PM
True Metallic Plasti Dip BeRZed Cosmetic Modification (Interior/Exterior/Lighting) 29 07-08-2013 02:30 AM
