Old 01-25-2019, 10:42 PM   #20357
Well hell, how old is @Face_Plant?
Maybe not so much his age, but, how far back in the woods he lived -
Sapphireho (01-25-2019), Ultramaroon (01-26-2019)
Old 01-25-2019, 10:45 PM   #20358
You can measure between the 2 wheels on the axle too but that will only make them parallel, not necessarily straight to the car
Yep, with the old straight axle vehicles, a 8' length of 1"x1" of board, a couple of nails and a piece of chalk would "set-em-straight", sort of.
Old 01-25-2019, 10:50 PM   #20359
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yep, with the old straight axle vehicles, a 8' length of 1"x1" of board, a couple of nails and a piece of chalk (for hard floor) would "set-em-straight" sort of.
Well yea, did the 2x4 method on my 1970 jeep gladiator, but the solid axle 4x4 closed knuckle truck had only one adjustment. Adjust toe with a pipe wrench.
humfrz (01-25-2019)
Old 01-25-2019, 11:44 PM   #20360
Yep, a pipe wrench and a torch would do the trick -
Old 01-26-2019, 12:45 AM   #20361
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
I am 26 years young. I've been working on my and my friends cars since I was about 16, but this is my first time trying to do a ghetto home alignment. I've seen the string method before in forum DIY's and YouTube videos, so I thought it was pretty popular.
I liked it better than trying to eyeball because I could measure things and use numbers and stuff. When I try to eyeball things I'm never happy. I'll think to myself, "this looks close, but what if I tweak that. Oh, that's worse. I'll go back to before. Damnit! That's not what I had before." and it's just a viscous never ending cycle that'll keep me in the garage all night...
Face_Plant is offline   Reply With Quote
The Following 4 Users Say Thank You to Face_Plant For This Useful Post:
humfrz (01-26-2019), new2subaru (01-26-2019), Sapphireho (01-26-2019), Ultramaroon (01-26-2019)
Old 01-26-2019, 12:51 PM   #20362
ermax
ermax's Avatar
It is popular amongst racers. I’ve never seen someone tape the string to the car like that though. Typically people use two equal length pipes, one at the front and one at the rear with the strings at the ends of the pipe. Then to square up the box you measure from the centerline of the car. I’ve seen race teams with permanent mounts at the front and rear of the car for their alignment rigs so they don’t have to square it up every time. I’ve used neon green fishing line as my string. It’s lighter than actual string so it’s easier to pull taut. It also helps to have something under the wheels that allows them to move and settle in when making adjustments. I’ve used stacks of laminate wood with lubrication between them so they slide easily.
The Following 3 Users Say Thank You to ermax For This Useful Post:
Face_Plant (01-26-2019), humfrz (01-26-2019), Ultramaroon (01-26-2019)
Old 01-26-2019, 11:10 PM   #20363
Kiibiiin
Kiibiiin's Avatar
Drives: 2018 86 Steel / 97 MX-5
Installed my Raceseng R-Lock
Kiibiiin is offline   Reply With Quote
The Following 3 Users Say Thank You to Kiibiiin For This Useful Post:
humfrz (01-27-2019), mrg666 (02-01-2019), SuperTom (01-27-2019)
Old 01-26-2019, 11:19 PM   #20364
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I've seen a lot of different home grown contraptions back in my track days, just never seen one like that, or called that. Mostly pipes and 2x4s.
Old 01-27-2019, 01:16 AM   #20365
Well, Kiibiiin , normally I don't have much use for aftermarket shift knobs, but, I kinda like that one. It would go well with my white car. -
Old 01-27-2019, 08:13 PM   #20366
orz
orz's Avatar
Drives: Halo
22,500 mile service and new wheel setup. RPF1 17x7.0 +42 on stock 215/45-17 Michelin PRIMACY HP.
Got some TRD neck pillows too. They were slightly on the stiff side so replaced them with some pillow cushions I hacked up from Target. Thanks ft86speedfactory.
orz is offline   Reply With Quote
The Following 2 Users Say Thank You to orz For This Useful Post:
MJones_RB (01-28-2019), mrg666 (02-01-2019)
Old 01-27-2019, 08:16 PM   #20367
jflogerzi
jflogerzi's Avatar
Super clean and nice weight reduction on the wheels
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 01-27-2019, 11:51 PM   #20368
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Nothing. Didn't even get my rear seat delete back in. Such a slacker.
Old 01-28-2019, 09:54 AM   #20369
Chamaco
Drives: Silver FR-S
Installed (saturday) Whiteline rear sub frame bushings.
Chamaco is offline   Reply With Quote
Old 01-28-2019, 01:51 PM   #20370
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Testing out some Stain glass window film.
[/URL]
[/URL]
I LIKE TIRES!
humfrz (01-28-2019)
