Old 01-23-2019, 11:06 PM   #20343
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
That's all nice, but, how did the headlight turn out??
I won't know until tomorrow, but I'm assuming it will turn out fine. I used the same repair procedure on the passenger side about a month ago and it works great.
For the repair I use a nut that's the same thread as the adjuster bolt. Then I stuff it into the black rectangle thing that snaps into the silver part of the headlight that the projector bolts to. Next I fill the black rectangle thing with JB Weld so the nut will never come loose. Now I'm at the stage where I have to wait for the JB Weld to cure before I can put it all back together.
I told myself last month that I should probably do the driver's side while I had the bumper off to repair the passenger side, but at the time it was still working fine, so I left well enough alone.
Nut encased in JB Weld:
Face_Plant is offline   Reply With Quote
The Following 3 Users Say Thank You to Face_Plant For This Useful Post:
eastendraceshop (01-24-2019), humfrz (01-24-2019), Ultramaroon (01-26-2019)
Old 01-24-2019, 09:07 PM   #20344
new2subaru
Weight Weenie
Drives: 15 FR-S
Prepping for sound deadening/seam sealer removal. Some extra cables and wiring will be removed and stored too.
The Following User Says Thank You to new2subaru For This Useful Post:
eastendraceshop (01-25-2019)
Old 01-24-2019, 09:12 PM   #20345
new2subaru
Weight Weenie
Drives: 15 FR-S
Fuel cable and latch for fuel door. I'll be reaching in the trunk to release it. Meh...
Old 01-25-2019, 12:51 AM   #20346
Face_Plant
Face_Plant's Avatar
Today I put my headlight back in. While installing it I noticed that there is infact a side to side adjustment and not just up/down like they want you to believe. Toyota/Subaru was pretty sneaky and hid it under a cap and made it hard to see/reach unless you take the headlight out. It's the silver circle on the left in the pic below:
When that was done I installed the rear shocks and lower control arms that I was too lazy to do last night. My only complaint is I wish the Eibach Pro Kit dropped the rear a little more so the car would be level.
Old 01-25-2019, 05:47 PM   #20347
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
You learn something new every day!
eastendraceshop is offline   Reply With Quote
Old 01-25-2019, 08:12 PM   #20348
Today I put my headlight back in. While installing it I noticed that there is infact a side to side adjustment and not just up/down like they want you to believe. Toyota/Subaru was pretty sneaky and hid it under a cap and made it hard to see/reach unless you take the headlight out. .
What won't they think of next -
(to make more complicated - )
Old 01-25-2019, 08:16 PM   #20349
Yep, eastendraceshop , you can put this back in your toolbox.
Old 01-25-2019, 08:33 PM   #20350
Face_Plant
Face_Plant's Avatar
Today I tried to test out my new suspension, but the alignment was so off that I couldn't make it to the end of the street. Anything over 10 MPH made the back end feel like it was hopping, so I decided to try a rough home alignment using the string method
As you can see, the rear tires were severely toed in (I measured about 1.5 inches from the tire to the string). The front tires had some toe too, but it wasn't as severe as the rear. Reducing camber fixed the toe enough that I can drive it for a few days until my alignment.
Old 01-25-2019, 08:40 PM   #20351
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Today I tried to test out my new suspension, but the alignment was so off I couldn't make it to the end of the street.
String method? In my 55 years i have never heard of such a thing. Even just eyeballing it would get me safely to the alignment shop.
humfrz (01-25-2019)
Old 01-25-2019, 08:50 PM   #20352
Face_Plant
Face_Plant's Avatar
You've never seen that method before? I thought it was pretty well known? I didn't want to just eyeball it since it's going to be a few days until my alignment, so I wanted to make it at least somewhat acceptable so I could drive the car.
Old 01-25-2019, 09:50 PM   #20353
Ashikabi
Ashikabi's Avatar
You can measure between the 2 wheels on the axle too but that will only make them parallel, not necessarily straight to the car
Old 01-25-2019, 10:33 PM   #20354
You need to take yourself back another 20 years to have used the string method -
S. Snake (02-18-2019)
Old 01-25-2019, 10:34 PM   #20355
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Well hell, how old is @Face_Plant?
humfrz (01-25-2019)
Old 01-25-2019, 10:37 PM   #20356
You must pre date ol @Sapphireho -
Sapphireho (01-25-2019)
