Old 01-21-2019, 09:46 PM   #1247
zeal86
zeal86's Avatar
Drives:
I made some progress on squaring up my rear overfender to my sideskirt yesterday.
My gaps are pretty much on point. The plan is to 3M bond, fill, and mold the seam where the rear of my sideskirt meets my overfender.
The skirt and overfender are held together with a bolt and rivnut setup. This fastener will also help keep everything tight while the 3M bonding adhesive cures. I also have a bolt, spacer, and rivnut setup securing and maintaining the gap between the overfender and rear bumper extentions.
IG @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Irace86.2.0 (02-25-2019), Raven86Project (01-21-2019)
Old 01-21-2019, 09:50 PM   #1248
zeal86
zeal86's Avatar
Drives:
Did some more sanding today...still more work to do here though.
Can't wait to get this extension and rear overfender primed...all the colors are driving me nuts... lol
IG @zeal.eightsix
DustinS (01-22-2019), Irace86.2.0 (02-25-2019)
Old 01-23-2019, 11:36 PM   #1249
zeal86
zeal86's Avatar
Drives:
I'm considering a color change from the OEM pearl white to something different...and by different I mean white but not pearl.
I do like the bright whites but too white may clash with my engine bay since it is the base color of my pearl...I just need it to be close.
For that reason I'm leaning towards the Championship White (NH0) because from what I've read about the color it is described as creamy...creamy should work with my engine bay... however, I have time to figure this out so any suggestions on non-pearl whites will be appreciated.
I'm also considering:
HONDA:
Frost White (NH-538)
Aspen White (51E)
Taffeta White (NH-578)
TOYOTA:
Super White 2 (040)
BMW:
Alpine White (300)
NISSAN:
Solid White aka Glacier/Blizzard (QAK)
IG @zeal.eightsix
The Following User Says Thank You to zeal86 For This Useful Post:
DarkPira7e (01-24-2019)
Old 01-24-2019, 06:33 AM   #1250
johl
johl's Avatar
Drives: toyota 86
I always loved the pearl white used on the Toyota jzx100 chaser. I believe it is paint code 044
johl is offline   Reply With Quote
The Following User Says Thank You to johl For This Useful Post:
zeal86 (01-24-2019)
Old 01-24-2019, 07:40 AM   #1251
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The warmer championship white gets my vote. The warmer white does better in direct sunlight in my opinion. Your panel work is incredible
zeal86 (01-24-2019)
Old 01-24-2019, 01:02 PM   #1252
zeal86
zeal86's Avatar
Drives:
I love pearl white as well but since I want to be different, save money, and make color matching in the future easier (if needed)... I'm going to go with a non-pearl white. Plus, I may take part in the painting of my build if not all of it...so if I jack some part up... It wouldn't hurt me in the pocket book as much if I end up needing more paint and or materials.
IG @zeal.eightsix
johl (01-24-2019)
Old 01-24-2019, 01:08 PM   #1253
Ashikabi
Ashikabi's Avatar
IG @zeal.eightsix
My .02... A fancy car like the 86 (let alone over like yours) shouldn't have a bland plain color. My opinion.
Old 01-24-2019, 01:43 PM   #1254
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
The bodywork looks great! I can't wait to see the finished product!
+1 for championship white looking very "creamy".
eastendraceshop is offline   Reply With Quote
The Following User Says Thank You to eastendraceshop For This Useful Post:
zeal86 (01-24-2019)
Old 02-05-2019, 04:35 PM   #1255
zeal86
zeal86's Avatar
Drives:
So I've been busy with finishing the fitment of my fenders, skirt, and rear bumper extention. I made some adjustments on front fender that squared it up with the door. The front fender is getting close to being ready for paint and primer... I just sprayed it with a guide coat so I can eliminate any low spots. I'll be doing that with the skirt next.
I'll post pics once I have all my passenger side panels primed and temp installed.
IG @zeal.eightsix
DustinS (02-05-2019)
Old 02-18-2019, 01:50 AM   #1256
zeal86
zeal86's Avatar
Drives:
Here are some progres pics... I may mock up my L1 3P wheels tomorrow... stay tuned...
Minor tweaks to be made and a few more holes to be drilled but for the most part this side is done. I may start on my front bumper or rear bumper next before moving on to the driver side.
IG @zeal.eightsix
The Following 5 Users Say Thank You to zeal86 For This Useful Post:
arkanist (02-18-2019), DustinS (02-20-2019), Irace86.2.0 (02-25-2019), Lococholo84 (02-18-2019), Raven86Project (02-18-2019)
Old 02-19-2019, 06:49 PM   #1257
zeal86
zeal86's Avatar
Drives:
Sorry for the picture overload... Progress has been made... still working the rear bumper extention. Happy with how everything has turned out so far...
IG @zeal.eightsix
The Following 6 Users Say Thank You to zeal86 For This Useful Post:
arkanist (02-20-2019), Busybee (03-06-2019), DustinS (02-20-2019), ichitaka05 (02-21-2019), Irace86.2.0 (02-25-2019), wolffbite (02-28-2019)
Old 02-25-2019, 09:12 PM   #1258
zeal86
zeal86's Avatar
Drives:
I finally got around to cutting my rear bumper to fit my rear beam brace support for my swan neck chassis mount wing.
To make the perfect cuts... I found the center on both bumper and support as pictured. The result were basically the minimal width cuts I could make. However, I widened the openings up almost equally around to leave room for adjustments and/or movement.
Btw... the little black spots that look like miscuts are actually the black plastic underneath showing after I sanded and filed the edges...
I'm very happy with the end product!
What I did:
>>Measured centerline of both bumper and support brace.
>>Lined them up with a square.
>>Used a ruler and sharpie to make a dashed lines.
>>Connected the dashes with a white paint marker and ruler.
>>Used Dremel with cutting wheel, sanding drum, and file make my openings.
>>Cleaned the edges up with sandpaper on a piece of sheet metal.
Perfect alignment on first try!
IG @zeal.eightsix
Old 02-25-2019, 09:33 PM   #1259
Ashikabi
Ashikabi's Avatar
I advise you look for a way to reinforce the bumper cover itself since it had so little structure left in it. I expect it will vibrate/flap badly at speed
The Following User Says Thank You to Ashikabi For This Useful Post:
zeal86 (02-25-2019)
Old 02-25-2019, 09:37 PM   #1260
zeal86
zeal86's Avatar
Drives:
I have that thought out already... lol I'm installing 90º brackets that will be riveted to the brace and bonded on the inside of the bumper cover.
IG @zeal.eightsix
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 08:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 07:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
