Old 01-20-2019, 09:54 PM   #1
jflogerzi
jflogerzi's Avatar
Best mount for OFT on small side window
What do you guys use to mount your oft on the driver's side. Getting ready for first track event in the FRS and I want to monitor oil and coolant temps with the oft guage mode.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 01-23-2019, 02:28 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I have a no-name phone holder that does work for the oft, but it's not great. A better choice is something from Ram Mount, I know people use those on track to hold stuff.
Alternative suggestion:
I put mine in front of the redundant analog speedometer using dual-lock on the dash and steering column cover. I'm sure there is a better way to mount it there but it works for me for street driving. This way you can open and close the door without worrying about the cable.
Old 01-23-2019, 02:30 PM   #3
ROADRACER
Drives: unlimited cheap build N/A track car
I just used Velcro to temporarily mount it over the radio. Easy to read and reach there.
ROADRACER is offline   Reply With Quote
Old 01-23-2019, 09:59 PM   #4
H1C
Drives: 2014 FR-S MT
I think this would do the job if you want to mount on the small side window:
https://olivmounts.com/products/oliv...tion-cup-mount
I have the one that mates to a ProClip dash mount, and I've done auto-x runs in our bumpy lot with my pretty heavy phone left on it by mistake, and the phone didn't fly off. The magnets hold my OFT in place just fine when I'm data-logging on the street -- I think they'd hold up to track use too since the OFT is pretty light.
H1C is offline   Reply With Quote
The Following User Says Thank You to H1C For This Useful Post:
jflogerzi (01-23-2019)
Old 01-24-2019, 01:34 AM   #5
tjohnson104
Drives: brz
I use a mount that goes in the cd slot. Got it from target. Works great. Better then the 3 times I tried different window mounts. a cd can still be inserted with the mount in also just fyi
tjohnson104 is offline   Reply With Quote
Old 01-24-2019, 02:20 AM   #6
jflogerzi
jflogerzi's Avatar
Thanks but I have an AA head unit without a CD slot
Old 01-25-2019, 12:02 AM   #7
Xbk47
Drives: 2016 BRZ
Do you ave a link?
Xbk47 is offline   Reply With Quote
Old 01-25-2019, 01:23 AM   #8
tjohnson104
Drives: brz
Originally Posted by Xbk47 View Post
Do you ave a link?
here you go!
https://www.target.com/p/scosche-cd-...k/-/A-53460492
Old 01-25-2019, 11:33 AM   #9
Hot-Lava_Dave
Hot-Lava_Dave's Avatar
Drives: 2016 Hot Lava MT
I'm curious how your cable reaches in order to mount anywhere? The one that comes with the tablet is painfully short...
Hot-Lava_Dave is offline   Reply With Quote
Old 01-25-2019, 12:45 PM   #10
Xbk47
Drives: 2016 BRZ
You can order extension cables on amazon. I got one that has a toggle switch to kill the power to the OFT. I read of some people leaving their OFT plugged in and draining the battery.
The Following User Says Thank You to Xbk47 For This Useful Post:
Hot-Lava_Dave (01-25-2019)
Side marker small metal clips blackfireball5 Want-To-Buy Requests 13 01-04-2017 06:46 PM
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
small front window weather stripping ripping? nickmerronesucks Issues | Warranty | Recalls / TSB 3 09-13-2014 07:05 AM
Small window door issue (rubber seal) Subforever Issues | Warranty | Recalls / TSB 7 05-20-2013 05:32 AM
new small problem with window motor sweeney208 Issues | Warranty | Recalls / TSB 8 02-27-2013 10:57 AM
