Old 01-21-2019, 12:14 PM   #52249
cjd
cjd's Avatar
Drives: 2017 BRZ
This is fun. Furnace started acting up last week. Got someone out finally Friday, and he's stumped. Probably the gas valve needs to be replaced since it also controls the igniter, which is what sometimes chooses to not work. And "its an Armstrong, cheap contractor stuff" so parts aren't available and they have to research...
As of yesterday evening, it seems it is now not working 100%. It hit 6° last night outside. So I'm doing what you should not and manually lighting, because I don't even have a quote yet...
cjd is offline
Old 01-21-2019, 12:15 PM   #52250
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Kids are up skiing, wife is at work. I have a day to myself. What to do?
A hot bath?
I occurs to me, the Hums have adult relatives relatively nearby with their own house, and probably, a bath or two with an unbroken caloric converter.
bcj is offline
The Following 2 Users Say Thank You to bcj For This Useful Post:
spike021 (01-21-2019), Tcoat (01-21-2019)
Old 01-21-2019, 12:25 PM   #52251
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
I have annoyed people by pointing that out every time somebody said "hot water heater" for decades now. It is not a "hot water heater" it is a cold water heater or simply water heater. A hot water heater is called a boiler and makes steam.
PIN number
LCD display
VIN number
NIC card
ScoobsMcGee is offline
The Following 3 Users Say Thank You to ScoobsMcGee For This Useful Post:
spike021 (01-21-2019), Spuds (01-21-2019), Ultramaroon (01-21-2019)
Old 01-21-2019, 12:32 PM   #52252
PIN number
LCD display
VIN number
NIC card
MSDS Sheets
Tcoat is offline
ScoobsMcGee (01-21-2019)
Old 01-21-2019, 12:36 PM   #52253
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
A hot bath?
Didn't want to rub it in.
Sapphireho is offline
Old 01-21-2019, 12:39 PM   #52254
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Speaking of boilers... I took the time to clean my Rancilio Silva (w/PID ) espresso machine this weekend.
1 table spoon of citric acid in the water reservoir ran through. Then two reservoir's full of water flushed through the system. Also put a plug in the portafilter to create pressure to back flush the purge line with a pinch of citric acid. (the plug comes with the machine - standard procedure for cleaning)
Once I got this machine, I NEVER buy espresso drinks anywhere anymore. I bet it actually has saved me money in the long run. $3 to $4 coffee drinks add up quickly! (especially when My wife and I would buy two of them!)
I LIKE TIRES!
Leonardo is offline
Old 01-21-2019, 12:40 PM   #52255
Sapphireho
Famous Potatoes
Sapphireho's Avatar
MSDS Sheets
We don't need to compete with each other.
My favorite is "these ones".
Spuds (01-21-2019)
Old 01-21-2019, 12:50 PM   #52256
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I have the same machine!
Leonardo (01-21-2019), Ultramaroon (01-21-2019)
Old 01-21-2019, 12:59 PM   #52257
Originally Posted by cjd View Post
...And "its an Armstrong, cheap contractor stuff" so parts aren't available and they have to research......
Armstrong is the "low end" division of Lennox, seems odd that parts aren't available.
Dadhawk is offline
Old 01-21-2019, 01:12 PM   #52258
Leonardo
Country Boy 4 Life
Leonardo's Avatar
WOW! IDENTICAL!
We have the same car too!
via Imgflip Meme Generator
I LIKE TIRES!
Leonardo is offline
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Sapphireho (01-21-2019), Ultramaroon (01-21-2019)
Old 01-21-2019, 01:22 PM   #52259
WOW! IDENTICAL!
Yours is probably easier to get in and out of!
Tcoat is offline
Leonardo (01-21-2019), Sapphireho (01-21-2019), Spuds (01-21-2019), Ultramaroon (01-21-2019)
Old 01-21-2019, 01:37 PM   #52260
cjd
cjd's Avatar
Drives: 2017 BRZ
Well, technically it's an AirEase. Which is the low end of Armstrong? I have no idea how this stuff works. The part is made by Honeywell. I'm a bit baffled myself. "Low end" is, as I understand it, simply in the name being less well known. We'll see.
I signed up for their service plan this year (it's January, and I know something in the A/C is making a horrid noise outside, and they charge to come to your house otherwise... plus 15% off hardware) so however many trips it takes I guess. As long as I can keep manually lighting, I suppose. We've used the service folks before as have people we know, so I'm reasonably confident they're not a problem. Hopefully...
In a pinch we can move downstairs, it's a 2 furnace house. Maybe some fans to try to move air upstairs to avoid freezing. But I really don't want to do that.
It's only money in the end, right? Already looking forward to paying a ton more income tax this year... should be interesting to see if we've budgeted adequately for it all. edit: just got the call, they want $1300 and it's only a "probably" fix...
cjd is offline
The Following User Says Thank You to cjd For This Useful Post:
Dadhawk (01-21-2019)
Old 01-21-2019, 01:40 PM   #52261
ScoobsMcGee
Drives: 15 BRZ
MSDS Sheets
Broken EJ257
Spuds (01-21-2019)
Old 01-21-2019, 01:42 PM   #52262
PIN number
LCD display
VIN number
NIC card
MSDS Sheets
We aren't competing. We're commiserating.
PCB board.
Ultramaroon is offline
ScoobsMcGee (01-21-2019), Spuds (01-21-2019), Tcoat (01-21-2019)
