Old 12-24-2018, 04:14 PM   #127
jflogerzi
jflogerzi's Avatar
I decided to cancel my order for now. I am waiting for other to post a review. I am mainly tired of the noise my current uel header makes. So I am going back to stock header for the time being and swapping my exhaust for a nicer and hopefully more mature sounding catback. Once summer hits or there are more proven dynos with OFT tunes I will consider it.
Looks good and typical JDL quality.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
R_E_L (12-24-2018)
Old 12-24-2018, 04:31 PM   #128
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
It's tempting to buy one of these despite my Nameless Performance/ Cosworth header holding up just fine. Oh holidays... :S
MS, CSCS, TSAC-F, CPT
Old 01-03-2019, 01:16 PM   #129
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
An update: My header has arrived and I will be picking it up Friday!
Possibly the first person in Canada to receive one, however probably won't be the first one running it on the car. Can't install and tune until spring as my car is stored for the winter.
JBezugs is offline   Reply With Quote
Old 01-03-2019, 01:24 PM   #130
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Originally Posted by R_E_L View Post
Well, Christmas came a day early for me
It was pretty well wrapped but at some point the flange must have taken a smack. It shouldn't really be an issue though right?
Oh and my dumb butt managed to squash the merge collector gasket while trying to put everything away again.
Now I will tuck it away somewhere until tax season lol. I'm not picking up the flex kit or EcuTek stuff til then. For the others who picked one up, have you guys installed yet?
Don't use those gaskets. They are garbage. I had to buy grimmspeeds and replace them shortly after install.
Sent from my Pixel 2 XL using Tapatalk
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following User Says Thank You to Roadcone For This Useful Post:
R_E_L (01-03-2019)
Old 01-03-2019, 03:53 PM   #131
TMF
TMF's Avatar
Drives: '14 FRS TT5
Mine arrived last week too. I'll be installing soon, but I won't be running it or getting it tuned until spring as mine is also in storage mode. Can't wait!!
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
The Following User Says Thank You to TMF For This Useful Post:
R_E_L (01-03-2019)
Old 01-15-2019, 11:44 AM   #132
JBezugs
Good Job Subaru!
JBezugs's Avatar
JDL 4-2-1 EL header
For the lack of quantifiable dynos at the moment (save for the JDL dyno on their website), I got a little nerdy this weekend.
I took some existing dyno numbers from Drift Office that were available that had a baseline for the stock BRZ and a JDL UEL header which you can find here.
From there, I extrapolated gains for the new 4-2-1 EL header vs stock. Since the 4-2-1 was compared against the JDL UEL header on the dyno from JDL; I could get a rough idea of the gain over stock from the Drift Office dyno using percentage gain of the 4-2-1 vs the UEL on JDL's dyno numbers at each 100RPM datapoint and then applying those values to the Drift Office JDL UEL numbers.
Keep in mind that this is very high level and does not include differences in tuning, etc.
Interactive version
Interactive version
The Following 3 Users Say Thank You to JBezugs For This Useful Post:
jflogerzi (01-19-2019), Pinoy_FRS (01-16-2019), PulsarBeeerz (01-15-2019)
Old 01-19-2019, 01:07 AM   #133
jflogerzi
jflogerzi's Avatar
Waiting for those results boys and girls. Get those headers on and show me some dyno numbers so I can spend more money!
Old 01-19-2019, 01:19 AM   #134
PuslarBrrrz
Didn't JDL dyno it against there own UEL header?
PuslarBrrrz is offline   Reply With Quote
Old 01-19-2019, 08:47 AM   #135
TMF
TMF's Avatar
Drives: '14 FRS TT5
They did, but it always helps to see more independent dyno results.
Mine are sitting in the box.... I'm anxiously waiting for Spring.
Old 01-27-2019, 12:45 PM   #136
TMF
TMF's Avatar
Drives: '14 FRS TT5
Got the new JDL 4-2-1 EL header, op, and fp installed yesterday. It only took a little massaging to get the headers in but not bad and clearance is pretty good. I cleaned up the mounting holes with a dremel and used a dead blow hammer to just bend in this part a little (see photos below) - it was pretty tight and made fitting them in a little tough. Didn't need to bend it much though. It looks like just an extra piece of sheet metal over the lower part of frame. Not sure if it was absolutely necessary to bend, but it did seem to make them go in easier.
Other top tip... Put in the overpipe before you put the new headers on. Ask me how I know.
Videos of the exhaust and weight savings are on my Instagram page: Instagram.com/jhillmotorsports
I can't wait until spring to get this thing tuned and drive it!!
Old 01-27-2019, 01:22 PM   #137
jflogerzi
jflogerzi's Avatar
You might want to let JDL on what you did for more clearance.
Old 01-27-2019, 03:28 PM   #138
jflogerzi
jflogerzi's Avatar
You might want to let JDL on what you did for more clearance. Feedback is always good.
Old 01-28-2019, 10:01 AM   #139
tobin
tobin's Avatar
Drives: '13 BRZ
Hmmm...wonder if they will revise the second batch to fix these clearance issues?
tobin is offline   Reply With Quote
Old 01-28-2019, 10:08 AM   #140
Roadcone
StreetKart
Mine only has a minor clearance issue on the aluminum undertray on one runner and I passed that info on to Jesse. I assumed it was due to worn out engine mounts on my car. The mounting holes that bolt to the heads are just very precise you have to be dead on straight when you install it.
The Following 2 Users Say Thank You to Roadcone For This Useful Post:
TMF (01-28-2019), tobin (01-28-2019)
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
