Southern California SoCal
Old 01-18-2019, 01:58 PM   #15
Originally Posted by Akuma-ZN6 View Post
Same here, Unless somebody knows a dealership in socal that takes modded cars. Not looking forward to swapping parts back and forth....
Have you checked to see if you have to swap parts? In other words, could you just pull the parts, tow the car in and let them finish the work? Might save you a little time/effort. Don't know that the process requires a running car or not but its a question I would ask before swapping equipment twice.
Akuma-ZN6 (01-18-2019)
Old 01-18-2019, 02:02 PM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
This is a great idea. I would drive it to the service guy and have him point to which parts are a problem. say, "Ok, I'll take those off".
Brilliant.
Old 01-18-2019, 02:15 PM   #17
DarkSideFRS
Drives: 2013 pearl white FR-S
has anyone changed out the TOB during the recall? If u did, how much extra did the dealer charge u? Lastly, is the tranny fluid changed out for the recall? I don't think it is, but just making sure
DarkSideFRS is offline   Reply With Quote
Old 01-18-2019, 03:30 PM   #18
Akuma-ZN6
Akuma-ZN6's Avatar
Drives: Hot Fire
Brilliant.
That's great advice, I will check with the service department.
Akuma-ZN6 is offline   Reply With Quote
Old 01-18-2019, 03:35 PM   #19
Akuma-ZN6
Akuma-ZN6's Avatar
Drives: Hot Fire
Great idea!
Old 01-18-2019, 04:29 PM   #20
Jeffboyarrdee
Jeffboyarrdee's Avatar
Drives: 2013 Subaru brz limited wr blue
Update:
1. I’ve found out so far that Toyota dealerships will not take a Subaru. (So far, maybe in other places they do or it’s case by case)
2. So far the dealerships I’ve spoken to will want modified cars to be turned back to stock first before being worked on.
3 dealerships are allotted money/hours for these recall repairs, so they aren’t inclined to take modified cars due to the extra time it possibly could take as well as there are so many variations that a car is modified. (Brand to brand differences as well as types of mods)
If anyone has different experiences either northern or couthern California that would probably help others, but as of now I may have to resort to going back to stock. Huge headache.
Jeffboyarrdee is offline   Reply With Quote
Old 01-18-2019, 07:37 PM   #21
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
Originally Posted by DandoX View Post
I was in the same boat but ultimately decided to take it to Longo.
What was your experience with Longo? Considering driving the car up from SD to get it done there as not too many people seem to have had their work done at San Diego dealerships
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
Old 01-18-2019, 09:27 PM   #22
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I have zero experience with Longo or Tustin, I moved down to SoCal from the bay area in November. This is purely based on limited research and word of mouth. I also called both dealerships more than once to get a feel. I think both will do a good job but it appears Longo is going to be one of the bigger hotspots for folks getting their cars done I thought it best to take mine there as well.
DandoX is offline   Reply With Quote
Old 01-22-2019, 02:42 PM   #23
DarkSideFRS
anyone have any experience with Toyota of Anaheim, Tustin Toyota or Autonation in Cerritos?
Old 01-22-2019, 11:29 PM   #24
bored@work84
bored@work84's Avatar
Drives: H8R 86
Will I have a problem since i removed the stock front pipe with cat.
bored@work84 is offline   Reply With Quote
Old 01-23-2019, 12:02 PM   #25
Thaeyo
Thaeyo's Avatar
Question, does this sound right to you guys. Called Tustin Toyota, car is flagged as needing recall. But they say they need to do an inspection first to see if I need the replacement? I thought recalls were done regardless?
Thaeyo is offline   Reply With Quote
Old 01-23-2019, 03:19 PM   #26
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
I saw one guy being rejected for the recall because he had a used engine from a newer year in the car. But as long as you have the original engine that corresponds to your VIN then you should be fine.
Also they inspect it to make sure everythings oem.
Decimus is offline   Reply With Quote
Old 01-24-2019, 02:29 AM   #27
Thaeyo
Thaeyo's Avatar
I ended up calling Irvine Toyota, they ordered the parts for me without inspection. Says it should take a week in and then they'll schedule me.
Wait time at Tustin Toyota is minimum 2-3 weeks
Old 01-24-2019, 09:19 PM   #28
dkdnt232
Drives: 2013 subaru brz, 1979 toyota hilux,
i made an appointment to have my car taken care of in subaru of san bernardino.
i was given an appointment in July. apparently they are booked all the way!
the lady showed me the calendar and they had 4 cars scheduled every weekday starting in february.
dkdnt232 is offline   Reply With Quote
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
Dealer recommendation for valve spring recall: South of Seattle rice_classic Northwest 8 03-17-2019 03:06 AM
Valve Spring Recall Resolved!!! hgamit Issues | Warranty | Recalls / TSB 32 02-23-2019 10:00 PM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 08:44 PM
