Old 01-16-2019, 05:02 AM   #1
Eazy-V
Replacing Connecting Rods
I know one of the main weak points of the FA20 is con rods, so has anyone just replaced the oem con rods with some forged ones while keeping all the other internals oem? Will this require engine break-in or no?
I’m currently hitting 400whp on E73 on all stock internals, so I just want beefier con rods to prevent bending them at this power level.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 01-16-2019, 08:09 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Aftermarket rods will not work with stock pistons. They could be machined to fit, but it's not really worth the expense since pistons aren't that much money. I want to know if anyone has used WRX fa20 rods.
Old 01-16-2019, 11:23 AM   #3
Fred E
Drives: WRB BRZ
I don't think there's much point in using WRX FA20 rods over forged aftermarket, since aftermarket options are both stronger and lighter. WRX rods break just as much as BRZ rods do, if not even more often. I do agree with your point that it's not worth the expense of only replacing the connecting rods and leaving the pistons alone, as they are also a possible failure point.
To the OP's other question, if you're replacing connecting rods, I'd hope you're also replacing bearings, which would most certainly require a break-in.
Fred E is offline   Reply With Quote
The Following User Says Thank You to Fred E For This Useful Post:
celek (01-23-2019)
Old 01-17-2019, 12:12 AM   #4
Eazy-V
Yeah I’ll be replacing the bearings, so I guess no way to avoid break-in and if no aftermarket conrods fit the OEM pistons then rings and etc have to be done.
Old 01-23-2019, 09:16 PM   #5
celek
Resident Gear Head
celek's Avatar
If you are going to tear it all the way down to the rods might as well toss pistons in. As for break in I am willing to bet your cylinders are still in a condition to break new rings in anyhow.
Once you fix one weak link the next one to fail in line pops up. do you want to tear it all the way down 2 times?
celek is offline   Reply With Quote
17 86 not connecting to iphone 8+ by bluetooth Grey86 Electronics | Audio | NAV | Infotainment 6 04-27-2018 09:16 PM
FBM 1000Hp Forged Connecting Rods FullBlown Forced Induction 75 10-08-2013 10:45 AM
Need Aftermarket Connecting Rods ASAP Synack Engine, Exhaust, Transmission 8 02-05-2013 06:02 PM
Ditching the Asymmetrical Connecting Rod WingsofWar Engine, Exhaust, Transmission 7 10-02-2012 09:38 PM
