Old 01-14-2019, 08:02 AM   #99
gpvecchi
gpvecchi's Avatar
Sorry, what's Wi-Fi for? Android Auto needs cable...
Old 01-14-2019, 11:18 PM   #100
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
I thought it was for screen mirroring?
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
Old 01-15-2019, 12:28 AM   #101
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Mirroring on iOS is wireless. The iPhone connects to the WiFi from the headunit.
el-guapin is offline   Reply With Quote
Old 01-15-2019, 03:59 AM   #102
gpvecchi
gpvecchi's Avatar
I had an iPhone before, it never worked...
Old 01-15-2019, 05:15 PM   #103
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Works fine on my android. I use it for mirroring torque pro onto my HU as I'm not really keen on using the XDA patch workaround.
wolffbite is offline   Reply With Quote
Old 01-15-2019, 06:06 PM   #104
gpvecchi
gpvecchi's Avatar
I think that Pixel 3 doesn't support Miracast. I think this is the standard for the DDX, right?
Old 01-15-2019, 06:41 PM   #105
wolffbite
Just the tip
wolffbite's Avatar
As far as I know yes. I'm using an LG G6 on Android 7.0 for reference.
Old 01-17-2019, 05:37 AM   #106
Varelco
Drives: '15 GT86 & '22 GR86
I was wondering if you could do that...
So when it comes to screen mirroring does it behave like an app? As in, can you close the screen mirror and open up waze or the radio then return to the screen mirroring, or does it not work like that?
not sure if that makes sense.
Varelco is offline   Reply With Quote
Old 01-17-2019, 10:56 AM   #107
wolffbite
Just the tip
wolffbite's Avatar
It will replicate your phone screen on the headunit, and because it has 2 way mirroring will allow you to control it from either the phone OR the headunit touchscreen at the same time. You can view any app you want on your phone while mirroring, but android auto/apple carplay would not be available since the connection is wireless and this specific headunit only supports a wired connection for those apps.
Old 01-17-2019, 09:37 PM   #108
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
You probably needed this patch...
Apple iOS 11 Wireless Mirroring for Kenwood DDX917WS & DDX9017DABSs/
Old 01-18-2019, 04:19 AM   #109
gpvecchi
gpvecchi's Avatar
Thanks, but I'm already on a newer firmware
Old 01-18-2019, 07:51 AM   #110
5H1F7Y
Drives: 2017 BRZ Premium
Anyone have issues with Android Auto locking up all the time with this HU? between that, and spotify app not connecting and garbage radio reception I'm about ready to ditch the unit.
S9+ Latest firmware on the HU
5H1F7Y is offline   Reply With Quote
Old 01-18-2019, 01:31 PM   #111
wolffbite
Just the tip
wolffbite's Avatar
First thing I would do is try a different cable. I see that the S9+ uses a USB type-C, and there are a ton of cheap cables out there that are not specced correctly for the newer standard. A cable longer than 3' can also cause issues.
Regarding your poor radio reception, I have no idea. Mine is just as good as the stock headunit... double check connection, see if any wires are loose/frayed?
Old 01-18-2019, 01:46 PM   #112
5H1F7Y
yea, tried the cable. radio signal i think might be something with the signal amplifier. Im using the carbon wiring harness, so ill have to check the pins on that to make sure its getting power. The spotify issue could be a software version as well. im hoping to try some legacy versions at some point. Bluetooth works for now
Kenwood DDX916WS head unit -- any installed? willimusk Electronics | Audio | NAV | Infotainment 39 07-27-2017 10:47 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 03:37 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 06:44 PM
Soo i installed a new head unit....gaps Sniper2606 Electronics | Audio | NAV | Infotainment 2 01-16-2014 05:12 PM
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 12:07 PM
