#1457 | |
Drives: 2015 BRZ
#1458 |
Drives: 2014 Subaru BRZ
If you're doing the TOB, you might as well do the clutch too. The whole job can be done by any competent mechanic and isn't particularly difficult and doesn't require any unique tools.
Texas Track works, G Speed, PRT Performance, or Doghouse Performance can all do it if you want a performance shop; however, if you have or know of an independent mechanic that is trustworthy and competent, they can do the work without any problems. |
#1459 |
Drives: 2013 Scion F-RS
Hey all, new user and new FRS owner here. Just wanted to say hello and check out some of the incredible builds people have going on. Enjoy your week and watch for idiots (and speed traps)
#1460 |
Drives: 1995 Ford Probe
Has anyone dealt with Growler Motor Labs (formerly known as Cobb of Plano) with Installing front pipes on their Subaru’s?
I want to bring my BRZ in to replace the stock overpipe with a Tanabe overpipe, stock frontpipe with a Megan Racing catless but resonated frontpipe, and lastly stock exhaust with Invidia N1 dual exhaust system. They said they can’t install the frontpipe because it’s catless? But anyone that knows the BrZ, knows it has 2 cats. I’m not replacing or upgrading the header system. So as long as I still have 1 cat I am still legal as far as catalytic converter requirement correct? It’s weird because everyone I know with a WRX or BRz/FRS has a catless front pipe. Any input? |
#1461 |
Low-Buck Ramp Truck
Drives: 2016 Scion FR-S Release 2.0 #502
Probably the law is written that they as a shop can not remove ANY cat from a street vehicle or “tamper” with any emissions device.
The exhaust is really easy to work on. I hear the overpipe can be tricky. Maybe a buddy with some beer and a wrench could assist?? |
#1462 | |
You'd be better off with a catless header and a high flow catted front pipe (almost all the power gains is from the catless header). The exhaust isn't too tough to do, I did mine in the parking lot with jack stands (just remember to wd40 the exhaust hangers, and some setups have a couple of bolts that can be a pain to reach). I installed a full exhaust on my old WRX solo in my apartment parking lot, I had to use the floor jack as an extra set of hands (along with a leg) to mount it all. Exhausts are just pipes, the only way to screw up is to not tighten everything and then you smell exhaust, get back under the car, and tighten that shit down. If you aren't doing headers, I wouldn't do anything more than just the mufflers since your only gains will be in sound. You're looking at a morning/afternoons worth of work (2-3hrs depending on how many beers you drink while doing it), an extra set of hands makes it easy but it can be done solo without any real problems. |
#1463 |
Has anyone had any issues with TX emissions inspections with a catless front pipe in the DFW area?
#1464 |
The inspections in Tarrant county (where I live) are an OBDII test. I've got a catless header and a high flow catted front pipe and haven't had any issues with inspections (basically as long as you don't have a CEL you're usually good to go).
#1465 |
Drives: 2015 BRZ
I have a catless front pipe, but stock header and i have zero problems passing inspection. Also, the cat on stock front pipe isnt even monitored so it doesnt matter if you remove it. As far as i know our inspections are done with an ODBII and they just check to make sure theres no CELs or codes.
#1466 |
Reverse Burnouts
Drives: 2013 Argento FRS
has anyone sent their car into a dealership for the recall? I'm really doubtful of toyota techs in our area. (valve spring issue)
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#1467 |
Drives: WRB BRZ
Just set up an appointment. Seems like a long wait - my appt isn't until end of March... Sewell Subaru dealership though so they always provide top notch service.
#1468 |
Reverse Burnouts
I've got a scion. I have even less expectations from techs that dont work on boxer engines lol
#1469 | |
Drives: 2013 FRS, 2024 Trueno
Toyota of Plano has done one and I just drove that car on track yesterday, all good. Lonogo Toyota in Prosper has done a couple. I still need to set it up for mine.
#1470 | |
Drives: WRB BRZ
| Gundam Universe - General All Discussion Thread | poormans_LFA | Off-Topic Lounge [WARNING: NO POLITICS] | 273 | 03-23-2014 11:45 PM |
| 2013 FR-S Info Sheet (General Facts) | xravexboix | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 04-29-2012 05:12 PM |
| General info on the 86 translated from Toyota Japan | WTF | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 02-24-2012 05:57 PM |
| Push button start general question | maxeveland | Other Vehicles & General Automotive Discussions | 9 | 02-14-2012 10:13 AM |
| General FT-86 musings around the world | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 01-01-2010 10:29 PM |
