Old 01-12-2019, 10:44 PM   #43
suzyj
Drives: 2018 86 GTS
I drilled and tapped the metal plate for an M3 screw that acts as a new stopper. Works very well - the boot closure is nice and positive without being ridiculously hard. I imagine a slightly softer spring might also be of benefit.
suzyj is offline   Reply With Quote
The Following User Says Thank You to suzyj For This Useful Post:
Ultramaroon (08-02-2021)
Old 02-20-2019, 06:18 PM   #44
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Mine is about to shear off again... and I'm at ~35,600 miles. Time to visit the dealership one last time?
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 01-27-2020, 11:38 PM   #45
spike021
spike021's Avatar
Just realized I don’t think I ever had the rubber nub/cap thing... since day 1 I’ve had to close the trunk just right for it to latch. The past year occasionally it unlatches on its own... usually on the highway. But very infrequently. But the past two days it’s happened twice. I was comparing with a friend’s FRS today and noticed he has the rubber thing but I don’t, and I’m 90% sure I never had it from the start.
I don’t know for sure that not having it is why my trunk has been getting unlatched randomly but I’d like to test it. Is there a part number for it?
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 01-28-2020, 12:08 AM   #46
AJ32162
Drives: 2019 BRZ with Performance Package
Part Number: 57531CA010 (Striker - Trunk Lid). Cost is about $20.
AJ32162 is offline   Reply With Quote
The Following User Says Thank You to AJ32162 For This Useful Post:
spike021 (01-28-2020)
Old 01-28-2020, 12:57 AM   #47
dhuang
dhuang's Avatar
If you're just missing the rubber bumper, just buy them from Advanced. I gave up after the dealership replaced it, as it eventually came apart again.
You get three in this six pack that work for our cars for $4 -- I treat it as a consumable item now.
https://shop.advanceautoparts.com/p/...75d/11911197-P
2017 Series.Yellow
2013 Whiteout
The Following User Says Thank You to dhuang For This Useful Post:
Old 01-28-2020, 03:50 PM   #48
spike021
spike021's Avatar
Thanks! I got a pack and put one on.
So far it’s still just as annoying to shut the trunk as it’s always been. But hopefully at least it’ll stop it from popping open on its own.
The Following User Says Thank You to spike021 For This Useful Post:
dhuang (01-29-2020)
Old 09-18-2020, 04:38 PM   #49
IvoryHammer
Drives: '17 BRZ PP
How's the aluminum shim holding up over time? Curious to know if a steel shim would work any better.
IvoryHammer is offline   Reply With Quote
Old 09-19-2020, 04:00 PM   #50
Here's mine.
Pro Tip: Scuff and clean mating surfaces before jb weld
Old 12-23-2020, 04:51 PM   #51
gpvecchi
gpvecchi's Avatar
I just noticed that I don't have any rubber thing inside my striker...
I didn't notice any issue.
Old 08-02-2021, 11:21 AM   #52
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Originally Posted by suzyj View Post
I drilled and tapped the metal plate for an M3 screw . . .
I like your solution. Here is a picture of how I implemented it. I did rotate the rubber bumper 180 degrees after taking the picture so it's more square with the trunk lid part of the latch and will hopefully last a while longer. Thanks!
LimitedSlip is offline   Reply With Quote
2017 Toyota 86 Trunk Lid GrayFox_27 Want-To-Buy Requests 0 06-23-2018 01:48 PM
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
TRADE: 2017 BRZ trunk and wing for wingless trunk?? Moto CANADA 0 05-19-2018 04:21 PM
WTT 2016 limited trunk for 2017 trunk Ignore Your Doctor Southeast 0 08-27-2016 10:32 AM
