Old 01-09-2019, 05:08 PM   #2941
Silvermk2
Drives: Toyota Supra 2JZGTE VVTi
Why not just pull the fuse if you're that worried about it? I leave mine sitting for weeks at a time with no issues.
Silvermk2 is offline   Reply With Quote
Old 01-09-2019, 06:02 PM   #2942
BertoFT
Drives: 13 FRS Firestorm
Originally Posted by toast View Post
Has anyone connected the LTR pump to another switched current source? Car is going to be sitting for a week in freezing weather in an airport parking lot and I don't want the pump running every time the car does a pressure check on the EVAP system and come back to a dead battery.
I've left my car at the airport for 2 weeks straight. She started right up, no problems. I was mostly worried about my tire pressure because of the temperature (40-50F)
Sent from my SM-G9600 using Tapatalk
BertoFT is offline   Reply With Quote
Old 01-11-2019, 11:14 AM   #2943
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Same here, left for weeks while away for work and starts right up. I'm pretty sure it was taken into account when the car was designed and having a supercharger wouldn't have any effect on that circuit. Are you still using the stock battery size?
B T is offline   Reply With Quote
Old 01-11-2019, 12:40 PM   #2944
toast
Drives: 14 BSP Edelbrock BRZ
Running the EVAP system test draws very little current; having a multi-amp pump running at the same time is not what the system was designed for. I've walked in to my garage at all hours and heard they system test running; if it does it a lot in below freezing temperatures for a week that could be a current draw.
I will pull the fuse for now, that takes care of it.
toast is offline   Reply With Quote
Old 01-11-2019, 10:57 PM   #2945
colushi808
Drives: 2017 Toyota 86
Let me just put this here. I was looking for something like this before I installed the supercharger and couldn't find one.
2017 Toyota 86. Everything stock. Edelbrock 2017 Toyota 86 tune.
258.6 hp +97.4 hp, 198.9 tq +64.3 tq
Installed 2 days ago and loving it so far. But need new tires now...
Sent from my SM-G965U1 using Tapatalk
colushi808 is offline   Reply With Quote
The Following 3 Users Say Thank You to colushi808 For This Useful Post:
CounterSpace Garage (01-14-2019), Dadhawk (01-12-2019), StraightOuttaCanadaEh (01-12-2019)
Old 01-12-2019, 09:52 AM   #2946
Wes
What's fuel consumption like?
Instagram: @gt86ws
Old 01-12-2019, 10:56 AM   #2947
colushi808
Not sure yet. Drove less than 80 miles. Dont know how accurate the mpg estimates on the dash is but I noticed the real time estimates dip into the single digits when starting in 1st (3mpg) and 2nd gear (6mpg). Never noticed it going that low that often before. I know before the supercharger I got 250-260 miles from a full tank to the light coming on. I'll check on it the next full tank I fill. I live in Hawaii and work close to home so not that much freeway driving and filling up gas.
The Following User Says Thank You to colushi808 For This Useful Post:
Old 01-12-2019, 12:03 PM   #2948
Silvermk2
I think mine in the 4-5k miles I have it I've been averaging around 22-23mpg. I probably got around 28 before the supercharger. I think you might be able to get 26-28 on the freeway the problem is anytime you give it throttle it drops into the single digits.
The Following User Says Thank You to Silvermk2 For This Useful Post:
Old 01-12-2019, 03:36 PM   #2949
toast
Put me down as a record for fastest bypass valve failure. On my third tank of gas and the car is very unhappy when cold. Been flashing map updates from Zach so it is hard to separate a new flash deadband vs a real problem. Put my mityvac on the line that goes to the bypass valve - less than 5 in of Hg the vacuum holds. But as soon as it goes above six and the valve starts to move it drops like a rock.
Old 01-12-2019, 05:13 PM   #2950
Wes
That's basically what's pushing me towards the turbo. I hear fuel consumption tends to run higher with an SC. I drive a lot so the difference would definitely be felt
Instagram: @gt86ws
Old 01-12-2019, 06:16 PM   #2951
mrg666
pessimistic skeptic
mrg666's Avatar
You cannot generalize that way. My fuel consumption is the same, if not better, with supercharger, of course when driven normally.
Old 01-12-2019, 11:54 PM   #2952
toast
The number of bypass valve failures is pretty ridiculous that I've seen. I understand why you would use a vacuum actuated device to move the valve, but I'm going to research using a second MAP sensor connected to an Arduino that will drive a magnetic linear actuator to control the bypass valve. That will also give me more control over when and how fast the valve responds to throttle inputs.
Any Arduino programming experts out there?
Old 01-17-2019, 11:22 AM   #2953
toast
Can someone explain why the PCV side of the engine gets kept in 'closed loop' by entering the intake after the throttlebody but the driver side gets essentially vented to atmosphere (deposited into the intake after the air filter but before the MAF)?
Old 01-17-2019, 03:06 PM   #2954
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's not VTA. It's still under vacuum. It's also the same way it's done on the OEM intake setup.
.: Stealth 86 :.
Kodename 47 DJ:
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
