Old 12-28-2018, 05:08 PM   #3515
dstrout
dstrout's Avatar
I’ve got a 2013 with 60K miles on it, and have tracked it about 15 days a year for the past couple of years. Runs like a top - no issues at all. I have not changed coil packs yet. Power train is stock except for an OFT E85 tune. (Hopefully I didn’t just jinx myself). 2013’s may have statistically more issues but they are by no means a sure failure.
dstrout is offline   Reply With Quote
Old 12-30-2018, 11:19 PM   #3516
dutchman1
Drives: 2017 86 6-Speed
New to STX this coming year.
I'm aware this will take some individual tuning, but just as a starting point, what pressures are you guys settling on for 255 re71rs?
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 12-31-2018, 11:25 AM   #3517
conedodging
conedodging's Avatar
Drives: '14 BRZ
It will definitely be setup and surface dependent. Here's where I was at with the 255 re71
29 psi Front
27 psi Rear
400 lb springs (x4)
Strano FSB
I don't have alignment in front of me, but I want to say
3.2 deg camber Front
slight toe out
2.5 deg camber Rear
0 toe.
conedodging is offline   Reply With Quote
The Following User Says Thank You to conedodging For This Useful Post:
dutchman1 (12-31-2018)
Old 12-31-2018, 12:47 PM   #3518
cjd
cjd's Avatar
Drives: 2017 BRZ
As low as 25psi, as high as 29psi (if I remember right). Usually ~1psi lower in the back. I've run 245's the last 2 years, 255's my first 2, but will be back to 255's now that I ended up 'upgrading' to a '17 from a '14 (will be the first set of tires I've purchased since that happened...)
The Following User Says Thank You to cjd For This Useful Post:
Old 01-10-2019, 11:31 AM   #3519
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Whatever my pyrometer dictates. :-) 28-32psi is usually the landing zone after I review temps.
Lincoln Logs is offline   Reply With Quote
Old 01-10-2019, 01:10 PM   #3520
cueball89
Drives: 15 Impreza
Is there a functional reason most seem to go with a 17x9 et35 vs a 17x9 et45? I was planning on joining stx and slowly building the car up. I just bought coilovers then saw a smoking deal on 17x9 et 45 wheels which I also had to buy.
cueball89 is offline   Reply With Quote
Old 01-10-2019, 01:18 PM   #3521
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
The 35 offset wheels can fit most of the front brake kits (like the AP Sprint kit). The 45 offset wheels will not, at least not without spacers. You also get a slightly wider track width or more flush (bro) with the 35 offset.
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
cueball89 (01-10-2019)
Old 01-14-2019, 11:03 PM   #3522
dvalue
Drives: 15 BRZ
What's everyone's exhaust setup?
Currently running Gruppe-S headers and OP with stock hardware the rest of the way back. Looking for something for something a little lighter, but don't want anything that is in your face loud.
Delta/CENLA Region SCCA - DS
dvalue is offline   Reply With Quote
Old 01-15-2019, 04:03 PM   #3523
cjd
cjd's Avatar
Drives: 2017 BRZ
A few lbs is possible... But much more and quiet is the rare Ti or custom build.
Check the exhaust weight thread. I haven't found much more data outside that
To address the question, Ace350, 3" catted/resonated FP (about the same as stock I think), Thermal CBE (only -2.5lbs, was told 10... oh well)
Old 01-15-2019, 08:36 PM   #3524
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I have 17x9+45 RPF1's and they rub the inner fender at full lock, no clearance issues at all with coilovers (OE coilover would be tight, maybe impossible depending on camber bolt situation) but I have extended studs (I broke 2 OE studs and just swapped them all) and run a 5mm spacer all the time on both street wheels and the 17x9 autox wheels. You won't notice on an autox course but you will likely rub when parking, unless you have the diligence to never turn the wheel to full lock. I think a 2mm or 3mm spacer is ok on stock studs and might get you some clearance but triple check that one.
Also in for exhaust suggestions, tried Nameless Axleback (muffled Dual Exit) and did not like, moderately tempted by TRD, Perrin 2.5" Resonated, or CSG MXP but mostly for jack clearance, not too disappointed by the stock muffler but I'm secretly an old man. Anything quiet is within 10 lbs of stock anyway so I'm just going to not spend money and just keep an eye out for a ridiculous deal on one of those used and local and try and lose weight instead. And maybe take a hammer to the stock muffler for that jack clearance.
ineedyourdiddly
Old 01-15-2019, 10:01 PM   #3525
cueball89
Drives: 15 Impreza
I'll keep an eye out for clearance issues, thank you!
Old 01-16-2019, 12:16 PM   #3526
tony_r
tony_r's Avatar
Drives: '15 STX
Perrin 2.5" resonated sounds good and is decent for weight. Makes zero difference with exhaust weight, it's low and centered anyway.
+35-40 is the sweet spot for offset, I have the TR C4's. It did rub with +35 rear & 245's so went to +40 there. 5mm spacers and extended studs gives you options.
tony_r is offline   Reply With Quote
The Following 2 Users Say Thank You to tony_r For This Useful Post:
cueball89 (01-16-2019), strat61caster (01-17-2019)
Old 01-24-2019, 08:28 PM   #3527
dutchman1
Has anyone else had issues with the whiteline rear upper control arm camber bushings?
I installed them myself (bit of a pain but doable), however my alignment guys is having some issues. I was having the car corner balanced and aligned (by a local, reputable, race-oriented shop), and he found it impossible to corner balance the car because the bushings create enough friction to make it impossible to get the corner weights to settle right after making ride height adjustments.
I don't know if this is a common issue, but from this experience I'd recommend staying away from them because you'll wind up (like me) with a car that can be aligned, but not corner balanced.
Old 01-26-2019, 06:51 PM   #3528
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
If you want light you've gotta pay for titanium. Otherwise you're trading noise for weight. You know that quality, cost, speed triangle? Well for car parts it's quality, cost, performance.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
