Old 12-26-2018, 01:32 PM   #1
Obsidiank
10 Series Fanatic
Drives: Scion FR-S 10
My engine blew up four years ago, now they recall the valve springs
Long story short, two years into owning my 2013 FRS 10-Series, my engine blew up while I was going 80 on a highway. Loud bang, big puff of smoke.
I was stuck in the middle of nowhere but luckily had my car towed to a toyota/jaguar dealership. Fast forward four months and numerous phone calls with Scion/Toyota, they rebuilt my engine with all new parts...no issues since.
My original problem, broken valve spring causes the valve to fall into the cylinder where the piston hit and and cracked the block.
So now that there is this recall, I called the dealership that did my work and they basically told me I was probably one of the unlucky ones that actually had major problems before this recall. However, since they used a different part when they rebuilt my engine, I shouldn't need to do this repair again.
So for those thinking about whether or not to do this repair,...well mines a pretty bad case scenario
Check out my basic mod's guide for new FRS owners.
Obsidiank is offline   Reply With Quote
The Following 4 Users Say Thank You to Obsidiank For This Useful Post:
bcj (12-26-2018), ermax (12-26-2018), humfrz (12-28-2018), Ultramaroon (12-26-2018)
Old 12-26-2018, 02:48 PM   #2
How many miles were on the engine when it failed?
bcj (12-26-2018)
Old 12-28-2018, 12:25 AM   #3
Decep
Drives: 2013 FR-S Series 10
Why would they have used a different part? They use whatever part the manufacturer specs. Do you have the invoice with all the parts they ordered?
Old 12-28-2018, 07:38 AM   #4
Most likely because by then they had changed the part out at the factory and the "defective" one was no longer in production? Since he said the car was two years old at the time the rebuild came after the time of the recall.
I'm guessing of course.
Old 12-28-2018, 08:21 AM   #5
radroach
Drives: car
Here's two roller rockers in a side-by-side comparison you can clearly see the defect in the shaft/bearing that's pressed in:
Guessing a bad batch of them got mixed in on early production, a manufacturing lottery.
The Following User Says Thank You to radroach For This Useful Post:
Leonardo (12-28-2018)
Old 12-28-2018, 08:27 AM   #6
statik
Drives: 2017 RS3, 2013 BRZ, 2010 M3
is there an actual recall on this?
statik is offline   Reply With Quote
Old 12-28-2018, 08:34 AM   #7
http://www.ft86club.com/forums/showthread.php?t=131043
statik (12-28-2018)
Old 12-28-2018, 08:57 AM   #8
statik
yeah just found this, mine is outside the range affected it seems (0454)
Old 12-28-2018, 10:42 AM   #9
NOHOME
Drives: RAVEN
Just got this recall in the mail last night. Have not contacted Toyota yet cause not likely to get anything but damage control out of them.
Interesting that the recall mentions springs specifically, not rockers. Uses the word "Stalling" instead of "destroying itself"!
Correct me if I am wrong, but this seems like a major engine out job. I know how to change springs and rockers without removing the head, but I don't see it working in this application with this engine.
I cant see the economical solution being to pull the old heads, reinstall with new parts and send you on the way. The number of people calling to report problems from botching that repair would be huge. Would not be surprised if a new cylinder head assembly was not the economical fix.
NOHOME is offline   Reply With Quote
Old 12-28-2018, 06:13 PM   #10
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
You may want to recheck it at: https://vinrcl.safercar.gov/vin/vinLookup
My VIN ends in 00367 and it is affected.
davesrave is offline   Reply With Quote
Old 12-28-2018, 10:50 PM   #11
Lantanafrs2
Drives: 2013 frs red
I'm in same boat. New motor in 2014. Have to clarify with Toyota if possible.
Lantanafrs2 is offline   Reply With Quote
Old 12-31-2018, 08:06 PM   #12
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
My VIN ends in 00559 and shows up affected, haven't called Subaru yet to confirm (maybe the site is wrong).
slizoth is offline   Reply With Quote
Old 01-02-2019, 01:47 PM   #13
davesrave
davesrave's Avatar
I emailed Subaru and they confirmed that my car is on the recall list.
The Following User Says Thank You to davesrave For This Useful Post:
slizoth (01-02-2019)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
VALVE SPRING WORLD - PRESS RECALL Trap63 Issues | Warranty | Recalls / TSB 85 03-12-2019 11:38 PM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 08:44 PM
67k miles, will bring car in for valve spring recall, what else to fix down there? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 12-19-2018 12:59 PM
