Old 12-23-2018, 03:26 PM   #1
frscory
frscory's Avatar
Drives: 2013 scion frs firestorm red
Another direct injection thread! Yay!
Hello my fellow 86 brothers and sisters, i hate to do it to you but i bring you another direct injector thread... so i have a greddy turbo kit and I have had it on for a little over 15k miles. No problems at all!! But recently i started having bogging and hesitation around 3k rpm and it stutters and it isnt really happy. Anything above 3k rpm it is just fine. So i decided to pull out the direct injectors but now i feel i have wasted my time! Here are some pictures of what they look like and i just dont know if its bad or good. They all look pretty good to me except the passenger side aft injector. (Should be first picture) anything knowledge or advice would be greatly appreciated thank you!
frscory is offline   Reply With Quote
Old 12-23-2018, 05:50 PM   #2
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Are any of the teflon seals cracked? Any deformation? Now that you have them out, maybe you should get them cleaned and flow tested on a bench.
sly is offline   Reply With Quote
Old 12-23-2018, 06:58 PM   #3
frscory
frscory's Avatar
No, none of them are cracked or split. I can see if there is a flow tester near me! Thank you!
Old 12-23-2018, 08:15 PM   #4
Besides the stutter at 3K, was there anything else that pointed you to direct injectors? Seems like quite a leap.
Old 12-23-2018, 11:55 PM   #5
frscory
frscory's Avatar
Well when i was getting a tune from a remote tuner he said i was having knock at lower rpms and anything above 3k he said was fine. He then told me it was signs of direct injection failure. I replaced all coils and my spark plugs were fairly new.
The Following User Says Thank You to frscory For This Useful Post:
Ultramaroon (12-23-2018)
Old 12-24-2018, 12:04 AM   #6
Hmmm... :/
Old 12-27-2018, 02:03 PM   #7
frscory
frscory's Avatar
Update: I had the injectors flow tested and one of them was flowing 10% less than all the other ones. So i guess its time to buy a new injector!
Old 12-27-2018, 03:47 PM   #8
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
http://www.ft86club.com/forums/showp...5&postcount=27
Do yourself a favor and replace the entire set. I had the same brown scorch marks on my Direct Injector.
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
frscory (12-27-2018)
Direct injection/port injection explained? mike the snake Software Tuning 31 06-06-2021 06:17 PM
Direct Injection Delete Kit Carolina Dyno Engine, Exhaust, Bolt-Ons 4 06-26-2015 11:47 AM
direct injection cc size bulldog11267mad Forced Induction 5 12-03-2013 01:24 AM
Stock Direct Injection PSI Fenrir Engine, Exhaust, Transmission 18 05-17-2013 03:03 PM
Gasoline Direct Injection... DoogenBurns Engine, Exhaust, Transmission 5 05-21-2012 02:05 PM
