Old 02-12-2016, 10:24 AM   #15
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Id give it a couple of days and at least a 100 miles or more driving before you get too excited it may be related to some weird fuel trim learning or something else that only shows up after a while.
this maybe why people dont see it they only log just after a flash possibly and not after a week or so.
yea it might be back idk. it seems good sometimes but it started doing it after the oft tablet cord got loose while driving and set of some cluster codes and puts it in limp mode. cleared them all and this issue happened again.. otherwise it has been having alot of writing problem to the ecu, keeps failing to write. maybe ecu or the oft is shot
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 02-12-2016, 04:14 PM   #16
steve99
Drives: FT86
Write fails not good ,suspect its the obd socket in car worn or loose sockets. Try a short obd cable extender right angle one best as you car cable tie it in and it does not hang down. Then lug oft into other end that way your not further wearing the car socket, if it rearly bad you may need to refit a new obd socket in car.
Old 02-14-2016, 10:33 AM   #17
Grip Ronin
The Mechanic
Grip Ronin's Avatar
luckily its only 5 wires if i need to repin it lol
IG-Joey_Soul
Old 12-11-2018, 05:20 PM   #18
Mr_Eyo
Drives: 2017 Toyota 86
I've been getting the same weird logging issues too:. 15.05 commanded AFR, OL, light to medium throttle. Actual measured AFR looks fine, car runs great, no CELs, no write failures. The only change I made to fueling is I made the CL load comp tables have offsets that make it match the POL table. It generally runs richer than the OTS CL map.
Mr_Eyo is offline   Reply With Quote
Old 12-12-2018, 03:15 AM   #19
tomm.brz
Drives: brz 2017 hksv2
I followed 3 guys with OFT in the last year and all of them have that kind of offset in the logged command afr value
Old 12-12-2018, 03:54 AM   #20
steve99
Drives: FT86
During closed loop the rear 02 sensor can influence the commanded afr value log AFCorrection #3
If af#3 corrections not disabled then you will see some offset in commanded afr by the rear 02 sensor.
Old 12-12-2018, 06:20 AM   #21
tomm.brz
I see the offset also with rear O2 Disabled
Old 12-12-2018, 10:12 AM   #22
steve99
Drives: FT86
thats strange
did you disable (zero) both tables ?
Old 12-17-2018, 09:37 PM   #23
Mr_Eyo
So I logged almost everything I could find in OFT related to O2 and AFR for this and it looks like commanded AFR going to 15.05 under throttle correlates to something called a/f sensor voltage going below ~2V. There is no scaling matching this in the OFT defs I have; OFT has a front O2 sensor scaling in current, not volts.
https://datazap.me/u/protoformx/log-....96&tmax=15.06
I'll do more correlation analysis on this log in Octave after dinner.
Old 12-17-2018, 11:15 PM   #24
Mr_Eyo
OK, here are some plots for:
commanded AFR = 15.06
RPMs increasing
Fuel system = OL
https://imgur.com/a/Ym8HhIv
First pic has the x-axes all sync'd are time in seconds.
Second pic is just the bottom right 2 plots with the gaps taken out. X-axes are just samples, not time.
Is there a measured AFR limit of ~13.5 for CL?
Old 12-18-2018, 02:10 AM   #25
steve99
Drives: FT86
Post the oft log to www.datazap.me will be esier to read
Old 12-18-2018, 03:16 AM   #26
Mr_Eyo
If this is for me, I did in the post prior.
Old 12-18-2018, 03:56 PM   #27
steve99
Drives: FT86
you commanded AFR is not logging correctly what calid is your tune ? are you using OFT V4 tunes ?
commanded afr may be being offset by the rear 02 sensor readings can you log AF#3 ? or alternative disable rear 02 sensor corre ctions by zeroing the two AF#3 correction tables
the rest looks ok, but i think your problem is just logging is incorrect for your rom/tune
http://www.ft86club.com/forums/showthread.php?p=2909412
Old 12-18-2018, 04:22 PM   #28
Mr_Eyo
Thanks for the comments. I Just checked my defs in RomRaider and found I had the wrong one at the top (ZA1JN10D, my car is ZA1JK00D and it was the next one down). I think these logging quirks started around the same time I downloaded that def. Could writing a tune with the following year's def cause this? AFAIK, the logger would be using the ZA1JK00D defs, right?
I'm not sure I'm understanding your linked forum post, so let me see if I have it right. If the correct cal ID doesn't fix this, you're saying I can set the limits for my AF #3 sensor to 0/0, even if my RomRaider def puts it in a different group ("ALPHA AF 3 (Rear O2 Sensor)", not "Fueling - AF Correction/Learning") from what was shown in your screen cap?
Dash Command App and Oil Temp on iPhone and iPad nzer Scion FR-S / Toyota 86 GT86 General Forum 38 03-19-2017 12:33 PM
Dash command for BOOST Flat_4_Life Forced Induction 5 01-18-2016 12:13 PM
idle afr is 14.05? command and actual...what gives? Lytheum Issues | Warranty | Recalls / TSB 1 06-24-2013 01:21 PM
Voice or GUI command to pause guidance? Sovran Electronics | Audio | NAV | Infotainment 0 09-25-2012 02:21 PM
handsfree voice command help lbroskee Electronics | Audio | NAV | Infotainment 5 09-13-2012 04:51 PM
