Old 12-17-2018, 06:31 PM   #15
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
sorry to hear OP, your car is probably totaled. please mail your broken trans & engine over to me, ty
HKz is offline   Reply With Quote
Old 12-17-2018, 06:42 PM   #16
BRZ_Prague
BRZ_Prague's Avatar
Drives: 2015 Subaru BRZ Sport
You are a man of interesting taste. Boxer with spun rod bearing matched with an auto is something I wouldnt even send to subaru nightmare museum.
BRZ_Prague is offline   Reply With Quote
Old 12-17-2018, 06:44 PM   #17
HKz
Reformed
HKz's Avatar
Old 02-23-2023, 11:59 AM   #18
AF_Speshul
Drives: 2015 Scion FRS (AT)
Originally Posted by extrashaky View Post
In that case, a couple of other things come to mind:
You mentioned yours is a 2015 and his is a 2014, but you didn't indicate the miles. An exhaust system's sound will change over its lifetime. Is there a difference in the number of miles on these cars?
If not that, then I'd suspect it has something to do with the fuel flow as controlled by the computer. I drive long distances and use the cruise control quite often. I have noticed that the engine tone sometimes changes when I engage or disengage the cruise, even at the same speed and RPM. When the computer takes over, the engine gets quieter.
With the automatic, the computer is always in control. Since the manual is putting more of the decisions in the driver's hands than the automatic, perhaps the computer allows more fuel to flow for the manual to be ready for the driver's inputs, whereas the automatic's computer can reduce the fuel flow since the shift points will be more predictable. With different fuel flow, you'd get a different sound.
I own a 2015 Automatic FRS and I can confirm this is true when I start driving in the morning I have it in drive but when i switch it to manual mode even at 2k rpm or whatever rpm it was at while in drive the sound changes
AF_Speshul is offline   Reply With Quote
Old 02-25-2023, 10:27 AM   #19
mrhemi
A manual trans vehicle will always sound different that the auto trans equivalent because the resonance of the mechanical coupling (clutch) vs. the fluid coupling (torque converter) skews the audio note. Even a "lock up" torque converter skews the audio resonance due to the damping effect of the extra mass of the fluid.
mrhemi is offline   Reply With Quote
Manual vs Automatic (Help!) Mr. J Engine, Exhaust, Transmission 177 01-04-2021 06:22 PM
Manual or Automatic? Why? DC86 Scion FR-S / Toyota 86 GT86 General Forum 184 10-08-2018 08:58 PM
Automatic vs Manual Rabble Scion FR-S / Toyota 86 GT86 General Forum 26 12-05-2011 02:55 PM
BRZ manual or automatic? f1ver BRZ First-Gen (2012+) — General Topics 23 08-30-2011 10:07 PM
