#15 |
| The Following User Says Thank You to humfrz For This Useful Post: | H1C (08-06-2018) |
#16 | |
Drives: 2014 FR-S MT
Yup, the area under the spare is easy to drain. I won't get concerned unless I start finding water in other parts of the interior. I've had it lucky so far: my buddy with a 2nd gen MR2 has to dry out his entire interior after every rain storm -- the sunroof leaks that badly. |
#17 | |
![]() humfrz |
#18 |
Drives: WRB BRZ
I guess I'm not alone here. It started with both my toms taillights getting filled with water.
Took the trunk lining out and saw a pool of water accumulate on both sides of the trunk and some in the middle, under the spare tire. Since both ends of the trunk had at least 3" of water with no sign of a drain, I decided to just drill a hole on the body to drain out the water. For the spare tire area, I just unplugged the rubber plugs to drain it out. ![]() If you decide to do this, don't forget to dry out the area where u drilled and paint over the bare metal around the hole to prevent rust. |
#19 |
Sorry to hear that this happened to you. I'm still getting a little bit of water under the spare towards the trunk lid after really heavy rains, which we've had a lot of this fall. I'm still at a loss as to how it's getting there, except for my condensation theory I posited earlier. It's so humid here that I drive with the front defogger on probably 70% of the time, and the rear can stay fogged/frosted even after 20 minutes of driving with the rear defroster on. I guess I'll just keep checking on it every now and then, to make sure no big pools of water are accumulating. |
#20 |
Wheels for Brains
Check your tail light gaskets
| The Following User Says Thank You to EndlessAzure For This Useful Post: | H1C (12-29-2018) |
#21 |
Drives: WRB BRZ
Went with ninja gaskets after the OEM failed, as well as the toms gasket. I'm sure this is where the problems started. But if the gaskets fail, I got a drain. Fuck u rain!
#22 |
#23 |
The Fail Boat
Drives: CWP S.B.
or don't park the car outside. :p
#24 |
#26 |
This is how much has accumulated in the spare's well after several weeks of pretty steady rain. There was nothing in the side areas. Dried it off and will keep an eye on it.
#27 |
You got me wondering, so I decided to order a pair of new OEM gaskets and take the lights off to see what was going on behind them. There seem to have been two revisions to the gasket part numbers: the ones I got are SU003-05121, SU003-05122. The old gaskets had a bunch of crud along their top edge where water and debris had poured over it for the past 4+ years I've had the car. But they held up: I never had any condensation in the lamps, and I don't believe water was getting past them and into the car. But, I think I found how water's been pooling under the spare. There are three clips in the vicinity of each tail light that attach the bumper to the body. When I had the lights out, I could see that only one of the three (circled in green) has a gasket on it. The other two clips don't. I think these naked clips are how water has been seeping into the spare wheel well. Compared to the gaskets that came on the car, the new ones seem to be slightly thicker and made of a denser, more memory-foam-like material. My lights also seem to have been lightly tightened down at the factory -- I could basically un-do the nuts by hand. After tightening the lights with the new gaskets to spec (39 lb-in), there is now a visible gap between the lower edge of the light and bumper. I don't think that was there before, but I could be wrong. It's a little annoying, but only noticeable if you look real close and from beneath the tail light. |
| Trunk flooring/spare tire cover | switchlanez | Want-To-Buy Requests | 0 | 02-23-2017 02:17 PM |
| Replace Only 1 Tire? / Spare Tire Question | chermo12 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-28-2015 02:44 PM |
| WTB: Trunk carpet, cover, spare tire, tools, foams, latch trim/cover | Izzy | Want-To-Buy Requests | 7 | 06-27-2015 07:38 PM |
| FS: OEM Trunk Set Up & Spare tire | MicheleAbbate | Interior Parts (Incl. Lighting) | 34 | 04-27-2015 07:36 PM |
| Spare tire becoming loose in trunk | midnight23 | Issues | Warranty | Recalls / TSB | 3 | 05-22-2014 11:09 AM |
