12-13-2018, 11:01 AM | #407 | |
Subaru has one that's more detailed. That's what I presented to the Toyota dealership.
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
12-13-2018, 12:27 PM | #408 |
Drives: 2013 Argento FRS
ok.. cool. Thanks for response. I just want to make sure what the are telling me is right on. Initially they doubted the repaired would be covered under power train warr and whithin an hour of them looking at it, they gave me a loaner and said they need to open a case with Toyo. Its been in 3 days. Seems this may be a somewhat common issue ?
12-13-2018, 02:08 PM | #409 | |
Toyota should cover 100%, unless you're over on mileage or months according to the powertrain warranty. If not, file a complaint with corporate. That's what I did, and they helped.
12-13-2018, 05:45 PM | #410 |
Drives: 2013 FRS supercharged
Not sure. However for an update on my same issue. I changed the oil after running a motor oil flush in engine for about 10 minutes. Also did a good clean on my air filter. I put in new oil and filter. I connected my Ecutek and cleared all the codes. So far I have driven the car a total of about 50 miles with no more CEL codes. The dealer did say that the car was a couple quarts low when they checked it but I don't recall my car using any oil at all. They wanted 3K to go into engine and fix cam sprocket too. I am really glad I didn't let them do anything! 3K is a lot of cash when all I have done so far is an engine flush and new oil. We shall see if it stays healthy!
12-13-2018, 05:52 PM | #411 |
I can tell you this! My dealer told me that since I had not had the oil changed at dealer and there were no records of it being changed (because I do it), that they would NOT do any work under warranty. I think they used that as a loop hole! They also told me they were willing to help me out. They offered me a $400 discount on the total 3K to fix my car! Just be wary of the dealer. They had my car a week and kept promising me that I would not have to pay anything. They also told me they were running it by cooperate as well. After a week of going back and forth, They told me I would have to pay! In my opinion, way too many loop holes in the dealer warranties!
12-13-2018, 06:58 PM | #412 | |
FYI - Boxer/flat configured engines have the tendency to burn oil more than normal. I would check it every month or 1000 miles.
12-13-2018, 07:18 PM | #413 |
So, after the tank of gas what did your issue end up being for sure? Cam sprocket? Thanks for the tip on the oil too. I change it earlier than I should but did not check it often which I will be sure to do from now on.
12-13-2018, 07:22 PM | #414 |
How do you like this set up? Enkei TS-10s, BFGoodwrench Sport Comp2 tires
I have Enkei wheels but am going to need tires soon. Perellli is an awesome tire with a big price but I really liked the last set I had. I have BFs on my JEEP wrangler and love them too. |
12-13-2018, 09:39 PM | #415 |
It was the cam sprocket. I went through 2 ecu changes, and it came back each time.
12-13-2018, 09:44 PM | #416 |
Drives: 2013 Subaru BRZ
Honestly, you need to troubleshoot everything. Almost feels like everyone's situation is slightly different. Knock on wood, but I think my issue was just ECU related. I fought over it for months and months and months.Sent from my Pixel 2 XL using Tapatalk
12-13-2018, 09:47 PM | #417 | |
Performance wise, it beats the stock setup. Price wise, it's inexpensive. If you want more grip, I would recommend going up in tire categories (e.g. a ultra or max performance summer tire). And the wheel is light for the size: 17x8 at 17.6lbs.
12-13-2018, 10:43 PM | #418 |
extra what?
Guys, a jammed spool valve will fuck up a perfectly good ECU. Once the ECU is out of whack, it MUST be replaced. It will never re-learn the correct initial position values. It sucks that the system is designed that way but, until someone cracks the low-level area where those values are stored, there's no return adjustment.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | alxtheoreo (12-14-2018), TheStig85 (12-13-2018) |
12-14-2018, 11:57 AM | #419 |
This has all been a great help guys. I will keep my fingers crossed that an simple oil change did the trick for me. So far I have driven the car 100 miles without CELs. If I see this light again, I will plan on a pulled timing cover and maybe a cam sprocket change and then on to an ECU if CEL for this issue still haunts me.
12-14-2018, 06:13 PM | #420 | |
Sent from my Pixel 2 XL using Tapatalk |
The Following User Says Thank You to TheStig85 For This Useful Post: | Ultramaroon (12-14-2018) |
Similar Threads | ||||
P0016 fixable without new ECU? | Mr.Jay | Issues | Warranty | Recalls / TSB | 8 | 02-06-2022 05:15 AM |
P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-16-2021 11:09 PM |
P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 02:31 PM |
p0016 need help asap | lol | Issues | Warranty | Recalls / TSB | 25 | 10-30-2018 03:49 PM |
OFT P0016 and TSB question | mmmcambelsoup | Software Tuning | 10 | 05-24-2017 09:24 AM |
