Old 12-11-2018, 04:37 AM   #1107
BigDaddyD
Drives: Asphalt 2016 FRS
Hey guys,
I ordered the kit and it should be here in about 2 weeks. I have been making of list of small tools and such i've seen on the install posts. Is there any specific things that helped you all with the install? Also all I bought was the turbo kit/ tune, will that be enough for now? I plan on getting a catch can and oil cooler eventually, but just wanted to make sure I can survive a little while without it.
BigDaddyD is offline   Reply With Quote
Old 12-12-2018, 10:59 AM   #1108
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by BigDaddyD View Post
Hey guys,
You'll also want to purchase the pre-welded oil pan, and some Permatex Ultra Black sealant for when you put the new pan on.
Be sure to install the wastegate to the manifold before securing the manifold to the engine.
If they aren't already included, get some hose clamps and secure them on both ends of the turbo oil drain hose over where it meets the push-lock fittings.
How long is a little while for running without a catch can and oil cooler? I would say that a catch can is critical on a turbo engine as you'll get blowby and crankcase pressure as soon as you start boosting it. Without a catch can, that blowby will recirculate directly back into your intake manifold and reduce your octane and performance. Also the stock rear pcv valve is not designed for boost. I recommend the Verus Engineering can, but if you're on a budget, the Mishimoto 3-port can is decent (just order it separately with the BRZ/FRS mounting bracket). Make sure you read my post in the owner's group on how to properly set up your catch can.
Since you are in California, an engine oil cooler is also a must-have for hard driving, especially in summer months. Your turbo is going to heat up the oil as it's fed through it and you may see temperatures approach dangerous levels after a few back to back pulls without an oil cooler. If you want to wait, just make sure you run 5w30 oil and change it more frequently until you get a cooler, and monitor your oil temps, making sure they don't go above 230-240F.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Conman (12-24-2018)
Old 12-12-2018, 09:46 PM   #1109
BigDaddyD
I was thinking like a month or 2, but after reading your post I realized I should just do it when I install the kit. There is someone in the FB parts for sale group selling a radium dual catch can for $200. Is it a good deal? Or are catch cans best to buy brand new ?
Old 12-13-2018, 11:15 AM   #1110
ATL BRZ
ATL BRZ's Avatar
Sounds like a good deal to me. Just make sure you set them up properly, particularly on the passenger side can that's fed by the rear PCV
Old 12-14-2018, 02:24 AM   #1111
BigDaddyD
Thanks I’ll make try to do so. And if you’re not busy I’ll check in with you to make sure I did it correctly😅
Old 12-25-2018, 03:19 PM   #1112
Conman
Conman's Avatar
Drives: Red FRS
Thoughts on this kit with stock engine internals?
Conman is offline   Reply With Quote
Old 12-26-2018, 02:09 PM   #1113
ATL BRZ
ATL BRZ's Avatar
Keep the boost low (7-10 psi) and the fuel octane high (93+) and stock engines will be fine
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Conman (12-26-2018), kev0 (02-03-2019)
Old 12-26-2018, 06:34 PM   #1114
Conman
Conman's Avatar
Drives: Red FRS
And if I ran low boost with E85? What kind of rpm could I expect it to hit full boost?
Old 12-26-2018, 09:46 PM   #1115
ATL BRZ
ATL BRZ's Avatar
The RPM when you turbo hits full boost depend on the turbo you choose. Smaller = spools quicker, Larger = spools slower
The base kit comes with a small, quick spooling turbo that delivers low boost as soon as 3000-3500 RPMs.
Conman (12-26-2018)
Old 02-03-2019, 02:09 AM   #1116
C3
C3's Avatar
Drives: Scion FR-S
Is anybody seeing low output numbers with the no cut ic option? First day on the dyno after breaking in the new block and only put up 210whp. Another guy with the v1 kit and same turbo put up 287 on the same dyno. I'm wondering if there is a boost pressure drop situation with the no cut.
C3 is offline   Reply With Quote
Old 02-03-2019, 12:30 PM   #1117
ATL BRZ
ATL BRZ's Avatar
There shouldn't be any pressure drop especially on a newly broken in engine. I'd have the system checked for boost leaks, which is the likely issue here. Check all the couplings and their clamps, even the one on the back of the intercooler, which can be difficult to see on a no-cut kit. Also check that your wastegate is installed and set up correctly with the vaccum and boost reference lines in the right ports.
C3 (02-03-2019)
Old 02-03-2019, 01:55 PM   #1118
C3
C3's Avatar
Drives: Scion FR-S
We pressure tested the system when we got on the dyno and found no leaks. But you are right the car is just not making boost so there must be a leak somewhere. Thanks for the reply
Old 02-03-2019, 04:04 PM   #1119
ATL BRZ
ATL BRZ's Avatar
You may need to use smoke when pressure testing so you can find the leak
Old 02-03-2019, 04:18 PM   #1120
Trust86
Drives: 2016 Halo FRS
You sure wastegate is hooked up/installed correctly? Sounds like valve seat in wastegate wasn’t installed
Trust86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Trust86 For This Useful Post:
ATL BRZ (02-04-2019), C3 (02-04-2019)
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
