Old 12-07-2018, 02:47 PM   #99
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Originally Posted by CokeZero View Post
What did you do for the wire melting on header?
And did the electric fans fix the overheat?
What oil pan are you using?
It has never overheated and it has had electric fans from the beginning. Engine temps run between 180 to 220.
I did notice the under hood temperatures were warm, specifically at the fuel rails since they're at the very top, but the addition of the tracspec hood vents keeps the engine bay nice and cool now.
Oil pan (and all parts) are listed in detail at the first post of this thread.
I routed the cylinders two and four under the headers up the front of the engine and to the coils. Did this with some MSD 32073 cut-to-length LS wires.
spitsnaugle is offline   Reply With Quote
Old 12-11-2018, 09:56 AM   #100
spitsnaugle
Probably the last time its out for the year...
Just got 255/40r17's mounted instead of the 235/40's... they don't really hook any better. Time for slicks and a second set of rims.
should note 255's with 17x9 +42 wont fit up front without a spacer.
Old 12-11-2018, 02:35 PM   #101
Axis2011KR
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
@VR4EVER @spitsnaugle did yall run a batch of clutch master cylinder recesses or did some make it over to @Pure Automotive for sale?
Axis2011KR is offline   Reply With Quote
Old 12-12-2018, 09:42 AM   #102
spitsnaugle
Thanks for the reminder, my location of the MC was slightly higher than OEM causing a slight hard spot in the pedal swing. This higher location was to avoid a stud (the stud only holds harness) from below it.
I finished revising the design last night, removing that stud, I'll send it back to my CAD guy this week.
Old 12-12-2018, 10:27 AM   #103
vijay.dy06
Drives: Red BRZ
Whats the price going to be?
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 12-14-2018, 11:03 PM   #104
spitsnaugle
Waiting to hear final prices from CNC guy. He has my revised design, asked me for a few more dimensions. (I'm only familiar with 2d cad work, not 3d).
I'm not a site vendor. So I wont be publicly announcing pricing or sales, keep it to PMs or hopefully I'll just produce some batches for PureAutomotive to sell.
PS to all- I've been reorganizing the my posts throughout this thread, trying to consolidate important info into the first post, and putting posts into better order. Hopefully its useful info for folks getting started in their swaps.
Old 12-16-2018, 12:05 AM   #105
Merc
Drives: Subaru brz 2013 LS1 swap
Wow first page first post update with the build process, all parts, and electrical is awesome! This Thread has to be one of the best laid out ive seen really helping my build go much smoother. Thanks for the great build thread.
Merc is offline   Reply With Quote
Old 12-19-2018, 03:59 PM   #106
frsty_86
frsty_86's Avatar
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
I must have missed the part about the rear end. Are you using a completely stock diff, a stock diff with different gears, or a swapped diff? I'd consider doing a Ford 8.8 on such a setup.
frsty_86 is offline   Reply With Quote
Old 12-19-2018, 05:05 PM   #107
spitsnaugle
Completely stock diff at the moment.
My next order of changes are:
  1. Fix a mild oil leak at front balancer, strangely only leaks at full throttle.
  2. Dyno Tuning
  3. Coilovers: CSG spec Tein Flex A or standard Tein Flex A
  4. Gears: 3.58 + flange
  5. Track wheel setup: 17x9 Wheels + Hoosier A7 245/40rz17
  6. Air conditioning: need to route two lines.
I formerly had a ford 8.8" in my 240z with 930cv joints, it was overkill. We have the same 8" rear end as Lexus IS300's and Supras. I suspect it'll handle my mid-400whp without too much issue. If I was north of 500hp, I would be worried.
Old 12-20-2018, 10:50 PM   #108
CokeZero
CokeZero's Avatar
Drives: 2015 brz
What kind of cart is this? where can I get one?
CokeZero is offline   Reply With Quote
Old 12-20-2018, 10:53 PM   #109
spitsnaugle
Lowe's: Gorilla Cart, has removable sides.
That one has 1,000lb capacity, another Gorilla Cart model at HomeDepot had 1,200lbs.
Super handy to roll around dirt, stone pavers, or an engine.
https://www.lowes.com/pd/Gorilla-Car...Cart/999930538
Old 01-16-2019, 05:55 PM   #110
Merc
What was the length approximately on the spark plug wires 2 and 4, also only 2 and 4 around the front? I'm using the cx headers as well but I ceramic coated and wrapped them so pretty tight on a few spots between but should be less heat.
Old 02-05-2019, 11:47 AM   #111
spitsnaugle
No idea, never measured, I put them on the coil, routed them with space, marked the wire at the spark plug location, and cut.
Old 02-05-2019, 11:50 AM   #112
spitsnaugle
master cylinder recess update:
first REVISED model is being cut now.
cx racing, ls swap, ls2, pure automotive
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP ILLSMOQ Engine Swaps 172 11-24-2022 07:01 PM
LS2 swap by KAB Customs with Pure Automotive Motec Sportsguy83 Engine Swaps 254 10-17-2018 12:45 PM
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
