Old 12-11-2018, 02:14 PM   #15
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
What I'd really like to see is the actual procedure to fix it. Has that been posted somewhere yet?
Old 12-11-2018, 05:56 PM   #16
That would be above your paygrade, there Spuds -
Old 12-11-2018, 07:15 PM   #17
gravitylover
There was a post in one of the threads where a guy knew someone that is a tech at a dealer in Australia I think. He gave a quick rundown but no specifics because they haven't really released the details yet.
Old 12-11-2018, 08:06 PM   #18
Well according to all the "enthusiasts" here they are still working out instructions that the poor, imbecilic, uncaring, Toyota techs can manage to understand.
gravitylover (12-11-2018), Gunman (12-12-2018), Overdrive (12-12-2018), RallySport (12-15-2018)
Old 12-11-2018, 09:33 PM   #19
Old 12-11-2018, 11:10 PM   #20
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Originally Posted by meadowz06 View Post
Great contribution. You should probably sit this one out.
Cool. All the pressure's off. My wife is very happy that my contributions are no longer needed, and I was about to fold under the pressure anyway. Thanks!
BTW... torque dip... ?
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 12-11-2018, 11:17 PM   #21
Yum! Extra spicy for me, please.
johan (12-12-2018)
Old 12-11-2018, 11:20 PM   #22
MuseChaser
MuseChaser's Avatar
If I made it the way I usually do, you'd have to sit this one out, too.
The Following User Says Thank You to MuseChaser For This Useful Post:
Ultramaroon (12-12-2018)
Old 12-11-2018, 11:24 PM   #23
By the numbers, large print, small words, lots of pictures and slow motion videos - right ??
Old 12-11-2018, 11:32 PM   #24
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Most boring board ever.
MuseChaser (12-12-2018), strat61caster (12-12-2018)
Old 12-12-2018, 12:58 AM   #25
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Why would it be any different from ‘refer to service manual replace valve springs with updated part, reassemble to spec’?
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
Gunman (12-12-2018), Spuds (12-12-2018), Tcoat (12-12-2018), Ultramaroon (12-12-2018)
Old 12-12-2018, 08:14 AM   #26
Spuds
The Dictater
Spuds's Avatar
Old 12-12-2018, 09:42 AM   #27
ermax
ermax's Avatar
Because from what I am hearing in this thread they plan to do it without removing the heads which is not what the manual wants you to do. The manual also doesn't want you to remove the cam caps before removing the cam subassemblies for risk of warping the heads. Perhaps they are trying to come up with an untorquing procedure that will allow them to remove the caps while the subassembly is still bolted to the head without warping. This would be a big time saver because you wouldn't have to clean up packing and reseal. Just think of how hard it would be to clean packing off a head and shit dropping down in there with no way to flush because you are trying to leave the head bolted to the engine.
The Following User Says Thank You to ermax For This Useful Post:
Old 12-12-2018, 10:20 AM   #28
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Debris will fall down an oil drainage how into the sump where it's relatively easy to flush.
Also, it's probably very doable without taking the cams off, one would just need an appropriate special tool to compress the lifter. If you can compress the lifter, you can take the shim out and it's very likely that once the shim is out you can take the rocker out from under the cam. Once that's out you've got a clear shot at the valve stem. Some compress air into the plug hole to hold the valve in while taking the spring out is all that's needed.
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Dealer recommendation for valve spring recall: South of Seattle rice_classic Northwest 8 03-17-2019 03:06 AM
VALVE SPRING WORLD - PRESS RECALL Trap63 Issues | Warranty | Recalls / TSB 85 03-12-2019 11:38 PM
67k miles, will bring car in for valve spring recall, what else to fix down there? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 12-19-2018 12:59 PM
Subaru Global Recall Checker (Japanese) - valve and so on Trap63 Issues | Warranty | Recalls / TSB 6 11-17-2018 03:28 AM
