#113 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Depends on whether you're fat or not I guess?
![]() I did mine using jack stands and there was not need to remove any covers.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#114 | |
nenber
sounds good for me -im not fat but i have quite big hands . hope its not too crowded hah anyhow if i go for that method i dont need to remove anything from inside the car right ? |
#115 |
Nope, it's completely accessible from underneath.
95RON SAV Tuned |
#117 |
nenber
Lifted the car up.
I cant get my hands in there . Sent from my SM-G960F using Tapatalk Edit Its ok thx
#118 | |
Drives: 2015 Subaru BRZ Limited
Anyone know the size of this washer? ID/OD? |
#119 | |
Drives: Toyota 86 (High) - White
#120 |
Drives: 2017 BRZ PP
Anyone know the size of the washers? ?part numbers? Wanted to order some - since everything is shut down and cant just run out and try a couple.
#121 |
No idea, I simply used one I had laying around.
95RON SAV Tuned |
#122 |
Toyota SU003-00892
Subaru 35038CA010 Same part... |
#123 |
Drives: 2014 Subaru Forester
I purchased 10mm washers from Lowes, stainless steel and nylon. With the SS I was not able to put the pin back in (~2.05mm thich). Nylon worked (1.65mm thick), but I'm going to check it to make sure it's not wearing poorly.
#124 |
Stock ones are conical
#125 |
86 Challenge
Drives: 2017 BRZ
#126 |
Drives: 2015 FR-S
Necro thread... looking at the 2022 shifter linkage the pin holding the washer (no change) has been changed to a ring clamp. Otherwise everything looks the same although not the same part numbers.
https://parts.subaru.com/a/Subaru_20...11-350-01.html I might order this ring clamp and see if it works better than trying to find a slightly thicker washer. not sure how such a tiny ring clamp works is it just one piece that's stretched to fit on? |
| The Following User Says Thank You to FrickingReallySlow For This Useful Post: | sav (01-02-2022) |
| Flywheel Rattle? | CB762 | Issues | Warranty | Recalls / TSB | 119 | 11-16-2016 10:09 PM |
| Vibrating shifter fix! | Superhatch | Issues | Warranty | Recalls / TSB | 51 | 06-05-2016 10:56 PM |
| Flimsy shifter | chessplaya2010 | Issues | Warranty | Recalls / TSB | 1 | 07-31-2012 01:21 PM |
| A/C Rattle? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 07:46 PM |
| FR-S Shifter Video | xravexboix | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 10 | 04-21-2012 08:20 PM |
